See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/43/changes>
Changes:
[aaime] GEOS-3626, Projection policy completely ignored in GS 2.0
[aaime] GEOS-3626, Projection policy completely ignored in GS 2.0, first cut
[...truncated 26554 lines...]
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
05 Nov 12:59:01 ERROR [geoserver.rest] - No such workspace: foo
org.geoserver.rest.RestletException
at org.geoserver.catalog.rest.WorkspaceFinder.findTarget(WorkspaceFinder.java:33)
at org.restlet.Finder.handle(Finder.java:268)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:38)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:79)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1058)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1025)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:467)
at org.geoserver.catalog.rest.WorkspaceTest.testDelete(WorkspaceTest.java:152)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:125)
05 Nov 12:59:01 ERROR [geoserver.rest] - Workspace not empty
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectDelete(WorkspaceResource.java:150)
at org.geoserver.rest.ReflectiveResource.handleDelete(ReflectiveResource.java:219)
at org.restlet.Finder.handle(Finder.java:300)
at org.springframework.web.servlet.FrameworkServlet.doDelete(FrameworkServlet.java:531)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:715)
at org.geoserver.test.GeoServerAbstractTestSupport.deleteAsServletResponse(GeoServerAbstractTestSupport.java:666)
at org.geoserver.catalog.rest.WorkspaceTest.testDeleteNonEmptyForbidden(WorkspaceTest.java:156)
05 Nov 12:59:02 ERROR [geoserver.rest] - Can't change the name of a workspace.
at org.geoserver.catalog.rest.WorkspaceResource.handleObjectPut(WorkspaceResource.java:129)
at org.geoserver.rest.ReflectiveResource.handlePut(ReflectiveResource.java:188)
at org.restlet.Finder.handle(Finder.java:298)
at org.springframework.web.servlet.FrameworkServlet.doPut(FrameworkServlet.java:521)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:712)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:563)
at org.geoserver.test.GeoServerAbstractTestSupport.putAsServletResponse(GeoServerAbstractTestSupport.java:551)
at org.geoserver.catalog.rest.WorkspaceTest.testPutNameChangeForbidden(WorkspaceTest.java:189)
05 Nov 12:59:02 ERROR [geoserver.rest] - No such workspace: nonExistant
at org.geoserver.catalog.rest.WorkspaceTest.testPutNonExistant(WorkspaceTest.java:205)
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.913 sec
Results :
Failed tests:
testPropertyFileUpload(org.geoserver.catalog.rest.DataStoreFileUploadTest)
testPropertyFileUploadWithWorkspace(org.geoserver.catalog.rest.DataStoreFileUploadTest)
testPropertyFileUploadZipped(org.geoserver.catalog.rest.DataStoreFileUploadTest)
testShapeFileUpload(org.geoserver.catalog.rest.DataStoreFileUploadTest)
Tests run: 143, Failures: 4, Errors: 0, Skipped: 0
05 Nov 12:59:03 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/restconfig/target/surefire-reports> for the individual test results.
[INFO] Total time: 10 minutes 19 seconds
[INFO] Finished at: Thu Nov 05 12:59:03 EST 2009
[INFO] Final Memory: 53M/153M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/44/changes>
Changes:
[aaime] GEOS-3598, WFS fields larger than 32000 characters corrupt Excel output
[...truncated 26550 lines...]
05 Nov 13:54:18 ERROR [geoserver.rest] - No such workspace: foo
05 Nov 13:54:18 ERROR [geoserver.rest] - Workspace not empty
05 Nov 13:54:19 ERROR [geoserver.rest] - Can't change the name of a workspace.
05 Nov 13:54:19 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.747 sec
Results :
Failed tests:
05 Nov 13:54:20 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
[INFO] Total time: 9 minutes 4 seconds
[INFO] Finished at: Thu Nov 05 13:54:20 EST 2009
[INFO] Final Memory: 52M/145M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/45/changes>
Changes:
[aaime] GEOS-3625, When default workspace is removed there is no way to set it back, this causes datastore creation exceptions
[...truncated 26556 lines...]
05 Nov 16:54:30 ERROR [geoserver.rest] - No such workspace: foo
05 Nov 16:54:30 ERROR [geoserver.rest] - Workspace not empty
05 Nov 16:54:31 ERROR [geoserver.rest] - Can't change the name of a workspace.
05 Nov 16:54:31 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.446 sec
Results :
Failed tests:
05 Nov 16:54:32 ERROR [geotools.jdbc] - There's code using JDBC based datastore and not disposing them. This may lead to temporary loss of database connections. Please make sure all data access code calls DataStore.dispose() before freeing all references to it
[INFO] Total time: 9 minutes 7 seconds
[INFO] Finished at: Thu Nov 05 16:54:32 EST 2009
[INFO] Final Memory: 52M/139M
