[Geoserver-devel] Build failed in Hudson: geoserver-2.1.x #158
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/158/changes&gt;
Changes:
[jdeolive] GEOS-4427, updating map preview to have the urls use workspace/virtual services to facilitate cases where global services are turned off
[jdeolive] GEOS-4283, chaning constant LAT_LON to NORTH_EAST, and implicit use of new version getAxisOrder() method to support axis order checks for projected crs
[jdeolive] GEOS-4446, patching worldToScreenTransform to take into account crs axis order
[...truncated 18640 lines...]
          <xsd:element maxOccurs="1" minOccurs="0" name="uriProperty" nillable="true" type="xsd:anyURI"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="measurand" nillable="true" type="xsd:string"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="dateTimeProperty" nillable="true" type="xsd:dateTime"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="dateProperty" nillable="true" type="xsd:date"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="decimalProperty" nillable="true" type="xsd:double"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="booleanProperty" nillable="true" type="xsd:boolean"/>
        </xsd:sequence>
      </xsd:extension>
    </xsd:complexContent>
  </xsd:complexType>
  <xsd:element name="PrimitiveGeoFeature" substitutionGroup="gml:_Feature" type="sf:PrimitiveGeoFeatureType"/>
  <xsd:complexType name="GenericEntityType">
    <xsd:complexContent>
      <xsd:extension base="gml:AbstractFeatureType">
        <xsd:sequence>
          <xsd:element maxOccurs="1" minOccurs="0" name="attribut.geom" nillable="true" type="gml:GeometryPropertyType"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="boolProperty" nillable="true" type="xsd:boolean"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="str4Property" nillable="true" type="xsd:string"/>
          <xsd:element maxOccurs="1" minOccurs="0" name="featureRef" nillable="true" type="xsd:string"/>
        </xsd:sequence>
      </xsd:extension>
  </xsd:complexType>
  <xsd:element name="GenericEntity" substitutionGroup="gml:_Feature" type="sf:GenericEntityType"/>
</xsd:schema>
04 Apr 17:37:29 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6586987050037752680data&gt;
04 Apr 17:37:30 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock985570760511859355data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock434657835073141569data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2344117022551772897data&gt;
04 Apr 17:37:30 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: Streams.
Strict WFS protocol conformance is being applied.
Make sure the type name is correctly qualified
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:138)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:97)
  at sun.reflect.GeneratedMethodAccessor210.invoke(Unknown Source)
  at java.lang.reflect.Method.invoke(Method.java:592)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.RequestObjectLogger.invoke(RequestObjectLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy14.describeFeatureType(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor209.invoke(Unknown Source)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:624)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:229)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1154)
  at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1173)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1114)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:542)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:523)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:795)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:759)
  at org.geoserver.wfs.v1_1.DescribeFeatureTypeTest.testCiteCompliance(DescribeFeatureTypeTest.java:181)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
  at sun.reflect.GeneratedMethodAccessor172.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4869842023160160873data&gt;
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.917 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5546084345829253660data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8710313929867302847data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.243 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4670413905821809289data&gt;
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.117 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8098445543989312319data&gt;
04 Apr 17:37:31 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7056877108818677024data&gt;
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.315 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6189269913092930021data&gt;
Feature type cite:InvalidTypeName unknown
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock542424724848731968data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3320547306689465893data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7872538664979485571data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1878615328064332601data&gt;
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.533 sec
Running org.geoserver.wfs.response.ShapeZipTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock699628660936730697data&gt;
04 Apr 17:37:32 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1086763097371108600data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3599245338672708233data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1899029863366128571data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4703535031477473432data&gt;
04 Apr 17:37:33 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2349087473309554206data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7699197133293054036data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock333549714507851828data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7122121977570974941data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock412232002338710567data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5765356429862351431data&gt;
04 Apr 17:37:34 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock303615208960507240data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock353875269577431997data&gt;
04 Apr 17:37:35 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock9209641518421300091data&gt;
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7884240373806075905data&gt;
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.116 sec
Running org.geoserver.wfs.GetCapabilitiesTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6131881420249454845data&gt;
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.374 sec
Results :
Failed tests:
  testWfs11(org.geoserver.wfs.SrsNameTest)
Tests run: 245, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/surefire-reports&gt; for the individual test results.
[INFO] Total time: 2 minutes 57 seconds
[INFO] Finished at: Mon Apr 04 17:37:36 UTC 2011
[INFO] Final Memory: 61M/275M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/159/&gt;
