[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x-deploy #383
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/383/&gt;
[...truncated 15791 lines...]
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319242/?
[INFO] Retrieving previous build number from opengeo
Uploading: http://repo.opengeo.org/org/geoserver/extension/restconfig/2.0.3-SNAPSHOT/restconfig-2.0.3-SNAPSHOT-sources.jar
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55173/?
[INFO] Building Feature Generalization Extension
[INFO] task-segment: [deploy]
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/feature-pregeneralized/target/feature-pregeneralized-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT-sources.jar
[INFO] [deploy:deploy]
altDeploymentRepository = null
[INFO] repository metadata for: 'snapshot org.geoserver.extension:feature-pregeneralized:2.0.3-SNAPSHOT' could not be found on repository: opengeo, so will be created
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT.jar
4096/?
5185/?
[INFO] Retrieving previous metadata from opengeo
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:feature-pregeneralized:2.0.3-SNAPSHOT'
[INFO] Uploading project information for feature-pregeneralized 2.0.3-SNAPSHOT
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:feature-pregeneralized'
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT-tests.jar
1775/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/feature-pregeneralized/2.0.3-SNAPSHOT/feature-pregeneralized-2.0.3-SNAPSHOT-sources.jar
3265/?
[INFO] Building Image Mosaic JDBC Extension
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT-sources.jar
[INFO] repository metadata for: 'snapshot org.geoserver.extension:imagemosaic-jdbc:2.0.3-SNAPSHOT' could not be found on repository: opengeo, so will be created
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT.jar
1681/?
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.extension:imagemosaic-jdbc:2.0.3-SNAPSHOT'
[INFO] Uploading repository metadata for: 'artifact org.geoserver.extension:imagemosaic-jdbc'
[INFO] Uploading project information for imagemosaic-jdbc 2.0.3-SNAPSHOT
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT-tests.jar
1681/?
Uploading: http://repo.opengeo.org/org/geoserver/extension/imagemosaic-jdbc/2.0.3-SNAPSHOT/imagemosaic-jdbc-2.0.3-SNAPSHOT-sources.jar
327/?
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [5.978s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.547s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.848s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.488s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [2.572s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.676s]
[INFO] Core Platform Module .................................. SUCCESS [2.172s]
[INFO] Open Web Service Module ............................... SUCCESS [10.150s]
[INFO] Main Module ........................................... SUCCESS [12.097s]
[INFO] Web Coverage Service Module ........................... SUCCESS [7.233s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [4.158s]
[INFO] Web Feature Service Module ............................ SUCCESS [4.670s]
[INFO] Web Map Service Module ................................ SUCCESS [5.112s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.496s]
[INFO] REST Support Module ................................... SUCCESS [3.051s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.158s]
[INFO] Core UI Module ........................................ SUCCESS [4.761s]
[INFO] WMS UI Module ......................................... SUCCESS [3.172s]
[INFO] GWC UI Module ......................................... SUCCESS [2.610s]
[INFO] WFS UI Module ......................................... SUCCESS [2.608s]
[INFO] WCS UI Module ......................................... SUCCESS [2.849s]
[INFO] Demoes Module ......................................... SUCCESS [3.338s]
[INFO] Security UI Module .................................... SUCCESS [7.543s]
[INFO] Community Space ....................................... SUCCESS [1.179s]
[INFO] Printing Module ....................................... SUCCESS [3.639s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [3.671s]
[INFO] GeoServer Web Application ............................. SUCCESS [25.760s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.209s]
[INFO] Application Schema Support ............................ SUCCESS [1.767s]
[INFO] Application Schema Integration Test ................... SUCCESS [3.226s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [3.488s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [3.240s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.182s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.623s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [2.397s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [2.375s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.414s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [2.783s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.323s]
[INFO] ImageMap Output Format ................................ SUCCESS [2.872s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.457s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [2.485s]
[INFO] Excel Output Format ................................... SUCCESS [2.940s]
[INFO] Validation Module ..................................... SUCCESS [6.783s]
[INFO] Chart external graphics support ....................... SUCCESS [2.804s]
[INFO] REST Configuration Service Module ..................... SUCCESS [3.008s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.542s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [2.376s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 3 minutes 14 seconds
[INFO] Finished at: Thu May 20 02:27:05 EDT 2010
[INFO] Final Memory: 56M/145M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson86253.sh
+ VER=2.0.2-SNAPSHOT
+ cd web/app/target
+ md5sum web-app-2.0.2-SNAPSHOT.jar
md5sum: web-app-2.0.2-SNAPSHOT.jar: No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/384/&gt;
[...truncated 15642 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319244/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55173/?
