[Geoserver-devel] Build failed in Hudson: geoserver-2.1.x #444
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/444/changes&gt;
Changes:
[groldan] GEOS-4672: allow setting a WMSStoreInfo auth credentials and max concurrent connections to the backend
[groldan] GEOS-4650: basicProcessingFilter with rememberme service makes gwc ReloadRestlet to ge an empty form. Use a basicProcessingFilter without rememberme service as workaround for /gwc/rest/**
[...truncated 667 lines...]
[INFO] Copying 4 resources
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes&gt;
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/surefire-reports&gt;
T E S T S
Running org.geoserver.ows.util.OwsUtilsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.geoserver.ows.DispatcherTest
Oct 6, 2011 12:41:14 AM org.geoserver.platform.GeoServerExtensions checkContext
SEVERE: Extension lookup occured, but ApplicationContext is unset.
Oct 6, 2011 12:41:14 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Thu Oct 06 00:41:14 UTC 2011]; root of context hierarchy
Oct 6, 2011 12:41:14 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes/org/geoserver/ows/applicationContext.xml\]>
Oct 6, 2011 12:41:14 AM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
Oct 6, 2011 12:41:14 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageKvpReader,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Oct 6, 2011 12:41:15 AM org.springframework.context.support.AbstractApplicationContext prepareRefresh
Oct 6, 2011 12:41:15 AM org.springframework.beans.factory.xml.XmlBeanDefinitionReader loadBeanDefinitions
Oct 6, 2011 12:41:15 AM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
Oct 6, 2011 12:41:15 AM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Refreshing org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com: display name [org.springframework.context.support.FileSystemXmlApplicationContext@anonymised.com]; startup date [Thu Oct 06 00:41:15 UTC 2011]; root of context hierarchy
INFO: Loading XML bean definitions from URL [<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/test-classes/org/geoserver/ows/applicationContextOnlyXml.xml\]>
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com: defining beans [extensions,dispatcher,messageXmlReader,messageResponse,hello,helloWorld,helloWorldService]; root of factory hierarchy
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.769 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.507 sec
Running org.geoserver.ows.xml.v1_0.ExceptionReportBindingTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.048 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Running org.geoserver.ows.XmlObjectEncodingResponseTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.ows.kvp.CharsetKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.016 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Results :
Tests run: 31, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt;
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows&gt;
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt;
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-test-sources.jar&gt;
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-tests.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/ows/target/ows-2.1-SNAPSHOT-test-sources.jar&gt; to /home/tomcat/.m2/repository/org/geoserver/ows/2.1-SNAPSHOT/ows-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Main Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target&gt;
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main&gt;
[INFO] Copying 28 resources
[INFO] Copying 1 resource
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-cql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-validation:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/2.7-SNAPSHOT/gt-validation-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-data:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-property:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:plugin:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-epsg-hsql:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wms:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-xml:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-render:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcgrid:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-geotiff:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-geotiff/2.7-SNAPSHOT/gt-geotiff-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-gtopo30:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-image:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/2.7-SNAPSHOT/gt-shapefile-2.7-SNAPSHOT.pom
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-imageio-ext-gdal:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:unsupported:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.ogc:net.opengis.wfs:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.xsd:gt-xsd-fes:2.7-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-fes/2.7-SNAPSHOT/gt-xsd-fes-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/2.7-SNAPSHOT/gt-validation-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/2.7-SNAPSHOT/gt-shapefile-2.7-SNAPSHOT.jar
[INFO] Compiling 299 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/target/classes&gt;
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/catalog/ResourcePool.java&gt;:\[62,29\] cannot find symbol
symbol : class MultithreadedHttpClient
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetFeatureInfoRequest.java&gt;:\[18,29\] cannot find symbol
symbol : class HTTPResponse
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetFeatureInfoRequest.java&gt;:\[98,35\] cannot find symbol
location: class org.geoserver.security.decorators.SecuredGetFeatureInfoRequest
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetMapRequest.java&gt;:\[22,29\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetMapRequest.java&gt;:\[243,35\] cannot find symbol
location: class org.geoserver.security.decorators.SecuredGetMapRequest
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/catalog/ResourcePool.java&gt;:\[1149,24\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/catalog/ResourcePool.java&gt;:\[1149,61\] cannot find symbol
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetFeatureInfoRequest.java&gt;:\[29,7\] org.geoserver.security.decorators.SecuredGetFeatureInfoRequest is not abstract and does not override abstract method createResponse(java.lang.String,java.io.InputStream) in org.geotools.data.ows.Request
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/main/src/main/java/org/geoserver/security/decorators/SecuredGetMapRequest.java&gt;:\[37,7\] org.geoserver.security.decorators.SecuredGetMapRequest is not abstract and does not override abstract method createResponse(java.lang.String,java.io.InputStream) in org.geotools.data.ows.Request
[INFO] Total time: 43 seconds
[INFO] Finished at: Thu Oct 06 00:41:26 UTC 2011
[INFO] Final Memory: 52M/217M
See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/445/&gt;
