See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/432/changes>
Changes:
[aaime] [GEOS-4777] Allow layers to be available, but not advertised in the capabilities documents
[...truncated 661 lines...]
[INFO] snapshot org.geotools:extension:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:extension:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-filter:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-coverage:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-core:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-graph:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml2:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-gml3:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 82 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/classes>
[INFO] Copying 4 resources
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/surefire-reports>
T E S T S
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.04 sec
Running org.geoserver.ows.DispatcherTest
Sep 29, 2011 1:27:05 PM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Sep 29, 2011 1:27:05 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Thu Sep 29 13:27:05 UTC 2011]; root of context hierarchy
Sep 29, 2011 1:27:05 PM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Sep 29, 2011 1:27:05 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
Sep 29, 2011 1:27:05 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.776 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.289 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.049 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.097 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.074 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.005 sec
Results :
Tests run: 31, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main>
[INFO] Copying 28 resources
[INFO] Copying 1 resource
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] Compiling 299 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingLayerInfo.java>:\[125,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingLayerInfo.java>:\[130,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingFeatureTypeInfo.java>:\[254,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingFeatureTypeInfo.java>:\[259,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingWMSLayerInfo.java>:\[207,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingWMSLayerInfo.java>:\[212,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingCoverageInfo.java>:\[281,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/DecoratingCoverageInfo.java>:\[286,5\] method does not override a method from its superclass
[INFO] Total time: 43 seconds
[INFO] Finished at: Thu Sep 29 13:27:19 UTC 2011
[INFO] Final Memory: 53M/214M
