See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/449/changes>
Changes:
[jdeolive] GEOS-4659, added option to allow WMS capabilities to output a bounding box for every supported projection
[jdeolive] GEOS-4658, adding support for vocabulary, and language to keywords for services and resources
[...truncated 48661 lines...]
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1198)
at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForRequest(GeoServerAbstractTestSupport.java:1267)
at org.geoserver.test.GeoServerAbstractTestSupport.assertStatusCodeForGet(GeoServerAbstractTestSupport.java:1220)
at org.geoserver.geosearch.SiteMapIndexRestletTest.assertProtectedEndpoint(SiteMapIndexRestletTest.java:33)
at org.geoserver.geosearch.SiteMapIndexRestletTest.testGotoKML(SiteMapIndexRestletTest.java:67)
at java.lang.reflect.Method.invoke(Method.java:592)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:142)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:345)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:1009)
06 Oct 19:58:12 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock9020669425814591806data>
06 Oct 19:58:12 ERROR [geoserver.rest] - Layer not indexable: BasicPolygons
org.geoserver.rest.RestletException
at org.geoserver.geosearch.FeatureRestlet.doGet(FeatureRestlet.java:165)
at org.geoserver.geosearch.FeatureRestlet.handle(FeatureRestlet.java:89)
at org.geoserver.rest.BeanDelegatingRestlet.handle(BeanDelegatingRestlet.java:37)
at org.restlet.Filter.doHandle(Filter.java:105)
at org.restlet.Filter.handle(Filter.java:134)
at org.restlet.Router.handle(Router.java:444)
at org.geoserver.rest.RESTDispatcher$1.handle(RESTDispatcher.java:204)
at com.noelios.restlet.ext.servlet.ServletConverter.service(ServletConverter.java:129)
at org.geoserver.rest.RESTDispatcher.handleRequestInternal(RESTDispatcher.java:86)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport$3.service(GeoServerAbstractTestSupport.java:1179)
at com.mockrunner.mock.web.MockFilterChain.doFilter(MockFilterChain.java:50)
at org.geoserver.geosearch.SiteMapIndexRestletTest.testFeatureKML(SiteMapIndexRestletTest.java:76)
06 Oct 19:58:13 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock2823094980249445586data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock14095352371606450data>
06 Oct 19:58:13 ERROR [geoserver.rest] - Indexing is disabled for this layer (NamespaceInfoImpl[cite:http://www.opengis.net/cite\]:BasicPolygons) false
at org.geoserver.geosearch.AbstractFeatureDescription.findFeature(AbstractFeatureDescription.java:66)
at org.geoserver.geosearch.HTMLFeatureDescription.doGet(HTMLFeatureDescription.java:38)
at org.geoserver.geosearch.HTMLFeatureDescription.handle(HTMLFeatureDescription.java:30)
at org.geoserver.geosearch.SiteMapIndexRestletTest.testFeatureHTML(SiteMapIndexRestletTest.java:94)
06 Oct 19:58:14 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock3965082744121069224data>
06 Oct 19:58:14 ERROR [geoserver.rest] - Layer indexing disabled
at org.geoserver.geosearch.LayerAboutPage.getContext(LayerAboutPage.java:61)
at org.geoserver.geosearch.LayerAboutPage.doGet(LayerAboutPage.java:54)
at org.geoserver.geosearch.LayerAboutPage.handle(LayerAboutPage.java:46)
at org.geoserver.geosearch.SiteMapIndexRestletTest.testLayerHTML(SiteMapIndexRestletTest.java:103)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 8.376 sec
Running org.geoserver.geosearch.FeatureRestletTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock1120287510672463839data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.525 sec
Running org.geoserver.geosearch.LayerAboutPageTest
06 Oct 19:58:15 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/./target/mock6857783248852379376data>
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.292 sec <<< FAILURE!
Results :
Tests in error:
testGetContext(org.geoserver.geosearch.LayerAboutPageTest)
Tests run: 8, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/geosearch/target/surefire-reports> for the individual test results.
[INFO] Total time: 10 minutes 54 seconds
[INFO] Finished at: Thu Oct 06 19:58:15 UTC 2011
[INFO] Final Memory: 75M/270M
