[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x-nightly #215
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/215/&gt;
[...truncated 325 lines...]
[INFO] [compiler:compile]
[INFO] Compiling 235 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/classes&gt;
[INFO] [resources:testResources]
[INFO] Copying 71 resources
[INFO] [compiler:testCompile]
[INFO] Compiling 53 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/main-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/main/2.0.3-SNAPSHOT/main-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service Module
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target&gt;
[INFO] [resources:resources]
[INFO] Copying 3 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/src/main/resources&gt;
[INFO] Compiling 37 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs/target/wcs-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs/2.0.3-SNAPSHOT/wcs-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Coverage Service 1.1 Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target&gt;
[INFO] [javacc:jjtree {execution: jjtree}]
Java Compiler Compiler Version 4.0 (Tree Builder)
(type "jjtree" with no arguments for help)
Warning: Output directory "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset&quot;&gt; does not exist. Creating the directory.
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset/rangeset.jjt&gt; . . .
Warning: Duplicate option setting for "VISITOR" will be ignored.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/Node.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/SimpleNode.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTRangeSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisSubset.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTFieldId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTAxisId.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTInterpolation.java&quot;&gt; does not exist. Will create one.
File "<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/ASTKey.java&quot;&gt; does not exist. Will create one.
Annotated grammar generated successfully in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt;
[INFO] [javacc:javacc {execution: javacc}]
Java Compiler Compiler Version 4.0 (Parser Generator)
(type "javacc" with no arguments for help)
Reading from file <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree/org/geoserver/wcs/kvp/rangesubset/rangeset.jj&gt; . . .
File "TokenMgrError.java" does not exist. Will create one.
File "ParseException.java" does not exist. Will create one.
File "Token.java" does not exist. Will create one.
File "SimpleCharStream.java" does not exist. Will create one.
Parser generated successfully.
[INFO] Copying 11 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/resources&gt;
[INFO] Compiling 53 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/classes&gt;
[INFO] Copying 1 resource
[INFO] Compiling 13 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/src/main/java/org/geoserver/wcs/kvp/rangesubset&gt; are up to date.
[INFO] Nothing to process - all grammars in <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/generated-sources/jjtree&gt; are up to date.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wcs1_1/target/wcs1_1-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wcs1_1/2.0.3-SNAPSHOT/wcs1_1-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target&gt;
[INFO] Copying 9 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/src/main/resources&gt;
[INFO] Compiling 170 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/classes&gt;
[INFO] Copying 14 resources
[INFO] Compiling 44 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wfs/target/wfs-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/wfs/2.0.3-SNAPSHOT/wfs-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/src/main/resources&gt;
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.JdkPrefixProfileActivator@anonymised.com
[INFO] snapshot org.geotools:gt-xml:2.6-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 151 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/wms/src/main/java/org/geoserver/wms/WMSLifecycleHandler.java&gt;:\[30,25\] cannot find symbol
symbol : method resetCache()
location: class org.geotools.renderer.style.SVGGraphicFactory
[INFO] Total time: 3 minutes 43 seconds
[INFO] Finished at: Fri May 28 05:12:55 EDT 2010
[INFO] Final Memory: 49M/132M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-05-28-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/216/changes&gt;
Changes:
[aaime] [GEOS-3985] RetypeDataStore does not properly handle the case of a feature type renamed to a target name that is also available the native name of another feature type
[aaime] [GEOS-3987] Clearing resource cache after adding a new store results in a NPE
[aaime] [GEOS-3988] Feature type reload warning dialog fails to display properly
[...truncated 272 lines...]
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/platform/target/platform-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/platform/2.0.3-SNAPSHOT/platform-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/src/main/resources&gt;
[INFO] Compiling 79 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/classes&gt;
[INFO] Copying 4 resources
[INFO] Compiling 16 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/ows/target/ows-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.0.3-SNAPSHOT/ows-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target&gt;
[INFO] Copying 28 resources
[INFO] Compiling 54 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/main/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] snapshot org.geotools:gt-render:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-svg:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wfs:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Total time: 1 minute 11 seconds
[INFO] Finished at: Sat May 29 05:04:52 EDT 2010
[INFO] Final Memory: 50M/149M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-05-29-bin.zip
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/217/&gt;
