[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #425
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/425/changes&gt;
Changes:
[ang05a] - features with app-schema mapping with mappingName should still be able to be queried as a top level feature type.
- trivial changes for assertEquals() parameter order in tests
[riniangreani] Test app-schema mapping mappingName for top level feature type.
[...truncated 21413 lines...]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/surefire-reports&gt;
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/gwc/target/web-gwc-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-gwc/2.0.2-SNAPSHOT/web-gwc-2.0.2-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target&gt;
[INFO] [resources:resources]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.381 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wfs/target/web-wfs-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0.2-SNAPSHOT/web-wfs-2.0.2-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target&gt;
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/classes&gt;
[INFO] snapshot org.geoserver:wcs1_1:2.0.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.0.2-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/surefire-reports&gt;
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
Apr 13, 2010 1:35:13 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Apr 13, 2010 1:35:14 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Apr 13, 2010 1:35:16 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/./target/mock41680data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.975 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.03 sec
Results :
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0
Apr 13, 2010 1:35:20 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/./target/mock41682data&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/wcs/target/web-wcs-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0.2-SNAPSHOT/web-wcs-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Demoes Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target&gt;
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-sample-data:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 11 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/classes&gt;
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Apr 13, 2010 1:35:38 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.352 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.511 sec
Running org.geoserver.web.demo.SRSListPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.844 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
Apr 13, 2010 1:35:47 AM java.util.prefs.FileSystemPreferences$7 run
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.2-SNAPSHOT/web-demo-2.0.2-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target&gt;
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/classes&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
Apr 13, 2010 1:35:57 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 8.294 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.462 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.006 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.378 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.359 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.554 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.281 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.74 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.191 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 7 minutes 9 seconds
[INFO] Finished at: Tue Apr 13 01:36:10 EDT 2010
[INFO] Final Memory: 46M/116M
Failed to send e-mail to ang05a because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/426/changes&gt;
Changes:
[riniangreani] Restore the test that was commented out for GEOS-3722.
[...truncated 3008 lines...]
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.8">
<cdf:boundedBy>
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.9">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.161 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Running org.geoserver.wfs.DescribeFeatureTest
13 Apr 04:52:31 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:135)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:98)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy11.describeFeatureType(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:599)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:230)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1086)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1053)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:657)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:604)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:584)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:793)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:776)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:51)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor162.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
sf
cdf
cgf
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.221 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.259 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.135 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.403 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type :InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 1.544 sec <<< FAILURE!
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.544 sec
Results :
Tests in error:
  testNoNativeProjection(org.geoserver.wfs.response.ShapeZipTest)
  testCharset(org.geoserver.wfs.response.ShapeZipTest)
  testMultiType(org.geoserver.wfs.response.ShapeZipTest)
  testMultiTypeDots(org.geoserver.wfs.response.ShapeZipTest)
  testGeometryInTheMiddle(org.geoserver.wfs.response.ShapeZipTest)
  testNullGeometries(org.geoserver.wfs.response.ShapeZipTest)
  testLongNames(org.geoserver.wfs.response.ShapeZipTest)
  testDots(org.geoserver.wfs.response.ShapeZipTest)
  testEmptyResult(org.geoserver.wfs.response.ShapeZipTest)
  testEmptyResulMultiGeom(org.geoserver.wfs.response.ShapeZipTest)
Tests run: 181, Failures: 0, Errors: 10, Skipped: 0
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wfs/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 57 seconds
[INFO] Finished at: Tue Apr 13 04:52:35 EDT 2010
[INFO] Final Memory: 41M/118M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/427/changes&gt;
