[Geoserver-devel] Build failed in Hudson: geoserver-2.0.x-nightly #221
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/221/changes&gt;
Changes:
[bencaradocdavies] Fixed logic error that prevented reload of user settings [GEOS-3982]
[bencaradocdavies] GEOS-3982, Intermittent build failure in NewUserPageTest (backported trunk patch by aaime)
[aaime] Adding ftp community module
[aaime] [GEOS-3991] GeoServerUserDao introduces non obvious dependency loop
[...truncated 844 lines...]
[INFO] [clean:clean]
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target&gt;
[INFO] [config:clean {execution: configClean}]
clean:
   [delete] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/main/webapp/data&gt;
[INFO] [resources:resources]
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/main/resources&gt;
[INFO] [compiler:compile]
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/classes&gt;
[INFO] [resources:testResources]
[INFO] Copying 74 resources
[INFO] [compiler:testCompile]
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/test-classes&gt;
[INFO] [surefire:test]
[INFO] Tests are skipped.
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] [config:config {execution: configPackage}]
config:
     [echo] Copying data dir from <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/../../../data/release&gt;
     [copy] Copying 438 files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/main/webapp/data&gt;
     [copy] Copied 62 empty directories to 1 empty directory under <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/main/webapp/data&gt;
[INFO] [install:install]
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0.3-SNAPSHOT/web-app-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0.3-SNAPSHOT/web-app-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/web-app-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0.3-SNAPSHOT/web-app-2.0.3-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/geoserver\]>
[INFO] Processing war project
[INFO] Copying webapp resources[<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/main/webapp\]>
[INFO] Webapp assembled in[2075 msecs]
[INFO] Building war: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/target/geoserver.war&gt;
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/target&gt;
[INFO] [site:attach-descriptor]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/target/community-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/target/pom-transformed.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/target/community-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/2.0.3-SNAPSHOT/community-2.0.3-SNAPSHOT-tests.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/src/main/resources&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/classes&gt;
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/control-flow/2.0.3-SNAPSHOT/control-flow-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/control-flow/2.0.3-SNAPSHOT/control-flow-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/control-flow/target/control-flow-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/control-flow/2.0.3-SNAPSHOT/control-flow-2.0.3-SNAPSHOT-sources.jar
[INFO] Building GeoServer CSS Styling
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/src/main/java&gt;
[INFO] Copying 9 resources
[INFO] [scala:add-source {execution: scala-compile-first}]
[INFO] Add Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/src/main/scala&gt;
[INFO] Add Test Source directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/src/test/scala&gt;
[INFO] [scala:compile {execution: scala-compile-first}]
[INFO] Checking for multiple versions of scala
[INFO] includes = [**/*.scala,**/*.java,]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/src/main/scala&gt;:\-1: info: compiling
[INFO] Compiling 12 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/classes&gt; at 1275472370144
[INFO] prepare-compile in 0 s
[INFO] compile in 28 s
[INFO] Nothing to compile - all classes are up to date
[INFO] Copying 14 resources
[INFO] [scala:testCompile {execution: scala-test-compile}]
[INFO] excludes =
[INFO] <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/src/test/scala&gt;:\-1: info: compiling
[INFO] Compiling 9 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/test-classes&gt; at 1275472398851
[INFO] compile in 16 s
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.0.3-SNAPSHOT/css-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.0.3-SNAPSHOT/css-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/css/target/css-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/css/2.0.3-SNAPSHOT/css-2.0.3-SNAPSHOT-sources.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/classes&gt;
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/test-classes&gt;
[INFO] [jar:jar]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/printing/target/printing-2.0.3-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/community/printing/2.0.3-SNAPSHOT/printing-2.0.3-SNAPSHOT-sources.jar
[INFO] Building GeoServer Community Release Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/release/target&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/release/src/main/java&gt;
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/release/src/main/resources&gt;
[INFO] snapshot org.geoserver.community:ftp:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.community:ftp:2.0.3-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geoserver/community/ftp/2.0.3-SNAPSHOT/ftp-2.0.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:ftp:pom:2.0.3-SNAPSHOT’ in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/ftp/2.0.3-SNAPSHOT/ftp-2.0.3-SNAPSHOT.pom
[INFO] Unable to find resource 'org.geoserver.community:ftp:pom:2.0.3-SNAPSHOT’ in repository osgeo (http://download.osgeo.org/webdav/geotools/)
Downloading: http://repo.opengeo.org//org/geoserver/community/ftp/2.0.3-SNAPSHOT/ftp-2.0.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:ftp:jar:2.0.3-SNAPSHOT’ in repository opengeo (http://repo.opengeo.org/)
Downloading: http://download.osgeo.org/webdav/geotools//org/geoserver/community/ftp/2.0.3-SNAPSHOT/ftp-2.0.3-SNAPSHOT.jar
[INFO] Unable to find resource 'org.geoserver.community:ftp:jar:2.0.3-SNAPSHOT’ in repository osgeo (http://download.osgeo.org/webdav/geotools/)
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.geoserver.community:ftp:jar:2.0.3-SNAPSHOT
  Try downloading the file manually from the project website.
