See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/589/>
[...truncated 4860 lines...]
62/42K
66/42K
70/42K
74/42K
78/42K
82/42K
84/42K
42K uploaded (web-security-2.0.3-SNAPSHOT-sources.jar)
[INFO] Building Community Space
[INFO] task-segment: [deploy]
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Preparing source:jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/target/community-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT-tests.jar
[INFO] [deploy:deploy {execution: default-deploy}]
[INFO] Retrieving previous build number from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a98fdcce2722f9329d92bb243cf237ca60267ac'; remote = '3141b6a9a7d35d3f9ffa8321505175f79ff06e38' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '0a98fdcce2722f9329d92bb243cf237ca60267ac'; remote = '3141b6a9a7d35d3f9ffa8321505175f79ff06e38' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT.pom
3/3K
6/3K
3K uploaded (community-2.0.3-SNAPSHOT.pom)
[INFO] Retrieving previous metadata from opengeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f31a60920706eb2a6bf1cb6bbede08969a26d881'; remote = '7d4595b58c4ac68e1ac99cdf3f7f422eab3449a5' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f31a60920706eb2a6bf1cb6bbede08969a26d881'; remote = '7d4595b58c4ac68e1ac99cdf3f7f422eab3449a5' - IGNORING
[INFO] Uploading repository metadata for: 'artifact org.geoserver:community'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver:community:2.0.3-SNAPSHOT'
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2d36371b4789572a7574a6ffd3c781e968ff88f9'; remote = 'e94f3a6cd2c4a41fb73789aea9d194de602dd300' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '2d36371b4789572a7574a6ffd3c781e968ff88f9'; remote = 'e94f3a6cd2c4a41fb73789aea9d194de602dd300' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT-tests.jar
1/1K
3/1K
1K uploaded (community-2.0.3-SNAPSHOT-tests.jar)
[INFO] Building Printing Module
[INFO] Copying 1 resource
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.pom
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-ows/2.6-SNAPSHOT/gt-xsd-ows-2.6-SNAPSHOT.jar
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/2.6-SNAPSHOT/gt-coverage-2.6-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-property/2.6-SNAPSHOT/gt-property-2.6-SNAPSHOT.jar
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 0 resource
[INFO] Tests are skipped.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/printing/target/printing-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/printing/target/printing-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/printing/target/printing-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/printing/target/printing-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-sources.jar
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7075c53d77e89272ab835e6de6251999f531562e'; remote = '0e833064de676552408ac508b5d8757a31e6f575' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '7075c53d77e89272ab835e6de6251999f531562e'; remote = '0e833064de676552408ac508b5d8757a31e6f575' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT.jar
4/5K
5/5K
9/5K
10/5K
5K uploaded (printing-2.0.3-SNAPSHOT.jar)
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f5e4e66c4c9f7965dcd6e6430eb68ac5f643803'; remote = 'caa09c9587bfaa59b9240ac7bd35976cb6c5fd95' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '6f5e4e66c4c9f7965dcd6e6430eb68ac5f643803'; remote = 'caa09c9587bfaa59b9240ac7bd35976cb6c5fd95' - IGNORING
[INFO] Uploading repository metadata for: 'artifact org.geoserver.community:printing'
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.community:printing:2.0.3-SNAPSHOT'
[INFO] Uploading project information for printing 2.0.3-SNAPSHOT
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'dee19c1f27e9c27d69ed9d8ecf3aec80483b4bcb'; remote = '51a4a2c7e118b06a60d25a6b87175a10c7cde577' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'dee19c1f27e9c27d69ed9d8ecf3aec80483b4bcb'; remote = '51a4a2c7e118b06a60d25a6b87175a10c7cde577' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-tests.jar
2/2K
5/2K
2K uploaded (printing-2.0.3-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-sources.jar
3/3K
7/3K
3K uploaded (printing-2.0.3-SNAPSHOT-sources.jar)
[INFO] Building HTTP Proxy Extension
[INFO] Copying 6 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/src/main/resources>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/src/test/java>
[INFO] No sources to compile
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/target/proxy-2.0.3-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/target/proxy-2.0.3-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/target/proxy-2.0.3-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/proxy/target/proxy-2.0.3-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT-sources.jar
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'a417be12407c624cf5e786fb6f6c6ed54b9ce7d5'; remote = '464b141ff96866a3f44684348983e10e781cc09a' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'a417be12407c624cf5e786fb6f6c6ed54b9ce7d5'; remote = '464b141ff96866a3f44684348983e10e781cc09a' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT.jar
4/27K
8/27K
12/27K
16/27K
20/27K
24/27K
27/27K
31/27K
35/27K
39/27K
43/27K
47/27K
51/27K
54/27K
27K uploaded (proxy-2.0.3-SNAPSHOT.jar)
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '96c194c2fe9064c25c6c674983b39846b184f04e'; remote = '529e58ea3e46848c04bc54dc4d76f07b85f3e775' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = '96c194c2fe9064c25c6c674983b39846b184f04e'; remote = '529e58ea3e46848c04bc54dc4d76f07b85f3e775' - IGNORING
[INFO] Uploading repository metadata for: 'artifact org.geoserver.community:proxy'
[INFO] Uploading project information for proxy 2.0.3-SNAPSHOT
[INFO] Uploading repository metadata for: 'snapshot org.geoserver.community:proxy:2.0.3-SNAPSHOT'
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'fcdd1ecc57142e3fc1d3f702163fef59424813e3'; remote = 'bd31b661832a22522271e759233def101052923b' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'fcdd1ecc57142e3fc1d3f702163fef59424813e3'; remote = 'bd31b661832a22522271e759233def101052923b' - IGNORING
Uploading: http://repo.opengeo.org/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT-tests.jar
1/1K
3/1K
1K uploaded (proxy-2.0.3-SNAPSHOT-tests.jar)
Uploading: http://repo.opengeo.org/org/geoserver/community/proxy/2.0.3-SNAPSHOT/proxy-2.0.3-SNAPSHOT-sources.jar
4/13K
8/13K
12/13K
13/13K
17/13K
21/13K
25/13K
27/13K
13K uploaded (proxy-2.0.3-SNAPSHOT-sources.jar)
[INFO] Building GeoServer Embedded FTP server
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/ftp/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-deploy/ws/community/ftp/src/main/java/org/geoserver/ftp/DefaultFTPCallback.java>:\[11,61\] package javax.xml.bind.annotation.adapters.XmlJavaTypeAdapter does not exist
[INFO] Total time: 38 seconds
[INFO] Finished at: Mon Nov 29 18:45:00 UTC 2010
[INFO] Final Memory: 56M/212M
