[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #614
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/614/changes&gt;
Changes:
[jdeolive] rolling back recent changes for GEOS-3534 and fixing the issue at the geotools level
[...truncated 25121 lines...]
  at org.eclipse.xsd.impl.XSDIncludeImpl.handleResolvedSchema(XSDIncludeImpl.java:247)
  at org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchemaDirectiveImpl.java:387)
  at org.eclipse.xsd.impl.XSDIncludeImpl.patch(XSDIncludeImpl.java:233)
  at org.eclipse.xsd.impl.XSDConcreteComponentImpl.patch(XSDConcreteComponentImpl.java:526)
  at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1505)
  at org.eclipse.xsd.impl.XSDSchemaImpl.changeAttribute(XSDSchemaImpl.java:2335)
  at org.eclipse.xsd.impl.XSDConcreteComponentImpl.eNotify(XSDConcreteComponentImpl.java:1240)
  at org.eclipse.xsd.impl.XSDSchemaImpl.setSchemaLocation(XSDSchemaImpl.java:829)
  at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:756)
  at org.eclipse.xsd.util.XSDResourceImpl.doLoad(XSDResourceImpl.java:784)
  at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:1094)
  at org.eclipse.xsd.impl.XSDSchemaDirectiveImpl.resolve(XSDSchemaDirectiveImpl.java:352)
  at org.eclipse.xsd.impl.XSDSchemaImpl.patchContents(XSDSchemaImpl.java:1547)
  at org.eclipse.xsd.impl.XSDSchemaImpl.patch(XSDSchemaImpl.java:1524)
  at org.eclipse.xsd.impl.XSDSchemaImpl.incorporate(XSDSchemaImpl.java:3235)
  at org.eclipse.xsd.impl.XSDSchemaImpl.included(XSDSchemaImpl.java:3117)
  at org.eclipse.emf.ecore.resource.impl.ResourceImpl.load(ResourceImpl.java:900)
  at org.geotools.xml.Schemas.parse(Schemas.java:256)
  at org.geotools.xml.XSD.buildSchema(XSD.java:250)
  at org.geotools.xml.XSD.getSchema(XSD.java:207)
  at org.geotools.xml.SchemaLocator.locateSchema(SchemaLocator.java:94)
  at org.geotools.xml.Schemas.findSchemas(Schemas.java:153)
  at org.geotools.data.complex.config.EmfAppSchemaReader.parse(EmfAppSchemaReader.java:104)
  at org.geotools.data.complex.config.EmfAppSchemaReader.parse(EmfAppSchemaReader.java:141)
  at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.parseGmlSchemas(AppSchemaDataAccessConfigurator.java:488)
  at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:179)
  at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:159)
  at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:93)
  at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:90)
  at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:96)
  at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:318)
  ... 70 more
Tests run: 2, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 6.815 sec <<< FAILURE!
Running org.geoserver.test.SRSWfsTest
Jul 19, 2010 3:10:12 PM org.geoserver.test.SRSWfsTest testGetFeatureContent
INFO: WFS GetFeature&typename=ex:geomContainer response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-07-19T15:10:12.777-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2&quot; xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot; xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot; xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock63112data/featureTypes/ex_geomContainer/NestedGeometry.xsd&gt; http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <ex:geomContainer gml:id="1">
            <ex:geom>
                <gml:Polygon srsName="urn:x-ogc:def:crs:EPSG:4283">
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.2">
                    <ex:geom>
                        <gml:Point srsName="urn:x-ogc:def:crs:EPSG:4283">
                            <gml:pos>42.58 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
    </gml:featureMember>
    <gml:featureMember>
        <ex:geomContainer gml:id="2">
            <ex:geom>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                <ex:nestedGeom gml:id="nested.1">
                    <ex:geom>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
</wfs:FeatureCollection>
Jul 19, 2010 3:10:13 PM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-07-19T15:10:13.748-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <ex:geom>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                            <gml:pos>42.58000004047607 31.29</gml:pos>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
    <gml:featureMember>
            <ex:geom>
                </gml:Point>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                            <gml:exterior>
                                <gml:LinearRing>
                                </gml:LinearRing>
                            </gml:exterior>
                        </gml:Polygon>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Jul 19, 2010 3:10:13 PM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-07-19T15:10:13.815-04:00" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    <gml:featureMember>
            <ex:geom>
                    <gml:exterior>
                        <gml:LinearRing>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </ex:geom>
            <ex:nestedFeature>
                    <ex:geom>
                        </gml:Point>
                    </ex:geom>
                </ex:nestedGeom>
            </ex:nestedFeature>
        </ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.384 sec
Results :
Failed tests:
  testGetFeature(org.geoserver.test.DataAccessIntegrationWfsTest)
  testGetFeatureContent(org.geoserver.test.DataAccessIntegrationWfsTest)
  testDescribeFeatureType(org.geoserver.test.DataAccessIntegrationWfsTest)
  testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
  testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
  testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
  testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
  testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
  testGetCapabilities(org.geoserver.test.DuplicatePropertiesWfsTest)
  testGetFeature(org.geoserver.test.DuplicatePropertiesWfsTest)
  testGetCapabilities(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeature(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
  testDescribeFeatureType(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeatureWithMappingName(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeaturePropertyFilter(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeatureWithFeatureIdFilter(org.geoserver.test.FeatureChainingWfsTest)
  testGetFeatureWithGmlObjectIdFilter(org.geoserver.test.FeatureChainingWfsTest)
  testAnyType(org.geoserver.test.FeatureChainingWfsTest)
  testFilteringXlinkHref(org.geoserver.test.FeatureChainingWfsTest)
  testFilteringNestedMultiValuedAttribute(org.geoserver.test.FeatureChainingWfsTest)
  testDenormalisedFeaturesCount(org.geoserver.test.FeatureChainingWfsTest)
  testEncodeFeatureMember(org.geoserver.test.FeatureChainingWfsTest)
  testEncodeFeatureMembers(org.geoserver.test.FeatureChainingWfsTest)
  testPropertyEncodingOrder_PlanarOrientation(org.geoserver.test.PropertyEncodingOrderTest)
  testPropertyEncodingOrder_GeoLogicUnit(org.geoserver.test.PropertyEncodingOrderTest)
Tests run: 42, Failures: 26, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 8 minutes 30 seconds
[INFO] Finished at: Mon Jul 19 15:10:14 EDT 2010
[INFO] Final Memory: 51M/147M
