See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/310/>
[...truncated 20420 lines...]
at sun.reflect.GeneratedMethodAccessor237.invoke(Unknown Source)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
25 Jun 10:48:37 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6099720032069876614data>
25 Jun 10:48:37 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find layer foobar
at org.geoserver.wms.map.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1180)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:204)
at org.geoserver.wms.map.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:74)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1157)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:488)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:231)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1179)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1198)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1139)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:555)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:538)
at org.geoserver.wms.WMSServiceExceptionTest.assertResponse130(WMSServiceExceptionTest.java:67)
at org.geoserver.wms.WMSServiceExceptionTest.testException130(WMSServiceExceptionTest.java:63)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.426 sec
Running org.geoserver.wms.map.GIFMapResponseTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8114830498231684498data>
25 Jun 10:48:37 ERROR [lite.StyledShapePainter] - ShapePainter has been asked to paint a null style!!
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.421 sec <<< FAILURE!
Running org.geoserver.wms.map.RenderedImageMapOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6601888838754178246data>
Tests run: 4, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 0.384 sec <<< FAILURE!
Running org.geoserver.wms.capabilities.GetCapabilitiesTransformerTest
25 Jun 10:48:37 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
25 Jun 10:48:38 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.324 sec
Running org.geoserver.wms.RenderingBufferTest
25 Jun 10:48:38 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4594120319559201754data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6112586208973609515data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4580971108636716282data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2055014000047491573data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2491406572926494495data>
25 Jun 10:48:39 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8539804810661865268data>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.011 sec
Running org.geoserver.kml.GeoSearchKMLTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock3920119450665798231data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8352186011695890973data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock8131235274449692912data>
25 Jun 10:48:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1906668815205762939data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock7001579554575622354data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock860988484473106144data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock6371969454085315610data>
25 Jun 10:48:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock1244179784044525835data>
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.005 sec
Running org.geoserver.wms.ProxyBaseURLIntegrationTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5825969172435048824data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.geoserver.wms.wms_1_1_1.GetFeatureInfoTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock2514854544547608757data>
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.239 sec
Running org.geoserver.wms.featureinfo.FeatureTimeTemplateTest
25 Jun 10:48:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4973174102980807896data>
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.195 sec
Running org.geoserver.kml.KMZMapProducerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock658401573342288958data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.258 sec
Running org.geoserver.wms.wms_1_1_1.CapabilitiesTest
25 Jun 10:48:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock4213249270008995976data>
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.302 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
25 Jun 10:48:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock5236118922686012050data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.18 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Failed tests:
testDefaultStyle(org.geoserver.wms.map.GIFMapResponseTest)
testDefaultStyle(org.geoserver.wms.map.RenderedImageMapOutputFormatTest)
Tests run: 264, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/surefire-reports> for the individual test results.
[INFO] Total time: 3 minutes 50 seconds
[INFO] Finished at: Sat Jun 25 10:48:45 UTC 2011
[INFO] Final Memory: 64M/313M