[INFO] [jar:jar]
4096/?
5185/?
1775/?
3265/?
[INFO] [jar:jar]
1682/?
1682/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [6.797s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.482s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.969s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.511s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [2.638s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.662s]
[INFO] Core Platform Module .................................. SUCCESS [2.240s]
[INFO] Open Web Service Module ............................... SUCCESS [5.315s]
[INFO] Main Module ........................................... SUCCESS [14.745s]
[INFO] Web Coverage Service Module ........................... SUCCESS [8.728s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [4.441s]
[INFO] Web Feature Service Module ............................ SUCCESS [4.852s]
[INFO] Web Map Service Module ................................ SUCCESS [6.850s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [3.699s]
[INFO] REST Support Module ................................... SUCCESS [2.677s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.240s]
[INFO] Core UI Module ........................................ SUCCESS [7.122s]
[INFO] WMS UI Module ......................................... SUCCESS [3.398s]
[INFO] GWC UI Module ......................................... SUCCESS [2.699s]
[INFO] WFS UI Module ......................................... SUCCESS [2.879s]
[INFO] WCS UI Module ......................................... SUCCESS [2.985s]
[INFO] Demoes Module ......................................... SUCCESS [3.678s]
[INFO] Security UI Module .................................... SUCCESS [9.064s]
[INFO] Community Space ....................................... SUCCESS [1.346s]
[INFO] Printing Module ....................................... SUCCESS [4.706s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [5.060s]
[INFO] GeoServer Web Application ............................. SUCCESS [32.031s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.376s]
[INFO] Application Schema Support ............................ SUCCESS [2.182s]
[INFO] Application Schema Integration Test ................... SUCCESS [4.871s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.948s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [4.714s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.188s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.970s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [6.518s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [2.439s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.466s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [3.557s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.489s]
[INFO] ImageMap Output Format ................................ SUCCESS [3.254s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.902s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [2.609s]
[INFO] Excel Output Format ................................... SUCCESS [2.857s]
[INFO] Validation Module ..................................... SUCCESS [2.556s]
[INFO] Chart external graphics support ....................... SUCCESS [2.918s]
[INFO] REST Configuration Service Module ..................... SUCCESS [4.277s]
[INFO] Feature Generalization Extension ...................... SUCCESS [7.534s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [2.489s]
[INFO] Total time: 3 minutes 44 seconds
[INFO] Finished at: Thu May 20 11:26:46 EDT 2010
[INFO] Final Memory: 54M/117M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson86861.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/385/&gt;
[...truncated 15660 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319243/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55173/?
[INFO] [jar:jar]
4096/?
5185/?
1775/?
3265/?
[INFO] [jar:jar]
1681/?
1681/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [6.406s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.458s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [4.081s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [2.609s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [3.857s]
[INFO] Core Platform Module .................................. SUCCESS [2.202s]
[INFO] Open Web Service Module ............................... SUCCESS [5.128s]
[INFO] Main Module ........................................... SUCCESS [19.331s]
[INFO] Web Coverage Service Module ........................... SUCCESS [4.563s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [4.421s]
[INFO] Web Feature Service Module ............................ SUCCESS [4.294s]
[INFO] Web Map Service Module ................................ SUCCESS [6.557s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.638s]
[INFO] REST Support Module ................................... SUCCESS [2.714s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.202s]
[INFO] Core UI Module ........................................ SUCCESS [9.699s]
[INFO] WMS UI Module ......................................... SUCCESS [3.399s]
[INFO] GWC UI Module ......................................... SUCCESS [7.390s]
[INFO] WFS UI Module ......................................... SUCCESS [2.759s]
[INFO] WCS UI Module ......................................... SUCCESS [3.030s]
[INFO] Demoes Module ......................................... SUCCESS [3.632s]
[INFO] Security UI Module .................................... SUCCESS [3.420s]
[INFO] Community Space ....................................... SUCCESS [1.217s]
[INFO] Printing Module ....................................... SUCCESS [3.751s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [4.000s]
[INFO] GeoServer Web Application ............................. SUCCESS [34.693s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.482s]
[INFO] Application Schema Support ............................ SUCCESS [2.494s]
[INFO] Application Schema Integration Test ................... SUCCESS [8.391s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.721s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [3.375s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.121s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.773s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [2.466s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [2.451s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.391s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [3.361s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.406s]
[INFO] ImageMap Output Format ................................ SUCCESS [3.127s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.473s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [2.939s]
[INFO] Excel Output Format ................................... SUCCESS [3.000s]
[INFO] Validation Module ..................................... SUCCESS [2.549s]
[INFO] Chart external graphics support ....................... SUCCESS [2.841s]
[INFO] REST Configuration Service Module ..................... SUCCESS [3.947s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.722s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [2.428s]
[INFO] Total time: 3 minutes 38 seconds
[INFO] Finished at: Fri May 21 02:32:30 EDT 2010
[INFO] Final Memory: 56M/143M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson86954.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/386/&gt;
[...truncated 15694 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319244/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55173/?
