See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/649/>
[...truncated 23431 lines...]
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.getTargetDescriptor(AppSchemaDataAccessConfigurator.java:231)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.createFeatureTypeMappings(AppSchemaDataAccessConfigurator.java:204)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:184)
at org.geotools.data.complex.config.AppSchemaDataAccessConfigurator.buildMappings(AppSchemaDataAccessConfigurator.java:158)
at org.geotools.data.complex.AppSchemaDataAccessFactory.createDataStore(AppSchemaDataAccessFactory.java:93)
at org.vfny.geoserver.util.DataStoreUtils.getDataAccess(DataStoreUtils.java:96)
at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:318)
... 74 more
Aug 17, 2010 6:12:34 AM org.geoserver.test.SRSReprojectionTest testChainingReprojection
INFO: WFS GetFeature&typename=ex:geomContainer response:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd">
<ows:Exception exceptionCode="NoApplicableCode">
<ows:ExceptionText>Error occurred getting features
null
null</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.174 sec <<< FAILURE!
Running org.geoserver.test.SRSWfsTest
Aug 17, 2010 6:12:35 AM org.geoserver.test.SRSWfsTest testGetFeatureContent
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-08-17T06:12:35.083Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0" xmlns:ows="http://www.opengis.net/ows"
xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1" xmlns:wfs="http://www.opengis.net/wfs"
xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://example.com <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/app-schema-mock568453583629826188data/featureTypes/ex_geomContainer/NestedGeometry.xsd> http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<ex:geomContainer gml:id="1">
<ex:geom>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.2 52.5 -1.2 52.6 -1.1 52.6 -1.1 52.5 -1.2 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.2">
<ex:geom>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4283">
<gml:pos>42.58 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</gml:featureMember>
<gml:featureMember>
<ex:geomContainer gml:id="2">
<ex:geom>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:nestedGeom gml:id="nested.1">
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
</wfs:FeatureCollection>
Aug 17, 2010 6:12:35 AM org.geoserver.test.SRSWfsTest testReproject
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326 response:
<wfs:FeatureCollection numberOfFeatures="2" timeStamp="2010-08-17T06:12:35.161Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:geom>
<gml:Polygon srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:exterior>
<gml:LinearRing>
<gml:posList>-1.1999999999634965 52.5 -1.1999999999634965 52.6 -1.099999999966089 52.59999999999999 -1.099999999966089 52.5 -1.1999999999634965 52.5</gml:posList>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
<gml:pos>42.58000004047607 31.29</gml:pos>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
<gml:featureMember>
<ex:geom>
</gml:Point>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Aug 17, 2010 6:12:35 AM org.geoserver.test.SRSWfsTest testFilters
INFO: WFS GetFeature&typename=ex:geomContainer&srsname=urn:x-ogc:def:crs:EPSG::4326&featureid=1response:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-17T06:12:35.213Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml"
<gml:featureMember>
<ex:geom>
<gml:exterior>
<gml:LinearRing>
</gml:LinearRing>
</gml:exterior>
</gml:Polygon>
</ex:geom>
<ex:nestedFeature>
<ex:geom>
</gml:Point>
</ex:geom>
</ex:nestedGeom>
</ex:nestedFeature>
</ex:geomContainer>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.277 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Aug 17, 2010 6:12:39 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_PlanarOrientation
INFO: WFS GetFeature&er:MineralOccurrence:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-17T06:12:39.481Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
xmlns:gml="http://www.opengis.net/gml" xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc" xmlns:om="http://www.opengis.net/om/1.0"
xmlns:ows="http://www.opengis.net/ows" xmlns:sa="http://www.opengis.net/sampling/1.0" xmlns:sml="http://www.opengis.net/sensorML/1.0.1" xmlns:swe="http://www.opengis.net/swe/1.0.1"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:cgi:xmlns:GGIC:EarthResource:1.1 http://www.earthresourceml.org/earthresourceml/1.1/xsd/earthResource.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<er:MineralOccurrence gml:id="er.mineraloccurrence.S0032895">
<gml:name>Robinson Range - Deposit D</gml:name>
<er:planarOrientation>
<gsml:CGI_PlanarOrientation>
<gsml:convention>strike dip right hand rule</gsml:convention>
<gsml:azimuth>
<gsml:CGI_NumericValue>
<gsml:principalValue uom="urn:ogc:def:uom:UCUM::deg">50.0</gsml:principalValue>
</gsml:CGI_NumericValue>
</gsml:azimuth>
<gsml:dip>
<gsml:CGI_TermValue>
<gsml:value codeSpace="http://www.dmp.wa.gov.au/371.aspx">60\-80</gsml:value>
</gsml:CGI_TermValue>
</gsml:dip>
<gsml:polarity>not applicable</gsml:polarity>
</gsml:CGI_PlanarOrientation>
</er:planarOrientation>
</er:MineralOccurrence>
Aug 17, 2010 6:12:43 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeologicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-08-17T06:12:43.731Z" xmlns:cv="http://www.opengis.net/cv/0.2.1" xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
xmlns:wfs="http://www.opengis.net/wfs" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd">
<gml:featureMember>
<gsml:GeologicUnit gml:id="gu.25699">
<gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
<gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
<gml:name>-Py</gml:name>
<gsml:occurrence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
<gsml:exposureColor>
<gsml:value codeSpace="some:uri">Blue</gsml:value>
</gsml:exposureColor>
<gsml:outcropCharacter>
<gsml:value codeSpace="some:uri">x</gsml:value>
</gsml:outcropCharacter>
<gsml:composition>
<gsml:CompositionPart>
<gsml:role>interbedded component</gsml:role>
<gsml:proportion>
<gsml:value codeSpace="some:uri">significant</gsml:value>
</gsml:proportion>
</gsml:CompositionPart>
</gsml:composition>
</gsml:GeologicUnit>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.565 sec
Results :
Failed tests:
testChainingReprojection(org.geoserver.test.SRSReprojectionTest)
Tests run: 47, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports> for the individual test results.
[INFO] Total time: 9 minutes 22 seconds
[INFO] Finished at: Tue Aug 17 06:12:43 UTC 2010
[INFO] Final Memory: 62M/230M
