See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/577/changes>
Changes:
[aaime] [GEOS-4913] A disappearing scaleline
[...truncated 13431 lines...]
29 Dec 11:41:40 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1398398962748395617data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5090584853021702045data>
Tests run: 11, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.72 sec
Running org.geoserver.wfs.response.CSVOutputFormatTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3144334021167991631data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2363935100033995144data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.249 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
29 Dec 11:41:41 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1242754167158741974data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.117 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2473909989572389560data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5608656826263823567data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.283 sec
Running org.geoserver.wfs.kvp.GetFeatureKvpRequestReaderTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5044623178265168096data>
Feature type cite:InvalidTypeName unknown
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7448504774955535956data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6465849016321232592data>
29 Dec 11:41:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4993474299240169370data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3048332298141277390data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7968632617715853979data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5472778325494712075data>
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.115 sec
Running org.geoserver.wfs.response.ShapeZipTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7454200148607501564data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8619836990620817481data>
29 Dec 11:41:43 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock8893437537610049322data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5335144283697996501data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7410715261711397370data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock1104433211055753836data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock904720629351158997data>
29 Dec 11:41:44 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7947588808408317537data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock181377502302200367data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4019254414387435345data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5860361297776540821data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock3425501745768630778data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock2624983053004912914data>
29 Dec 11:41:45 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6508170401196820058data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock6630620798639484804data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7083751487734453202data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4837371428805772951data>
29 Dec 11:41:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock4857127938727661068data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock7119305010455532045data>
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.861 sec
Running org.geoserver.wfs.GetCapabilitiesTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/./target/mock5625143180188637720data>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.979 sec
Results :
Tests run: 272, Failures: 0, Errors: 0, Skipped: 0
Downloading: http://repo.opengeo.org//org/geotools/gt-coverage/2.7-SNAPSHOT/gt-coverage-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-validation/2.7-SNAPSHOT/gt-validation-2.7-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT.jar>
Downloading: http://repo.opengeo.org//org/opengeo/geodb/0.6-SNAPSHOT/geodb-0.6-SNAPSHOT.jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wfs/target/wfs-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/wfs/2.1-SNAPSHOT/wfs-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms>
[INFO] Copying 1 resource
[INFO] Copying 63 resources
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-svg:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.7-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/2.7-SNAPSHOT/gt-shapefile-renderer-2.7-SNAPSHOT.pom
Downloading: http://repo.opengeo.org//org/geotools/gt-main/2.7-SNAPSHOT/gt-main-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile/2.7-SNAPSHOT/gt-shapefile-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-shapefile-renderer/2.7-SNAPSHOT/gt-shapefile-renderer-2.7-SNAPSHOT.jar
Downloading: http://repo.opengeo.org//org/geotools/gt-wfs/2.7-SNAPSHOT/gt-wfs-2.7-SNAPSHOT.jar
[INFO] Compiling 170 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/classes>
[INFO] Copying 50 resources
[INFO] Compiling 60 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/target/test-classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/src/test/java/org/geoserver/wms/decoration/MapDecorationLayoutTest.java>:\[374,17\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/src/test/java/org/geoserver/wms/decoration/MapDecorationLayoutTest.java>:\[380,17\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/wms/src/test/java/org/geoserver/wms/decoration/MapDecorationLayoutTest.java>:\[385,17\] method does not override a method from its superclass
[INFO] Total time: 3 minutes 54 seconds
[INFO] Finished at: Thu Dec 29 11:41:56 UTC 2011
[INFO] Final Memory: 64M/292M
