See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/419/>
[...truncated 12345 lines...]
Sep 22, 2011 10:12:28 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Tests run: 57, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.007 sec
Running org.vfny.geoserver.util.SLDValidatorTest
Sep 22, 2011 10:12:28 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock4855028554459205179data>
Sep 22, 2011 10:12:28 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4cd8'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4cd6'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4cd5'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4cd7'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock3169567217118971260data>
cvc-complex-type.2.4.a: Invalid content starting with element 'Font'. One of '{"http://www.opengis.net/sld":Stroke\}' is expected.
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c80'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c7e'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c7d'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c7f'
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.527 sec
Running org.geoserver.catalog.impl.CascadeRemovalReporterTest
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock4609901988574938032data>
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c28'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c26'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c27'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4c25'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock2512691681190314825data>
Sep 22, 2011 10:12:29 AM org.geoserver.catalog.ResourcePool$DataStoreCache dispose
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4bcf'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4bcd'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4bce'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4bcc'
Sep 22, 2011 10:12:29 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock4216247400837136737data>
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b76'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b74'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b75'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b73'
SEVERE:
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/./target/mock6552506069890024892data>
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b1d'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b1b'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b1c'
INFO: Disposing datastore 'DataStoreInfoImpl--55412a7f:132909eceb3:-4b1a'
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.472 sec
Results :
Failed tests:
testMosaicParameters(org.geoserver.catalog.impl.CatalogBuilderTest)
Tests run: 278, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target/surefire-reports> for the individual test results.
[INFO] Total time: 2 minutes 16 seconds
[INFO] Finished at: Thu Sep 22 10:12:30 UTC 2011
[INFO] Final Memory: 51M/210M