  Then, install it using the command:
      mvn install:install-file -DgroupId=org.geoserver.community -DartifactId=ftp -Dversion=2.0.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file
  Alternatively, if you host your own repository you can deploy the file there:
      mvn deploy:deploy-file -DgroupId=org.geoserver.community -DartifactId=ftp -Dversion=2.0.3-SNAPSHOT -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
  Path to dependency:
    1) org.geoserver.community:release:jar:2.0.3-SNAPSHOT
    2) org.geoserver.community:ftp:jar:2.0.3-SNAPSHOT
1 required artifact is missing.
for artifact:
from the specified remote repositories:
  central (http://repo1.maven.org/maven2),
  opengeo (http://repo.opengeo.org/),
  osgeo (http://download.osgeo.org/webdav/geotools/),
  maven-restlet (http://maven.restlet.org)
[INFO] Total time: 4 minutes 1 second
[INFO] Finished at: Wed Jun 02 05:53:41 EDT 2010
[INFO] Final Memory: 65M/152M
+ cp 'target/release/geoserver*-bin.zip' /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-06-02-bin.zip
cp: cannot stat `target/release/geoserver*-bin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/222/changes&gt;
Changes:
[aaime] Fixing nightly build
[...truncated 5613 lines...]
[INFO] Copying org.w3.xlink-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/org.w3.xlink-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-core-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-core-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-filter-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-filter-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-gml2-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-gml2-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-gml3-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-gml3-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-ows-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-ows-2.6-SNAPSHOT.jar&gt;
[INFO] Copying gt-xsd-wfs-2.6-SNAPSHOT.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/gt-xsd-wfs-2.6-SNAPSHOT.jar&gt;
[INFO] Copying h2-1.1.104.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/h2-1.1.104.jar&gt;
[INFO] Copying jetty-6.1.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/jetty-6.1.8.jar&gt;
[INFO] Copying jetty-util-6.1.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/jetty-util-6.1.8.jar&gt;
[INFO] Copying servlet-api-2.5-6.1.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/servlet-api-2.5-6.1.8.jar&gt;
[INFO] Copying geodb-0.3.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/geodb-0.3.jar&gt;
[INFO] Copying geoapi-2.3-M1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/geoapi-2.3-M1.jar&gt;
[INFO] Copying geoapi-pending-2.3-M1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/geoapi-pending-2.3-M1.jar&gt;
[INFO] Copying postgis-driver-1.0.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/postgis-driver-1.0.jar&gt;
[INFO] Copying org.restlet-1.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/org.restlet-1.0.8.jar&gt;
[INFO] Copying org.restlet.ext.freemarker-1.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/org.restlet.ext.freemarker-1.0.8.jar&gt;
[INFO] Copying org.restlet.ext.spring-1.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/org.restlet.ext.spring-1.0.8.jar&gt;
[INFO] Copying slf4j-api-1.4.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/slf4j-api-1.4.2.jar&gt;
[INFO] Copying slf4j-log4j12-1.4.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/slf4j-log4j12-1.4.2.jar&gt;
[INFO] Copying slf4j-simple-1.0.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/slf4j-simple-1.0.1.jar&gt;
[INFO] Copying spring-aop-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-aop-2.5.5.jar&gt;
[INFO] Copying spring-beans-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-beans-2.5.5.jar&gt;
[INFO] Copying spring-context-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-context-2.5.5.jar&gt;
[INFO] Copying spring-context-support-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-context-support-2.5.5.jar&gt;
[INFO] Copying spring-core-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-core-2.5.5.jar&gt;
[INFO] Copying spring-jdbc-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-jdbc-2.5.5.jar&gt;
[INFO] Copying spring-tx-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-tx-2.5.5.jar&gt;
[INFO] Copying spring-web-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-web-2.5.5.jar&gt;
[INFO] Copying spring-webmvc-2.5.5.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/spring-webmvc-2.5.5.jar&gt;
[INFO] Copying htmlvalidator-1.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/htmlvalidator-1.2.jar&gt;
[INFO] Copying oro-2.0.8.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/oro-2.0.8.jar&gt;
[INFO] Copying picocontainer-1.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/picocontainer-1.2.jar&gt;
[INFO] Copying postgresql-8.4-701.jdbc3.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/postgresql-8.4-701.jdbc3.jar&gt;
[INFO] Copying stax-api-1.0.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/stax-api-1.0.1.jar&gt;
[INFO] Copying struts-1.2.9.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/struts-1.2.9.jar&gt;
[INFO] Copying jasper-compiler-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/jasper-compiler-5.5.15.jar&gt;
