See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/131/changes>
Changes:
[aaime] [GEOS-4438] KML may return no data if the style has rules with scale dependencies
[...truncated 19992 lines...]
at java.lang.reflect.Method.invoke(Method.java:592)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
at sun.reflect.GeneratedMethodAccessor153.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
21 Mar 20:43:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5010117706766375894data>
21 Mar 20:43:33 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1161)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:204)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:74)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1144)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:482)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:226)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1154)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1173)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:542)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:67)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:63)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.214 sec
Running org.geoserver.wms.map.GIFMapResponseTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1328380592642177549data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.599 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
21 Mar 20:43:34 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
21 Mar 20:43:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6798859149762676862data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.777 sec
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
21 Mar 20:43:35 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
21 Mar 20:43:35 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.296 sec
Running org.geoserver.wms.RenderingBufferTest
21 Mar 20:43:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock7627473606019194303data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2830488610198230022data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6125626452180910537data>
21 Mar 20:43:36 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4489550071606061186data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3073703847691512598data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6762384592048757285data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.048 sec
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2758676915419181921data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4538981692043870083data>
21 Mar 20:43:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock717421440383276290data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5126655249198257508data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1665940790465689704data>
21 Mar 20:43:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock446642986599965872data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6251893672639635414data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock591172825716258460data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.464 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
21 Mar 20:43:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3387826072597300370data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.26 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock372613102037640170data>
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.833 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
21 Mar 20:43:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2832862429905559702data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.191 sec
Running org.geoserver.kml.KMZMapProducerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock7034576370691796061data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.285 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
21 Mar 20:43:40 ERROR [geotools.map] - Call MapContent dispose() to prevent memory leaks
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1199278969219956684data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.183 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
21 Mar 20:43:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4799411452982832619data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Results :
Tests in error:
org.geoserver.kml.KMLTest
Tests run: 241, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 31 seconds
[INFO] Finished at: Mon Mar 21 20:43:42 UTC 2011
[INFO] Final Memory: 63M/312M