[INFO] [jar:jar]
4096/?
5186/?
1776/?
3265/?
[INFO] [jar:jar]
1681/?
1681/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [8.379s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [2.127s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [5.390s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.557s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [3.052s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [4.849s]
[INFO] Core Platform Module .................................. SUCCESS [11.237s]
[INFO] Open Web Service Module ............................... SUCCESS [8.177s]
[INFO] Main Module ........................................... SUCCESS [38.194s]
[INFO] Web Coverage Service Module ........................... SUCCESS [19.635s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [11.398s]
[INFO] Web Feature Service Module ............................ SUCCESS [16.232s]
[INFO] Web Map Service Module ................................ SUCCESS [20.857s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [6.537s]
[INFO] REST Support Module ................................... SUCCESS [10.022s]
[INFO] GeoServer Web Modules ................................. SUCCESS [2.277s]
[INFO] Core UI Module ........................................ SUCCESS [21.580s]
[INFO] WMS UI Module ......................................... SUCCESS [5.750s]
[INFO] GWC UI Module ......................................... SUCCESS [7.459s]
[INFO] WFS UI Module ......................................... SUCCESS [3.751s]
[INFO] WCS UI Module ......................................... SUCCESS [7.812s]
[INFO] Demoes Module ......................................... SUCCESS [5.458s]
[INFO] Security UI Module .................................... SUCCESS [14.152s]
[INFO] Community Space ....................................... SUCCESS [2.149s]
[INFO] Printing Module ....................................... SUCCESS [5.960s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [26.159s]
[INFO] GeoServer Web Application ............................. SUCCESS [2:28.422s]
[INFO] GeoServer Extensions .................................. SUCCESS [2.068s]
[INFO] Application Schema Support ............................ SUCCESS [5.149s]
[INFO] Application Schema Integration Test ................... SUCCESS [16.813s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [8.865s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [11.322s]
[INFO] GeoSearch Index Module ................................ SUCCESS [8.700s]
[INFO] H2 DataStore Extension ................................ SUCCESS [6.241s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [3.224s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [3.895s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [4.451s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [14.188s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [8.400s]
[INFO] ImageMap Output Format ................................ SUCCESS [18.488s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [10.744s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [12.459s]
[INFO] Excel Output Format ................................... SUCCESS [5.338s]
[INFO] Validation Module ..................................... SUCCESS [3.489s]
[INFO] Chart external graphics support ....................... SUCCESS [7.902s]
[INFO] REST Configuration Service Module ..................... SUCCESS [5.850s]
[INFO] Feature Generalization Extension ...................... SUCCESS [9.790s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [3.399s]
[INFO] Total time: 10 minutes 4 seconds
[INFO] Finished at: Fri May 21 05:09:30 EDT 2010
[INFO] Final Memory: 55M/130M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson86986.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/387/&gt;
[...truncated 15649 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319242/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55083/?
[INFO] [jar:jar]
4096/?
5184/?
1774/?
3265/?
[INFO] [jar:jar]
1681/?