[INFO] Copying jasper-compiler-jdt-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/jasper-compiler-jdt-5.5.15.jar&gt;
[INFO] Copying jasper-runtime-5.5.15.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/jasper-runtime-5.5.15.jar&gt;
[INFO] Copying xalan-2.7.0.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xalan-2.7.0.jar&gt;
[INFO] Copying xercesImpl-2.6.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xercesImpl-2.6.2.jar&gt;
[INFO] Copying xmlParserAPIs-2.6.2.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xmlParserAPIs-2.6.2.jar&gt;
[INFO] Copying xml-apis-1.3.04.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xml-apis-1.3.04.jar&gt;
[INFO] Copying xml-apis-ext-1.3.04.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xml-apis-ext-1.3.04.jar&gt;
[INFO] Copying xml-apis-xerces-2.7.1.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xml-apis-xerces-2.7.1.jar&gt;
[INFO] Copying xom-1.0b3.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xom-1.0b3.jar&gt;
[INFO] Copying xpp3-1.1.3.4.O.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xpp3-1.1.3.4.O.jar&gt;
[INFO] Copying xpp3_min-1.1.4c.jar to <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/release/target/dependency/xpp3_min-1.1.4c.jar&gt;
[WARNING] Component returned which is not the same manager. Ignored. component=org.apache.maven.profiles.activation.SystemPropertyProfileActivator@anonymised.com
[INFO] [antrun:run {execution: default}]
[INFO] Executing tasks
[INFO] Executed tasks
[INFO]
[INFO]
[INFO] Reactor Summary:
[INFO] GeoServer ............................................. SUCCESS [6.739s]
[INFO] GeoServer Maven Plugins ............................... SUCCESS [0.431s]
[INFO] Configuration Deployment PlugIn ....................... SUCCESS [2.746s]
[INFO] GeoServer Maven Archetypes ............................ SUCCESS [0.158s]
[INFO] GeoServer Web Plugin Archetype ........................ SUCCESS [1.255s]
[INFO] GeoServer WFS Output Format Archetype ................. SUCCESS [0.740s]
[INFO] Core Platform Module .................................. SUCCESS [6.144s]
[INFO] Open Web Service Module ............................... SUCCESS [17.967s]
[INFO] Main Module ........................................... SUCCESS [18.533s]
[INFO] Web Coverage Service Module ........................... SUCCESS [5.568s]
[INFO] Web Coverage Service 1.1 Module ....................... SUCCESS [9.232s]
[INFO] Web Feature Service Module ............................ SUCCESS [9.794s]
[INFO] Web Map Service Module ................................ SUCCESS [14.909s]
[INFO] GeoWebCache (GWC) Module .............................. SUCCESS [9.130s]
[INFO] REST Support Module ................................... SUCCESS [4.373s]
[INFO] GeoServer Web Modules ................................. SUCCESS [0.127s]
[INFO] Core UI Module ........................................ SUCCESS [13.905s]
[INFO] WMS UI Module ......................................... SUCCESS [9.590s]
[INFO] GWC UI Module ......................................... SUCCESS [2.418s]
[INFO] WFS UI Module ......................................... SUCCESS [4.515s]
[INFO] WCS UI Module ......................................... SUCCESS [3.926s]
[INFO] Demoes Module ......................................... SUCCESS [5.868s]
[INFO] Security UI Module .................................... SUCCESS [5.795s]
[INFO] GeoServer Web Application ............................. SUCCESS [26.965s]
[INFO] Community Space ....................................... SUCCESS [0.339s]
[INFO] OWS request flow controller ........................... SUCCESS [4.684s]
[INFO] GeoServer CSS Styling ................................. SUCCESS [48.987s]
[INFO] Printing Module ....................................... SUCCESS [5.258s]
[INFO] GeoServer Embedded FTP server ......................... SUCCESS [12.356s]
[INFO] GeoServer Community Release Module .................... SUCCESS [2.710s]
[INFO] GeoServer Extensions .................................. SUCCESS [0.109s]
[INFO] Application Schema Support ............................ SUCCESS [2.754s]
[INFO] Application Schema Integration Test ................... SUCCESS [14.686s]
[INFO] Sample DataAccess Integration Test .................... SUCCESS [2.379s]
[INFO] ArcSDE DataStore Extension ............................ SUCCESS [5.113s]
[INFO] GeoSearch Index Module ................................ SUCCESS [5.003s]
[INFO] H2 DataStore Extension ................................ SUCCESS [4.343s]
[INFO] SQL Server DataStore Extension ........................ SUCCESS [0.438s]
[INFO] Oracle DataStore Extension ............................ SUCCESS [0.432s]
[INFO] MySQL DataStore Extension ............................. SUCCESS [0.341s]
[INFO] Versioned Web Feature Service Module .................. SUCCESS [6.085s]
[INFO] DB2 DataStore Extension ............................... SUCCESS [0.341s]
[INFO] ImageMap Output Format ................................ SUCCESS [9.780s]
[INFO] JP2K Coverage Extension ............................... SUCCESS [0.540s]
[INFO] ogr2ogr Output Format ................................. SUCCESS [3.353s]
[INFO] Excel Output Format ................................... SUCCESS [3.277s]
[INFO] Validation Module ..................................... SUCCESS [1.999s]
[INFO] Chart external graphics support ....................... SUCCESS [0.532s]
