[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #451
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/451/changes&gt;
Changes:
[aaime] [GEOS-3622] Add back the ability to reload the catalog from disk
[aaime] [GEOS-3925] Log profiles choosable in the GUI should reflect what's available on disk
[aaime] Reverting previous change, it contained extra diffs
[...truncated 3011 lines...]
<gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:exterior>
<gml:LinearRing>
<gml:posList>500000.0 500000.0 500000.0 500100.0 500100.0 500100.0 500100.0 500000.0 500000.0 500000.0</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
<gml:Point srsName="urn:x-ogc:def:crs:EPSG:32615">
<gml:pos>500050.0 500050.0</gml:pos>
</gml:Point>
</cdf:pointProperty>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.8">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.9">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.10">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.11">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.12">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.13">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
<cdf:ft15 gml:id="ft15.14">
<cdf:boundedBy>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</cdf:boundedBy>
<cdf:pointProperty>
</gml:Point>
</cdf:ft15>
</gml:featureMembers>
</wfs:FeatureCollection>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.153 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.242 sec
Running org.geoserver.wfs.DescribeFeatureTest
20 Apr 05:52:42 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:135)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:98)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy11.describeFeatureType(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:599)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:230)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1086)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1053)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:657)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:604)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:584)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:793)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:776)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:51)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor162.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
sf
cdf
cgf
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.318 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.123 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.268 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
Feature type cite:InvalidTypeName unknown
Feature type :InvalidTypeName unknown
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.245 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 10, Failures: 0, Errors: 10, Skipped: 0, Time elapsed: 1.555 sec <<< FAILURE!
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.393 sec
Results :
Tests in error:
  testNoNativeProjection(org.geoserver.wfs.response.ShapeZipTest)
  testCharset(org.geoserver.wfs.response.ShapeZipTest)
  testMultiType(org.geoserver.wfs.response.ShapeZipTest)
  testMultiTypeDots(org.geoserver.wfs.response.ShapeZipTest)
  testGeometryInTheMiddle(org.geoserver.wfs.response.ShapeZipTest)
  testNullGeometries(org.geoserver.wfs.response.ShapeZipTest)
  testLongNames(org.geoserver.wfs.response.ShapeZipTest)
  testDots(org.geoserver.wfs.response.ShapeZipTest)
  testEmptyResult(org.geoserver.wfs.response.ShapeZipTest)
  testEmptyResulMultiGeom(org.geoserver.wfs.response.ShapeZipTest)
Tests run: 181, Failures: 0, Errors: 10, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wfs/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 3 minutes 15 seconds
[INFO] Finished at: Tue Apr 20 05:52:45 EDT 2010
[INFO] Final Memory: 41M/114M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/452/&gt;
