[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #533
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/533/changes&gt;
Changes:
[bencaradocdavies] Disabled application schema caching in offline tests
[riniangreani] Matthew Birks' test for GEOS-3807: The maxFeature parameter doesn't work properly with denormalized views
[riniangreani] Shane Bailie's test for GEOT-3095: gml:id aren't encoded for non-feature complex attributes
[bencaradocdavies] Updated release descriptor to include app-schema-resolver as a dependency of app-schema [GEOT-3085]
[...truncated 16884 lines...]
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:862)
  at org.geotools.referencing.operation.projection.MapProjection.transform(MapProjection.java:896)
  at org.geotools.referencing.operation.transform.AbstractMathTransform.transform(AbstractMathTransform.java:235)
  at org.geotools.referencing.CRS.transform(CRS.java:1178)
  at org.geotools.referencing.CRS.transform(CRS.java:1244)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:629)
  at org.geotools.geometry.jts.ReferencedEnvelope.transform(ReferencedEnvelope.java:584)
  at org.geoserver.wms.DefaultWebMapService.autoSetBoundsAndSize(DefaultWebMapService.java:486)
  at org.geoserver.web.demo.PreviewLayer.getRequest(PreviewLayer.java:134)
  at org.geoserver.web.demo.PreviewLayer.getWmsLink(PreviewLayer.java:172)
  at org.geoserver.web.demo.MapPreviewPage$1.getComponentForProperty(MapPreviewPage.java:72)
  at org.geoserver.web.wicket.GeoServerTablePanel$1$1.populateItem(GeoServerTablePanel.java:134)
  at org.apache.wicket.markup.html.list.ListView.onPopulate(ListView.java:573)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:127)
  at org.apache.wicket.Component.internalBeforeRender(Component.java:1009)
  at org.apache.wicket.Component.beforeRender(Component.java:1041)
  at org.apache.wicket.MarkupContainer.onBeforeRenderChildren(MarkupContainer.java:1590)
  at org.apache.wicket.Component.onBeforeRender(Component.java:3727)
  at org.apache.wicket.markup.repeater.AbstractRepeater.onBeforeRender(AbstractRepeater.java:147)
  at org.apache.wicket.markup.repeater.AbstractPageableView.onBeforeRender(AbstractPageableView.java:109)
  at org.apache.wicket.Page.onBeforeRender(Page.java:1458)
  at org.apache.wicket.Component.prepareForRender(Component.java:2167)
  at org.apache.wicket.Page.renderPage(Page.java:892)
  at org.apache.wicket.request.target.component.BookmarkablePageRequestTarget.respond(BookmarkablePageRequestTarget.java:240)
  at org.apache.wicket.request.AbstractRequestCycleProcessor.respond(AbstractRequestCycleProcessor.java:104)
  at org.apache.wicket.RequestCycle.processEventsAndRespond(RequestCycle.java:1245)
  at org.apache.wicket.RequestCycle.step(RequestCycle.java:1316)
  at org.apache.wicket.RequestCycle.steps(RequestCycle.java:1418)
  at org.apache.wicket.RequestCycle.request(RequestCycle.java:578)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:469)
  at org.apache.wicket.protocol.http.MockWebApplication.processRequestCycle(MockWebApplication.java:378)
  at org.apache.wicket.util.tester.BaseWicketTester.startPage(BaseWicketTester.java:289)
  at org.geoserver.web.demo.MapPreviewPageTest.testValues(MapPreviewPageTest.java:7)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:128)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
org.geotools.referencing.operation.projection.ProjectionException: The transform result may be 200,566.547 meters away from the expected position. Are you sure that the input coordinates are inside this map projection area of validity? The point is located 53°23.4'W away from the central meridian and 21687°36.2'S away from the latitude of origin. The projection is "Transverse_Mercator".
  at org.geotools.referencing.operation.projection.MapProjection.checkReciprocal(MapProjection.java:671)
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.89 sec
Running org.geoserver.web.demo.DemoRequestsPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.144 sec
Running org.geoserver.web.demo.SRSListPageTest
May 25, 2010 4:10:11 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.638 sec
Results :
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.3-SNAPSHOT/web-demo-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.3-SNAPSHOT/web-demo-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/demo/target/web-demo-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-demo/2.0.3-SNAPSHOT/web-demo-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Security UI Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target&gt;
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 24 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/classes&gt;
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt;
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
May 25, 2010 4:10:22 AM it.geosolutions.imageio.gdalframework.GDALUtilities loadGDAL
WARNING: Native library load failed.java.lang.UnsatisfiedLinkError: no gdaljni in java.library.path
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 8.305 sec <<< FAILURE!
Running org.geoserver.web.security.user.UserListPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.654 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.305 sec
Running org.geoserver.web.security.data.NewRulePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.262 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.346 sec
Running org.geoserver.web.security.user.EditUserPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.649 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.341 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.293 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.824 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.305 sec
Results :
Tests in error:
  testFill(org.geoserver.web.security.user.NewUserPageTest)
Tests run: 18, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/web/security/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 9 minutes 20 seconds
[INFO] Finished at: Tue May 25 04:10:36 EDT 2010
[INFO] Final Memory: 46M/113M
Failed to send e-mail to bencaradocdavies because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to riniangreani because no e-mail address is known, and no default e-mail domain is configured
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/534/changes&gt;
