See <http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/283/changes>
Changes:
[victortey] GEOT-2679: Improve app-schema handling of nillable properties: unit test
Started by timer
Updating http://svn.codehaus.org/geoserver/branches/2.0.x
AU src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTest.java
AU src/extension/app-schema/app-schema-test/src/test/java/org/geoserver/test/ValidationTestMockData.java
Fetching 'http://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/css’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/test/java/org/geoserver/wicket/test/css’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/img’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/src/test/java/org/geoserver/wicket/test/img’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/branches/2.0.x/data/citewfs-1.1/workspaces’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/data/citewfs-1.1-h2/workspaces’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/legacy/web/minimal’>
At revision 14638
Fetching 'http://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal’ at -1 into '<http://hudson.opengeo.org/hudson/job/geoserver-2.0.x-nightly/ws/geoserver_20x_nightly/src/web/app/minimal’>
At revision 14638
At revision 14638
no change for http://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/css since the previous build
no change for http://svn.codehaus.org/geoserver/branches/2.0.x/src/web/core/src/main/java/org/geoserver/web/img since the previous build
no change for http://svn.codehaus.org/geoserver/branches/2.0.x/data/citewfs-1.1/workspaces since the previous build
no change for http://svn.codehaus.org/geoserver/branches/2.0.x/data/minimal since the previous build
[workspace] $ /bin/sh -xe /opt/tomcat-6.0/temp/hudson6828496021028801719.sh
+ ver=2.0.x
+ dist=/var/www/html/geoserver/2.0.x
+ date +%Y-%m-%d
+ datestamp=2010-07-29
+ cd geoserver_20x_nightly/src
+ mvn -DskipTests -P release,communityRelease clean install
/opt/tomcat-6.0/temp/hudson6828496021028801719.sh: 1: mvn: not found
+ cp target/release/geoserver-2.0.3-SNAPSHOT-bin.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-2010-07-29-bin.zip
+ cp target/release/geoserver-2.0.3-SNAPSHOT-war.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-latest-war.zip
+ cp target/release/geoserver-2.0.3-SNAPSHOT-bin.zip /var/www/html/geoserver/2.0.x/geoserver-2.0.x-latest-bin.zip
+ cd community
+ mvn assembly:attached
+ [ ! -e /var/www/html/geoserver/2.0.x/ext-2010-07-29 ]
+ mkdir /var/www/html/geoserver/2.0.x/ext-2010-07-29
+ [ ! -e /var/www/html/geoserver/2.0.x/community-2010-07-29 ]
+ mkdir /var/www/html/geoserver/2.0.x/community-2010-07-29
+ cp target/release/geoserver-2.0.3-SNAPSHOT-css-plugin.zip target/release/geoserver-2.0.3-SNAPSHOT-ftp-plugin.zip target/release/geoserver-2.0.3-SNAPSHOT-printing-plugin.zip /var/www/html/geoserver/2.0.x/ext-2010-07-29
+ rm -rf /var/www/html/geoserver/2.0.x/ext-latest
+ mkdir /var/www/html/geoserver/2.0.x/ext-latest
+ cp target/release/geoserver-2.0.3-SNAPSHOT-css-plugin.zip target/release/geoserver-2.0.3-SNAPSHOT-ftp-plugin.zip target/release/geoserver-2.0.3-SNAPSHOT-printing-plugin.zip /var/www/html/geoserver/2.0.x/ext-latest
+ cp community/target/release/geoserver-*-plugin.zip /var/www/html/geoserver/2.0.x/community-2010-07-29
cp: cannot stat `community/target/release/geoserver-*-plugin.zip': No such file or directory
