See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/765/changes>
Changes:
[jdeolive] GEOS-4325, restoring ability to set proxy base url from web.xml
[...truncated 218 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT.jar>
Downloading: http://repo.opengeo.org//org/geotools/gt-metadata/2.6-SNAPSHOT/gt-metadata-2.6-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.0.3-SNAPSHOT/geoserver-archetype-webplugin-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.0.3-SNAPSHOT/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/webPlugin/target/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-webplugin/2.0.3-SNAPSHOT/geoserver-archetype-webplugin-2.0.3-SNAPSHOT-sources.jar
[INFO] Building GeoServer WFS Output Format Archetype
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/src/main/java>
[INFO] Copying 5 resources
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/src/test/java>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/maven/archetype/wfsOutputFormat/target/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/maven/geoserver-archetype-wfsoutputformat/2.0.3-SNAPSHOT/geoserver-archetype-wfsoutputformat-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Core Platform Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/src/main/resources>
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/classes>
[INFO] Copying 1 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/surefire-reports>
T E S T S
Running org.geoserver.platform.GeoServerExtensionsTest
Jan 28, 2011 5:57:59 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.126 sec
Results :
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/platform/target/platform-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target>
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/src/main/resources>
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.ows:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:ogc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:ogc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:org.w3.xlink:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-ows:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:xsd:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:xsd:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:extension:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/classes>
[INFO] Copying 4 resources
[INFO] Compiling 16 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/surefire-reports>
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.context.support.FileSystemXmlApplicationContext).
log4j:WARN Please initialize the log4j system properly.
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.641 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.211 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.091 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.019 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests run: 23, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/ows/target/ows-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target>
[INFO] Copying 28 resources
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 240 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x/ws/geoserver-2.0.x/main/src/main/java/org/geoserver/ows/ProxifyingURLMangler.java>:\[27,46\] cannot find symbol
symbol : method getProperty(java.lang.String)
location: class org.geoserver.platform.GeoServerExtensions
[INFO] Total time: 32 seconds
[INFO] Finished at: Fri Jan 28 17:58:18 UTC 2011
[INFO] Final Memory: 46M/210M