[INFO] REST Configuration Service Module ..................... SUCCESS [7.588s]
[INFO] Feature Generalization Extension ...................... SUCCESS [2.383s]
[INFO] Image Mosaic JDBC Extension ........................... SUCCESS [0.528s]
[INFO] GeoServer Release Module .............................. SUCCESS [5.588s]
[INFO] BUILD SUCCESSFUL
[INFO] Total time: 5 minutes 35 seconds
[INFO] Finished at: Thu Jun 03 03:29:10 EDT 2010
[INFO] Final Memory: 77M/183M
+ mvn assembly:attached
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] Main Module
[INFO] task-segment: [assembly:attached] (aggregator-style)
[INFO] snapshot org.geoserver:platform:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:platform:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:ows:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:ows:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:main:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:main:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wfs:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wfs:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wms:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wms:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-core:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-core:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:gwc:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:gwc:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:wcs1_1:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver:rest:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:rest:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wms:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-wms:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-gwc:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-gwc:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wfs:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-wfs:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-wcs:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-wcs:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-demo:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-demo:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geoserver.web:web-security:2.0.3-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-security:2.0.3-SNAPSHOT: checking for updates from osgeo
[INFO] [assembly:attached]
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-src.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-war.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-javadoc.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-bin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-doc.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-db2-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-feature-pregeneralized-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-imagemosaic-jdbc-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-jp2k-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-mysql-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-oracle-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-vpf-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-arcsde-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-pyramid-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-wfsv-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-gdal-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-h2-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-sqlserver-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-imagemap-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-ogr-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-excel-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-restconfig-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-geosearch-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-charts-plugin.zip&gt;
[INFO] Building zip: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/target/release/geoserver-2.0.3-SNAPSHOT-app-schema-plugin.zip&gt;
[INFO] Total time: 1 minute 53 seconds
[INFO] Finished at: Thu Jun 03 03:31:08 EDT 2010
[INFO] Final Memory: 29M/128M
+ cp target/release/geoserver-2.0.3-SNAPSHOT-war.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-06-03-war.zip
+ cp target/release/geoserver-2.0.3-SNAPSHOT-bin.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-06-03-bin.zip
+ cp target/release/geoserver-2.0.3-SNAPSHOT-war.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-latest-war.zip
+ cp target/release/geoserver-2.0.3-SNAPSHOT-bin.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-latest-bin.zip
+ cd community
[ERROR] BUILD FAILURE
[INFO] Unable to find descriptor: <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/community/release/ext-ftp.xml&gt; (No such file or directory)
[INFO] Total time: 2 seconds
[INFO] Finished at: Thu Jun 03 03:31:13 EDT 2010
[INFO] Final Memory: 9M/68M
+ '[' '!' -e /var/www/html/geoserver/2.0.x/ext-2010-06-03 ']'
+ mkdir /var/www/html/geoserver/2.0.x/ext-2010-06-03
+ '[' '!' -e /var/www/html/geoserver/2.0.x/community-2010-06-03 ']'
+ mkdir /var/www/html/geoserver/2.0.x/community-2010-06-03
+ cp 'target/release/geoserver-*-plugin.zip' /var/www/html/geoserver/2.0.x/ext-2010-06-03
cp: cannot stat `target/release/geoserver-*-plugin.zip': No such file or directory
See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/223/changes&gt;
