See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/477/changes>
Changes:
[fgdrf] i18n for table headers of user roles management Palette
[fgdrf] i18n support for "Reload feature type" link
[...truncated 41265 lines...]
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock5329486563473562177data>
20 Oct 12:49:01 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
20 Oct 12:49:02 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
20 Oct 12:49:02 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock4898291398486023151data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.2 sec
Results :
Failed tests:
testRenders(org.geoserver.web.security.user.NewUserPageTest)
testEditUser(org.geoserver.web.security.user.UserListPageTest)
testEditRule(org.geoserver.web.security.data.DataAccessRulePageTest)
testRenders(org.geoserver.web.security.data.NewRulePageTest)
testRenders(org.geoserver.web.security.user.EditUserPageTest)
testEditRule(org.geoserver.web.security.service.ServiceAccessRulePageTest)
Tests in error:
testFill(org.geoserver.web.security.user.NewUserPageTest)
testPasswordsDontMatch(org.geoserver.web.security.user.NewUserPageTest)
testFill(org.geoserver.web.security.data.NewRulePageTest)
testAjaxUpdate(org.geoserver.web.security.data.NewRulePageTest)
Tests run: 19, Failures: 6, Errors: 4, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/surefire-reports> for the individual test results.
[INFO] Total time: 8 minutes 59 seconds
[INFO] Finished at: Thu Oct 20 12:49:02 UTC 2011
[INFO] Final Memory: 70M/306M
Failed to send e-mail to fgdrf because no e-mail address is known, and no default e-mail domain is configured
