See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/479/changes>
Changes:
[groldan] let integrated gwc layers cascade feature_count on GetFeatureInfo requests
[...truncated 29800 lines...]
20 Oct 17:40:17 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.095 sec
Running org.geoserver.wms.map.OpenLayersMapTemplateTest
20 Oct 17:40:19 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/./target/mock9087627196251911654data>
20 Oct 17:40:19 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.267 sec
Running org.geoserver.wms.map.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Results :
Tests run: 285, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-gml2/2.7-SNAPSHOT/gt-xsd-gml2-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/2.7-SNAPSHOT/gt-xsd-sld-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-image/2.7-SNAPSHOT/gt-image-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-arcgrid/2.7-SNAPSHOT/gt-arcgrid-2.7-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/wms-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wms/2.1-SNAPSHOT/wms-2.1-SNAPSHOT-test-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/gwc/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/gwc>
[INFO] Copying 0 resource
[INFO] Copying 13 resources
Downloading: http://repo.opengeo.org//org/geotools/gt-render/2.7-SNAPSHOT/gt-render-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/2.7-SNAPSHOT/gt-wfs-2.7-SNAPSHOT.jar
[INFO] Compiling 18 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/gwc/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/gwc/src/main/java/org/geoserver/gwc/layer/GeoServerTileLayer.java>:\[409,53\] selectedStringsFromMap(java.util.Map<java.lang.String,?>,java.lang.String,java.lang.String) in org.geowebcache.util.ServletUtils cannot be applied to (java.util.Map,java.lang.String,java.lang.String)
[INFO] Total time: 4 minutes 55 seconds
[INFO] Finished at: Thu Oct 20 17:40:23 UTC 2011
[INFO] Final Memory: 65M/300M
