[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x-deploy #127
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/127/&gt;
[...truncated 15488 lines...]
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2318955/?
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/restconfig/2.0.2-SNAPSHOT/restconfig-2.0.2-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55075/?
[INFO] Building Feature Generalization Extension
[INFO] task-segment: [deploy]
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT-sources.jar
[INFO] [deploy:deploy]
altDeploymentRepository = null
[INFO] repository metadata for: 'snapshot org.geoserver.extension:feature-pregeneralized:2.0.2-SNAPSHOT' could not be found on repository: opengeo, so will be created
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT.jar
4096/?
4547/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:feature-pregeneralized:2.0.2-SNAPSHOT'
[INFO] Uploading project information for feature-pregeneralized 2.0.2-SNAPSHOT
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:feature-pregeneralized'
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT-tests.jar
1774/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.2-SNAPSHOT/feature-pregeneralized-2.0.2-SNAPSHOT-sources.jar
2943/?
[INFO] Building Image Mosaic JDBC Extension
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.2-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.2-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.2-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.2-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT-sources.jar
[INFO] repository metadata for: 'snapshot org.geoserver.extension:imagemosaic-jdbc:2.0.2-SNAPSHOT' could not be found on repository: opengeo, so will be created
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT.jar
1680/?
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:imagemosaic-jdbc:2.0.2-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:imagemosaic-jdbc'
[INFO] Uploading project information for imagemosaic-jdbc 2.0.2-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT-tests.jar
1680/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.2-SNAPSHOT/imagemosaic-jdbc-2.0.2-SNAPSHOT-sources.jar
327/?
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [8.189s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.727s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [4.848s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.860s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [3.007s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.948s]
[INFO] Core Platform Module .................................. SUCCESS [2.498s]
[INFO] Open Web Service Module ............................... SUCCESS [6.268s]
[INFO] Main Module ........................................... SUCCESS
[INFO] Web Coverage Service Module ........................... SUCCESS [7.636s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [4.318s]
[INFO] Web Feature Service Module ............................ SUCCESS [3.906s]
[INFO] Web Map Service Module ................................ SUCCESS [5.916s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.859s]
[INFO] REST Support Module ................................... SUCCESS [2.669s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.498s]
[INFO] Core UI Module ........................................ SUCCESS [5.348s]
[INFO] WMS UI Module ......................................... SUCCESS [4.027s]
[INFO] GWC UI Module ......................................... SUCCESS
[INFO] WFS UI Module ......................................... SUCCESS [3.267s]
[INFO] WCS UI Module ......................................... SUCCESS [3.588s]
[INFO] Demoes Module ......................................... SUCCESS [0.846s]
[INFO] Security UI Module .................................... SUCCESS [3.469s]
[INFO] Community Space ....................................... SUCCESS [1.497s]
[INFO] Printing Module ....................................... SUCCESS [10.756s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [4.695s]
[INFO] GeoServer Web Application ............................. SUCCESS [20.160s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.560s]
[INFO] Application Schema Support ............................ SUCCESS [2.468s]
[INFO] Application Schema Integration Test ................... SUCCESS [3.806s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [3.479s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [6.276s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.430s]
[INFO] H2 DataStore Extension ................................ SUCCESS [3.297s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [3.097s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [3.109s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [3.098s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [3.828s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [3.137s]
[INFO] ImageMap Output Format ................................ SUCCESS [3.588s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [3.139s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [3.178s]
[INFO] Excel Output Format ................................... SUCCESS [4.157s]
[INFO] Validation Module ..................................... SUCCESS [3.027s]
[INFO] Chart external graphics support ....................... SUCCESS [3.729s]
[INFO] REST Configuration Service Module ..................... SUCCESS [3.907s]
[INFO] Feature Generalization Extension ...................... SUCCESS [3.319s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [3.098s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 2 minutes 29 seconds
[INFO] Finished at: Mon Dec 21 00:49:53 EST 2009
[INFO] Final Memory: 55M/137M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson35528.sh
+ VER=2.0.1-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.0.1-SNAPSHOT.jar
md5sum: web-app-2.0.1-SNAPSHOT.jar: No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/128/&gt;
[...truncated 15393 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2318956/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55075/?
[INFO] [jar:jar]
4096/?
4547/?
1774/?
2943/?
[INFO] [jar:jar]
1680/?
1680/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [8.723s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.840s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [10.743s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.888s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [3.069s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.939s]
[INFO] Core Platform Module .................................. SUCCESS [2.668s]
[INFO] Open Web Service Module ............................... SUCCESS [6.396s]
[INFO] Main Module ........................................... SUCCESS [9.095s]
[INFO] Web Coverage Service Module ........................... SUCCESS [4.289s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [4.406s]
[INFO] Web Feature Service Module ............................ SUCCESS [3.757s]
[INFO] Web Map Service Module ................................ SUCCESS [5.759s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.776s]
[INFO] REST Support Module ................................... SUCCESS [2.740s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.537s]
[INFO] Core UI Module ........................................ SUCCESS [5.058s]
[INFO] WMS UI Module ......................................... SUCCESS [4.078s]
[INFO] GWC UI Module ......................................... SUCCESS [3.188s]
[INFO] WFS UI Module ......................................... SUCCESS [9.087s]
[INFO] WCS UI Module ......................................... SUCCESS [3.522s]
[INFO] Demoes Module ......................................... SUCCESS [3.687s]
[INFO] Security UI Module .................................... SUCCESS [3.429s]
[INFO] Community Space ....................................... SUCCESS [1.578s]
[INFO] Printing Module ....................................... SUCCESS [4.869s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [4.777s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.609s]
[INFO] Application Schema Support ............................ SUCCESS [2.429s]
[INFO] Application Schema Integration Test ................... SUCCESS [3.298s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [3.977s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [8.465s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.527s]
[INFO] H2 DataStore Extension ................................ SUCCESS [3.329s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [3.246s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [3.150s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [3.138s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [3.226s]
[INFO] ImageMap Output Format ................................ SUCCESS [0.568s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [3.158s]
[INFO] Excel Output Format ................................... SUCCESS [3.459s]
[INFO] Validation Module ..................................... SUCCESS [3.058s]
[INFO] Chart external graphics support ....................... SUCCESS [3.839s]
[INFO] REST Configuration Service Module ..................... SUCCESS [9.304s]
[INFO] Feature Generalization Extension ...................... SUCCESS [3.337s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [3.138s]
[INFO] Total time: 2 minutes 38 seconds
[INFO] Finished at: Mon Dec 21 04:36:34 EST 2009
[INFO] Final Memory: 54M/139M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson35554.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/129/&gt;