1681/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [6.097s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [6.368s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.871s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [5.249s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.758s]
[INFO] Core Platform Module .................................. SUCCESS [2.421s]
[INFO] Open Web Service Module ............................... SUCCESS [6.006s]
[INFO] Main Module ........................................... SUCCESS [21.674s]
[INFO] Web Coverage Service Module ........................... SUCCESS [5.222s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [5.006s]
[INFO] Web Feature Service Module ............................ SUCCESS [6.610s]
[INFO] Web Map Service Module ................................ SUCCESS [7.744s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [4.489s]
[INFO] REST Support Module ................................... SUCCESS [2.884s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.241s]
[INFO] Core UI Module ........................................ SUCCESS [13.510s]
[INFO] WMS UI Module ......................................... SUCCESS [4.399s]
[INFO] GWC UI Module ......................................... SUCCESS [2.939s]
[INFO] WFS UI Module ......................................... SUCCESS [3.316s]
[INFO] WCS UI Module ......................................... SUCCESS [4.891s]
[INFO] Demoes Module ......................................... SUCCESS [5.010s]
[INFO] Security UI Module .................................... SUCCESS [5.173s]
[INFO] Community Space ....................................... SUCCESS [1.398s]
[INFO] Printing Module ....................................... SUCCESS [8.270s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [7.429s]
[INFO] GeoServer Web Application ............................. SUCCESS [59.122s]
[INFO] GeoServer Extensions .................................. SUCCESS [2.911s]
[INFO] Application Schema Support ............................ SUCCESS [2.329s]
[INFO] Application Schema Integration Test ................... SUCCESS [5.707s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [3.325s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [5.458s]
[INFO] GeoSearch Index Module ................................ SUCCESS [4.060s]
[INFO] H2 DataStore Extension ................................ SUCCESS [6.037s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [4.083s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [7.279s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [3.226s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [5.405s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.511s]
[INFO] ImageMap Output Format ................................ SUCCESS [4.496s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.571s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [4.143s]
[INFO] Excel Output Format ................................... SUCCESS [3.466s]
[INFO] Validation Module ..................................... SUCCESS [2.819s]
[INFO] Chart external graphics support ....................... SUCCESS [4.633s]
[INFO] REST Configuration Service Module ..................... SUCCESS [5.540s]
[INFO] Feature Generalization Extension ...................... SUCCESS [3.301s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [3.976s]
[INFO] Total time: 4 minutes 56 seconds
[INFO] Finished at: Fri May 21 12:15:11 EDT 2010
[INFO] Final Memory: 55M/139M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson87101.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/388/&gt;
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319243/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55083/?
[INFO] [jar:jar]
4096/?
5185/?
1775/?
3265/?
[INFO] [jar:jar]
1682/?
1682/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [6.016s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.404s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.842s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.458s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [2.390s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.270s]
[INFO] Core Platform Module .................................. SUCCESS [1.963s]
[INFO] Open Web Service Module ............................... SUCCESS [4.669s]
[INFO] Main Module ........................................... SUCCESS [10.639s]
[INFO] Web Coverage Service Module ........................... SUCCESS [3.429s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [3.322s]
[INFO] Web Feature Service Module ............................ SUCCESS [2.895s]
[INFO] Web Map Service Module ................................ SUCCESS [3.834s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.286s]
[INFO] REST Support Module ................................... SUCCESS [2.045s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.233s]
[INFO] Core UI Module ........................................ SUCCESS [3.894s]
[INFO] WMS UI Module ......................................... SUCCESS [3.097s]
[INFO] GWC UI Module ......................................... SUCCESS [2.730s]
[INFO] WFS UI Module ......................................... SUCCESS [6.188s]
[INFO] WCS UI Module ......................................... SUCCESS [2.693s]
[INFO] Demoes Module ......................................... SUCCESS [3.000s]
[INFO] Security UI Module .................................... SUCCESS [2.600s]
[INFO] Community Space ....................................... SUCCESS [1.181s]
[INFO] Printing Module ....................................... SUCCESS [3.518s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [3.517s]
[INFO] GeoServer Web Application ............................. SUCCESS [22.804s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.195s]
[INFO] Application Schema Support ............................ SUCCESS [1.789s]
[INFO] Application Schema Integration Test ................... SUCCESS [2.723s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.571s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [4.609s]
[INFO] GeoSearch Index Module ................................ SUCCESS [2.819s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.519s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [2.372s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [2.348s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.740s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [2.657s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.348s]
[INFO] ImageMap Output Format ................................ SUCCESS [2.701s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.393s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [2.394s]
[INFO] Excel Output Format ................................... SUCCESS [2.580s]
[INFO] Validation Module ..................................... SUCCESS [2.356s]
[INFO] Chart external graphics support ....................... SUCCESS [2.770s]
[INFO] REST Configuration Service Module ..................... SUCCESS [6.126s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.573s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [2.522s]
[INFO] Total time: 2 minutes 49 seconds
[INFO] Finished at: Sun May 23 06:00:55 EDT 2010
[INFO] Final Memory: 55M/152M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson87291.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/389/&gt;
[...truncated 15968 lines...]
