[Geoserver-devel] Build failed in Hudson: geoserver-2.1.x #100
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/100/changes&gt;
Changes:
[aaime] [GEOS-4410] jaitools based processes won't work in Tomcat due to jai registration issues
[...truncated 26789 lines...]
[INFO] No sources to compile
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow&gt;
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/resources&gt;
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/classes&gt;
[INFO] Copying 0 resource
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/surefire-reports&gt;
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-3,5,main] waiting
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] waiting
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] waiting
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.511 sec
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.009 sec
Results :
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/control-flow-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/control-flow/2.1-SNAPSHOT/control-flow-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Web Processing Service parent
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps&gt;
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/target/wps-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/pom.xml&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/target/wps-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/extension/wps/2.1-SNAPSHOT/wps-2.1-SNAPSHOT-tests.jar
[INFO] Building Web Processing Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core&gt;
[INFO] Copying 10 resources
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/src/main/resources&gt;
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wps:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/2.7-SNAPSHOT/net.opengis.wps-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wps:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-process:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from jaitools-snapshots
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geojson:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/jdbc/gt-jdbc-postgis/2.7-SNAPSHOT/gt-jdbc-postgis-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/ogc/net.opengis.wps/2.7-SNAPSHOT/net.opengis.wps-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/2.7-SNAPSHOT/gt-xsd-fes-2.7-SNAPSHOT.jar
[INFO] Compiling 116 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/RangeLookupProcess.java&gt;:\[56,114\] cannot find symbol
symbol : variable JAI_TOOLS_PRODUCT
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/PolygonExtractionProcess.java&gt;:\[52,110\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/ContourProcess.java&gt;:\[58,106\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/wps/wps-core/src/main/java/org/geoserver/wps/gs/RasterZonalStatistics.java&gt;:\[83,112\] cannot find symbol
[INFO] Total time: 9 minutes 46 seconds
[INFO] Finished at: Fri Mar 04 15:59:37 UTC 2011
[INFO] Final Memory: 81M/326M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/101/&gt;
