[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x #705
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/705/changes&gt;
Changes:
[NielsCharlier] Reverse back to revision 14992
[...truncated 24990 lines...]
            </gsml:shape>
        </gsml:MappedFeature>
    </gml:featureMember>
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf3">
            <gsml:shape>
                <gml:Point srsDimension="2" srsName="urn:x-ogc:def:crs:EPSG:4326">
                    <gml:pos>-12.1883 96.8339</gml:pos>
                </gml:Point>
            </gsml:shape>
    <gml:featureMember>
        <gsml:MappedFeature gml:id="gsml.mappedfeature.mf4">
            <gsml:shape>
                    <gml:pos>-34.9502 117.8102</gml:pos>
                </gml:Point>
            </gsml:shape>
</wfs:FeatureCollection>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.328 sec
Running org.geoserver.test.PropertyEncodingOrderTest
Oct 20, 2010 3:51:58 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_Borehole
INFO: WFS GetFeature&gsml:Borehole:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-10-20T03:51:58.572Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:gsml="urn:cgi:xmlns:CGI:GeoSciML:2.0" xmlns:ogc="http://www.opengis.net/ogc&quot; xmlns:om="http://www.opengis.net/om/1.0&quot;
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:sa="http://www.opengis.net/sampling/1.0&quot; xmlns:sml="http://www.opengis.net/sensorML/1.0.1&quot; xmlns:swe="http://www.opengis.net/swe/1.0.1&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns:xlink="http://www.w3.org/1999/xlink&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="urn:cgi:xmlns:CGI:GeoSciML:2.0 http://www.geosciml.org/geosciml/2.0/xsd/geosciml.xsd http://www.opengis.net/wfs http://schemas.opengis.net/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMember>
        <gsml:Borehole gml:id="BOREHOLE.WTB5">
            <gml:name>WTB5 TEST</gml:name>
            <sa:sampledFeature xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot; xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/GeologicUnit/GeologicUnit.html&quot; xlink:title="unknown"/>
            <sa:shape>
                <gml:LineString>
                    <gml:posList>-28.4139 121.142 -28.4139 121.142</gml:posList>
                </gml:LineString>
            </sa:shape>
            <gsml:collarLocation>
                <gsml:BoreholeCollar gml:id="BOREHOLE.COLLAR.WTB5">
                    <gsml:location>
                        <gml:Point>
                            <gml:pos>-28.4139 121.142</gml:pos>
                        </gml:Point>
                    </gsml:location>
                    <gsml:elevation axisLabels="Gravity-related height" srsDimension="1" srsName="http://www.opengis.net/gml/srs/epsg.xml#5711&quot; uomLabels="m">1.0</gsml:elevation>
                </gsml:BoreholeCollar>
            </gsml:collarLocation>
            <gsml:indexData>
                <gsml:BoreholeDetails>
                    <gsml:operator xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot; xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/Borehole/BoreholeDetails.html#operator&quot; xlink:title="GSWA"/>
                    <gsml:dateOfDrilling>2004-09-17</gsml:dateOfDrilling>
                    <gsml:drillingMethod>diamond core</gsml:drillingMethod>
                    <gsml:startPoint>natural ground surface</gsml:startPoint>
                    <gsml:inclinationType>vertical</gsml:inclinationType>
                    <gsml:coredInterval>
                        <gml:Envelope axisLabels="core envelope" srsDimension="1" srsName="#BOREHOLE.WTB5.LINESTRING" uomLabels="m">
                            <gml:lowerCorner>106.0</gml:lowerCorner>
                            <gml:upperCorner>249.0</gml:upperCorner>
                        </gml:Envelope>
                    </gsml:coredInterval>
                    <gsml:coreCustodian xlink:href="http://www.opengis.net/def/nil/OGC/0/unknown&quot;
                        xlink:role="http://www.geosciml.org/geosciml/2.0/doc/GeoSciML/Borehole/BoreholeDetails.html#coreCustodian&quot; xlink:title="CSIRONR"/>
                </gsml:BoreholeDetails>
            </gsml:indexData>
        </gsml:Borehole>
20 Oct 03:51:58 ERROR [geoserver.ows] -
java.lang.RuntimeException: Error applying mapping with targetAttribute er:planarOrientation
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:722)
  at org.geotools.data.complex.AbstractMappingFeatureIterator.next(AbstractMappingFeatureIterator.java:188)
  at org.geotools.data.complex.MappingFeatureCollection.size(MappingFeatureCollection.java:300)
  at org.geoserver.wfs.GetFeature.run(GetFeature.java:371)
  at org.geoserver.wfs.DefaultWebFeatureService.getFeature(DefaultWebFeatureService.java:115)
  at sun.reflect.GeneratedMethodAccessor88.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy10.getFeature(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor87.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:599)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:230)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1095)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1055)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:474)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:455)
  at org.geoserver.test.AbstractAppSchemaWfsTestSupport.get(AbstractAppSchemaWfsTestSupport.java:147)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:729)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:691)
