See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/296/changes>
Changes:
[aaime] [GEOS-4638] GeoServer WMS fails to re-encode 4bit paletted png images back in png
[...truncated 20357 lines...]
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1198)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1139)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:555)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:538)
at org.geoserver.wms.WMSServiceExceptionTest.testPng8InImageFormat130(WMSServiceExceptionTest.java:43)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
at sun.reflect.GeneratedMethodAccessor237.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
18 Jun 17:55:47 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8511341618664618612data>
18 Jun 17:55:47 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1180)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:204)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:74)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1157)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:488)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:231)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1179)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:67)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:63)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.968 sec
Running org.geoserver.wms.map.GIFMapResponseTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8346454874175629556data>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.591 sec
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
18 Jun 17:55:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3762791585887014339data>
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
18 Jun 17:55:48 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
18 Jun 17:55:49 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.251 sec
Running org.geoserver.wms.RenderingBufferTest
18 Jun 17:55:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6862497248340906104data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4186552649493344198data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5814471890268930992data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8019431040888557157data>
18 Jun 17:55:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4708901650475279503data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3077696810613062877data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.15 sec
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5070244922390362175data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3803006302907413947data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1512010371646514248data>
18 Jun 17:55:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8162755940457580326data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock7323311559322942599data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5854549031165247296data>
18 Jun 17:55:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6723685153292649394data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5876995774388225448data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.443 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1480403094838420121data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.245 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
18 Jun 17:55:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock9195804591425084280data>
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.891 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6835311581016168189data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.217 sec
Running org.geoserver.kml.KMZMapProducerTest
18 Jun 17:55:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5150344122941150844data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4417033584786628810data>
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.671 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
18 Jun 17:55:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4959989368926677202data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Failed tests:
testFourBits(org.geoserver.wms.map.GetMapIntegrationTest)
Tests run: 262, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 44 seconds
[INFO] Finished at: Sat Jun 18 17:55:56 UTC 2011
[INFO] Final Memory: 64M/308M
