[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #498
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/498/changes&gt;
Changes:
[arneke] GWC automatic support for declared SRS for all layers and layer groups
[arneke] Attempt at temporary fix for intermittent build failues, see comment inline
[...truncated 15504 lines...]
      </Layer>
      <Layer queryable="1">
        <Name>cdf:Seven</Name>
        <Title>Seven</Title>
        <Abstract>abstract about Seven</Abstract>
        <KeywordList>
          <Keyword>Seven</Keyword>
        </KeywordList>
        <SRS>EPSG:32615</SRS>
        <!--WKT definition of this CRS:
PROJCS["WGS 84 / UTM zone 15N",
  GEOGCS["WGS 84",
    DATUM["World Geodetic System 1984",
      SPHEROID["WGS 84", 6378137.0, 298.257223563, AUTHORITY["EPSG","7030"]],
      AUTHORITY["EPSG","6326"]],
    PRIMEM["Greenwich", 0.0, AUTHORITY["EPSG","8901"]],
    UNIT["degree", 0.017453292519943295],
    AXIS["Geodetic longitude", EAST],
    AXIS["Geodetic latitude", NORTH],
    AUTHORITY["EPSG","4326"]],
  PROJECTION["Transverse Mercator", AUTHORITY["EPSG","9807"]],
  PARAMETER["central_meridian", -93.0],
  PARAMETER["latitude_of_origin", 0.0],
  PARAMETER["scale_factor", 0.9996],
  PARAMETER["false_easting", 500000.0],
  PARAMETER["false_northing", 0.0],
  UNIT["m", 1.0],
  AXIS["Easting", EAST],
  AXIS["Northing", NORTH],
  AUTHORITY["EPSG","32615"]]-->
        <LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Default</Name>
          <Title>Default Styler</Title>
          <Abstract/>
          <LegendURL height="20" width="20">
            <Format>image/png</Format>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Seven&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cite:Streams</Name>
        <Title>Streams</Title>
        <Abstract>abstract about Streams</Abstract>
        <KeywordList>
          <Keyword>Streams</Keyword>
        </KeywordList>
        <SRS>EPSG:4326</SRS>
GEOGCS["WGS 84",
  AUTHORITY["EPSG","4326"]]-->
        <BoundingBox SRS="EPSG:4326" maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
        <Style>
          <Name>Streams</Name>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Streams&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
        <Name>cdf:Updates</Name>
        <Title>Updates</Title>
        <Abstract>abstract about Updates</Abstract>
        <KeywordList>
          <Keyword>Updates</Keyword>
        </KeywordList>
  GEOGCS["WGS 84",
  UNIT["m", 1.0],
        <Style>
          <Abstract/>
            <OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink&quot; xlink:href="http://localhost/proxy/wms?request=GetLegendGraphic&amp;format=image%2Fpng&amp;width=20&amp;height=20&amp;layer=Updates&quot; xlink:type="simple"/>
          </LegendURL>
        </Style>
      </Layer>
    </Layer>
  </Capability>
</WMT_MS_Capabilities>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.407 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.007 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Results :
Tests run: 172, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.2-SNAPSHOT/wms-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.2-SNAPSHOT/wms-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/wms/target/wms-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wms/2.0.2-SNAPSHOT/wms-2.0.2-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 8 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target/surefire-reports&gt;
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
May 11, 2010 1:44:11 PM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Exception in thread "Thread-9" java.lang.NullPointerException
  at org.geoserver.gwc.GWCCatalogListener.getGrids(GWCCatalogListener.java:435)
  at org.geoserver.gwc.GWCCatalogListener.getLayer(GWCCatalogListener.java:361)
  at org.geoserver.gwc.GWCCatalogListener.getTileLayers(GWCCatalogListener.java:258)
  at org.geowebcache.layer.TileLayerDispatcher.initialize(TileLayerDispatcher.java:136)
  at org.geowebcache.layer.TileLayerDispatcher.access$300(TileLayerDispatcher.java:33)
  at org.geowebcache.layer.TileLayerDispatcher$ConfigurationLoader.run(TileLayerDispatcher.java:241)
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 6.996 sec <<< FAILURE!
Running org.geoserver.gwc.GWCIntegrationTest
Exception in thread "Thread-17" java.lang.NullPointerException
11 May 13:44:19 ERROR [geowebcache.GeoWebCacheDispatcher] - null http://localhost/geoserver/gwc/service/wmts?request=GetTile&layer=cite:BasicPolygons&format=image/png&tilematrixset=EPSG:4326&tilematrix=EPSG:4326:0&tilerow=0&tilecol=0
  at org.geowebcache.layer.TileLayerDispatcher.getTileLayer(TileLayerDispatcher.java:69)
  at org.geowebcache.service.wmts.WMTSService.getTile(WMTSService.java:108)
  at org.geowebcache.service.wmts.WMTSService.getConveyor(WMTSService.java:79)
  at org.geowebcache.GeoWebCacheDispatcher.handleServiceRequest(GeoWebCacheDispatcher.java:333)
  at org.geowebcache.GeoWebCacheDispatcher.handleRequestInternal(GeoWebCacheDispatcher.java:252)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1086)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1053)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:472)
  at org.geoserver.gwc.GWCIntegrationTest.testPngIntegration(GWCIntegrationTest.java:21)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 6.861 sec <<< FAILURE!
Results :
Failed tests:
  testPngIntegration(org.geoserver.gwc.GWCIntegrationTest)
Tests in error:
  testInit(org.geoserver.gwc.GWCCatalogListenerTest)
Tests run: 2, Failures: 1, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/gwc/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 14 seconds
[INFO] Finished at: Tue May 11 13:44:23 EDT 2010
[INFO] Final Memory: 43M/112M
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/499/changes&gt;
