[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #432
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/432/&gt;
Started by upstream project "geotools-2.6.x" build number 285
Updating https://svn.codehaus.org/geoserver/branches/2.0.x/src
ERROR: Failed to update https://svn.codehaus.org/geoserver/branches/2.0.x/src
org.tmatesoft.svn.core.SVNException: svn: OPTIONS of '/geoserver/branches/2.0.x/src': 503 Service Temporarily Unavailable (https://svn.codehaus.org)
svn: OPTIONS request failed on '/geoserver/branches/2.0.x/src'
  at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:103)
  at org.tmatesoft.svn.core.internal.wc.SVNErrorManager.error(SVNErrorManager.java:87)
  at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:616)
  at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:273)
  at org.tmatesoft.svn.core.internal.io.dav.http.HTTPConnection.request(HTTPConnection.java:261)
  at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.exchangeCapabilities(DAVConnection.java:516)
  at org.tmatesoft.svn.core.internal.io.dav.DAVConnection.open(DAVConnection.java:98)
  at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.openConnection(DAVRepository.java:1001)
  at org.tmatesoft.svn.core.internal.io.dav.DAVRepository.getRepositoryUUID(DAVRepository.java:146)
  at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SVNBasicClient.java:342)
  at org.tmatesoft.svn.core.wc.SVNBasicClient.createRepository(SVNBasicClient.java:330)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.update(SVNUpdateClient.java:535)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:401)
  at org.tmatesoft.svn.core.wc.SVNUpdateClient.doUpdate(SVNUpdateClient.java:217)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:574)
  at hudson.scm.SubversionSCM$CheckOutTask.invoke(SubversionSCM.java:541)
  at hudson.FilePath.act(FilePath.java:676)
  at hudson.FilePath.act(FilePath.java:660)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:534)
  at hudson.scm.SubversionSCM.checkout(SubversionSCM.java:482)
  at hudson.model.AbstractProject.checkout(AbstractProject.java:833)
  at hudson.model.AbstractBuild$AbstractRunner.checkout(AbstractBuild.java:314)
  at hudson.model.AbstractBuild$AbstractRunner.run(AbstractBuild.java:266)
  at hudson.model.Run.run(Run.java:949)
  at hudson.model.Build.run(Build.java:112)
  at hudson.model.ResourceController.execute(ResourceController.java:93)
  at hudson.model.Executor.run(Executor.java:116)
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/433/&gt;
A SCM change trigger started this job
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/434/&gt;
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/435/&gt;
Started by upstream project "geotools-2.6.x" build number 286
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/436/&gt;
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/437/&gt;