  at org.geoserver.test.AbstractAppSchemaWfsTestSupport.getAsDOM(AbstractAppSchemaWfsTestSupport.java:165)
  at org.geoserver.test.PropertyEncodingOrderTest.testPropertyEncodingOrder_PlanarOrientation(PropertyEncodingOrderTest.java:124)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:130)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
Caused by: java.lang.RuntimeException: Error applying mapping with targetAttribute gsml:dip
  at org.geotools.data.complex.NestedAttributeMapping.getFeatures(NestedAttributeMapping.java:284)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:354)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:716)
  ... 70 more
Caused by: java.lang.IllegalArgumentException: Filter Function problem for function if_then_else argument #0 - expected type boolean
  at org.geotools.filter.function.FilterFunction_if_then_else.evaluate(FilterFunction_if_then_else.java:45)
  at org.geotools.data.complex.NestedAttributeMapping.getNestedFeatureType(NestedAttributeMapping.java:315)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.setAttributeValue(DataAccessMappingFeatureIterator.java:299)
  at org.geotools.data.complex.DataAccessMappingFeatureIterator.computeNext(DataAccessMappingFeatureIterator.java:719)
  ... 74 more
Oct 20, 2010 3:51:58 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_PlanarOrientation
INFO: WFS GetFeature&er:MineralOccurrence:
<ows:ExceptionReport version="1.0.0" xmlns:ows="http://www.opengis.net/ows&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
    <ows:Exception exceptionCode="NoApplicableCode">
        <ows:ExceptionText>java.lang.RuntimeException: Error applying mapping with targetAttribute er:planarOrientation
Filter Function problem for function if_then_else argument #0 - expected type boolean</ows:ExceptionText>
    </ows:Exception>
</ows:ExceptionReport>
Oct 20, 2010 3:51:58 AM org.geoserver.test.PropertyEncodingOrderTest testPropertyEncodingOrder_GeologicUnit
INFO: WFS GetFeature&typename=gsml:GeologicUnit&featureid=gu.25699:
<wfs:FeatureCollection numberOfFeatures="1" timeStamp="2010-10-20T03:51:58.871Z" xmlns:cv="http://www.opengis.net/cv/0.2.1&quot; xmlns:er="urn:cgi:xmlns:GGIC:EarthResource:1.1"
    <gml:featureMember>
        <gsml:GeologicUnit gml:id="gu.25699">
            <gml:description>Olivine basalt, tuff, microgabbro, minor sedimentary rocks</gml:description>
            <gml:name codeSpace="urn:ietf:rfc:2141">Yaugher Volcanic Group</gml:name>
            <gml:name>-Py</gml:name>
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value codeSpace="http://urn.opengis.net">urn:ogc:def:nil:OGC::missing</gsml:value>
                </gsml:CGI_TermValue>
            </gsml:observationMethod>
            <gsml:purpose>instance</gsml:purpose>
            <gsml:occurrence xlink:href="urn:cgi:feature:MappedFeature:mf1"/>
            <gsml:geologicUnitType xlink:href="urn:ogc:def:nil:OGC::unknown"/>
            <gsml:exposureColor>
                    <gsml:value codeSpace="some:uri">Blue</gsml:value>
            </gsml:exposureColor>
            <gsml:outcropCharacter>
                    <gsml:value codeSpace="some:uri">x</gsml:value>
            </gsml:outcropCharacter>
            <gsml:composition>
                <gsml:CompositionPart>
                    <gsml:role codeSpace="urn:cgi:classifierScheme:Example:CompositionPartRole">fictitious component</gsml:role>
                    <gsml:lithology>
                        <gsml:ControlledConcept gml:id="cc.5">
                            <gml:name>name_cc_5</gml:name>
                            <gsml:name xml:lang="en">name_cc_5</gsml:name>
                            <gsml:vocabulary xlink:href="urn:ogc:def:nil:OGC::missing"/>
                        </gsml:ControlledConcept>
                    </gsml:lithology>
                    <gsml:proportion>
                            <gsml:value codeSpace="some:uri">nonexistent</gsml:value>
                    </gsml:proportion>
                </gsml:CompositionPart>
            </gsml:composition>
        </gsml:GeologicUnit>
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 5.255 sec <<< FAILURE!
Results :
Failed tests:
  testPolymorphism(org.geoserver.test.PolymorphismWfsTest)
  testFirstValueFilters(org.geoserver.test.PolymorphismWfsTest)
  testSecondValueFilters(org.geoserver.test.PolymorphismWfsTest)
  testAnyTypeFilters(org.geoserver.test.PolymorphismWfsTest)
  testMappingNameFilters(org.geoserver.test.PolymorphismWfsTest)
  testPropertyEncodingOrder_PlanarOrientation(org.geoserver.test.PropertyEncodingOrderTest)
Tests run: 52, Failures: 6, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/extension/app-schema/app-schema-test/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 6 minutes 26 seconds
[INFO] Finished at: Wed Oct 20 03:51:59 UTC 2010
[INFO] Final Memory: 63M/282M
Failed to send e-mail to NielsCharlier because no e-mail address is known, and no default e-mail domain is configured
Hmmm I did make the (roll-back) changes to both geoserver and geotools right after each other, but this build still uses the new geoserver revision with the old geotools revision. The problem should be resolved with next build.
Niels Charlier
Software Engineer
CSIRO Earth Science and Resource Engineering
Phone: +61 8 6436 8914
Australian Resources Research Centre
26 Dick Perry Avenue, Kensington WA 6151
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/706/changes&gt;