2011136/?
2015232/?
2019328/?
2023424/?
2027520/?
2031616/?
2035712/?
2039808/?
2043904/?
2048000/?
2052096/?
2056192/?
2060288/?
2064384/?
2068480/?
2072576/?
2076672/?
2080768/?
2084864/?
2088960/?
2093056/?
2097152/?
2101248/?
2105344/?
2109440/?
2113536/?
2117632/?
2121728/?
2125824/?
2129920/?
2134016/?
2138112/?
2142208/?
2146304/?
2150400/?
2154496/?
2158592/?
2162688/?
2166784/?
2170880/?
2174976/?
2179072/?
2183168/?
2187264/?
2191360/?
2195456/?
2199552/?
2203648/?
2207744/?
2211840/?
2215936/?
2220032/?
2224128/?
2228224/?
2232320/?
2236416/?
2240512/?
2244608/?
2248704/?
2252800/?
2256896/?
2260992/?
2265088/?
2269184/?
2273280/?
2277376/?
2281472/?
2285568/?
2289664/?
2293760/?
2297856/?
2301952/?
2306048/?
2310144/?
2314240/?
2318336/?
2319243/?
4096/?
8192/?
12288/?
16384/?
20480/?
24576/?
28672/?
32768/?
36864/?
40960/?
45056/?
49152/?
53248/?
55083/?
[INFO] [jar:jar]
4096/?
5186/?
1776/?
3265/?
[INFO] [jar:jar]
1682/?
1682/?
327/?
[INFO]
[INFO]
[INFO] GeoServer ............................................. SUCCESS [6.403s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [1.447s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [3.984s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [1.535s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [2.601s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [2.751s]
[INFO] Core Platform Module .................................. SUCCESS [2.188s]
[INFO] Open Web Service Module ............................... SUCCESS [5.427s]
[INFO] Main Module ........................................... SUCCESS [17.360s]
[INFO] Web Coverage Service Module ........................... SUCCESS [3.955s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [5.452s]
[INFO] Web Feature Service Module ............................ SUCCESS [5.406s]
[INFO] Web Map Service Module ................................ SUCCESS [6.909s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [2.592s]
[INFO] REST Support Module ................................... SUCCESS [5.460s]
[INFO] GeoServer Web Modules ................................. SUCCESS [1.256s]
[INFO] Core UI Module ........................................ SUCCESS [7.575s]
[INFO] WMS UI Module ......................................... SUCCESS [3.651s]
[INFO] GWC UI Module ......................................... SUCCESS [2.806s]
[INFO] WFS UI Module ......................................... SUCCESS [2.732s]
[INFO] WCS UI Module ......................................... SUCCESS [3.062s]
[INFO] Demoes Module ......................................... SUCCESS [3.815s]
[INFO] Security UI Module .................................... SUCCESS [3.281s]
[INFO] Community Space ....................................... SUCCESS [1.227s]
[INFO] Printing Module ....................................... SUCCESS [3.959s]
[INFO] HTTP Proxy Extension .................................. SUCCESS [4.206s]
[INFO] GeoServer Web Application ............................. SUCCESS [38.180s]
[INFO] GeoServer Extensions .................................. SUCCESS [1.541s]
[INFO] Application Schema Support ............................ SUCCESS [1.850s]
[INFO] Application Schema Integration Test ................... SUCCESS [3.518s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.803s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [3.483s]
[INFO] GeoSearch Index Module ................................ SUCCESS [3.030s]
[INFO] H2 DataStore Extension ................................ SUCCESS [2.729s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [2.451s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [2.519s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [2.435s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [3.390s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [2.497s]
[INFO] ImageMap Output Format ................................ SUCCESS [3.158s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [2.482s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [2.690s]
[INFO] Excel Output Format ................................... SUCCESS [6.766s]
[INFO] Validation Module ..................................... SUCCESS [2.483s]
[INFO] Chart external graphics support ....................... SUCCESS [3.000s]
[INFO] REST Configuration Service Module ..................... SUCCESS [4.143s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.827s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [2.490s]
[INFO] Total time: 3 minutes 35 seconds
[INFO] Finished at: Sun May 23 15:22:21 EDT 2010
[INFO] Final Memory: 54M/144M
[geoserver-2.0.x] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson87340.sh
+ cd web/app/target
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/390/&gt;
