See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/593/>
[...truncated 21663 lines...]
[INFO] Copying 0 resource
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/surefire-reports>
T E S T S
Running org.geoserver.web.security.user.NewUserPageTest
17 Jan 19:44:42 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock8947311004744797433data>
17 Jan 19:44:46 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock3887033848197297463data>
17 Jan 19:44:48 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock6361779182067674174data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.763 sec
Running org.geoserver.web.security.user.UserListPageTest
17 Jan 19:44:49 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock6031020775419530823data>
17 Jan 19:44:50 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock3030122657818485572data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.774 sec
Running org.geoserver.web.security.data.DataAccessRulePageTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock7061961000309514017data>
17 Jan 19:44:51 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock1959630967480675129data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.249 sec
Running org.geoserver.web.security.data.NewRulePageTest
17 Jan 19:44:52 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock8146408069467104199data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock3687807072652621040data>
17 Jan 19:44:53 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock2246985584359703924data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.779 sec
Running org.geoserver.web.security.ConfirmRemovalUserPanelTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock454215155507021208data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.309 sec
Running org.geoserver.web.security.user.EditUserPageTest
17 Jan 19:44:54 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock6102480968792963900data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.397 sec
Running org.geoserver.web.security.ConfirmRemovalDataAccessRulePanelTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock4247269655105148056data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.669 sec
Running org.geoserver.web.security.ConfirmRemovalServicePanelTest
17 Jan 19:44:55 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock7823871134581920114data>
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.285 sec
Running org.geoserver.web.security.service.ServiceAccessRulePageTest
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock468651623808795427data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock6411749757731121996data>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.262 sec
Running org.geoserver.web.security.catalog.CatalogModePageTest
17 Jan 19:44:56 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock8683440647769959351data>
17 Jan 19:44:57 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock6738361415100721334data>
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/./target/mock766889277103057857data>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.115 sec
Results :
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/web/security/target/web-security-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/web/web-security/2.1-SNAPSHOT/web-security-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Community Space
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community>
[INFO] [site:attach-descriptor {execution: default-attach-descriptor}]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/target/community-2.1-SNAPSHOT-tests.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/pom.xml> to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT.pom
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/target/community-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/community/2.1-SNAPSHOT/community-2.1-SNAPSHOT-tests.jar
[INFO] Building Printing Module
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing>
[INFO] Copying 6 resources
[INFO] Copying 2 resources
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.print:print-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.pom
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from org.mapfish
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.mapfish.geo:mapfish-geo-lib:1.2-SNAPSHOT: checking for updates from osgeo
Downloading: http://dev.mapfish.org/maven/repository/org/mapfish/print/print-lib/1.2-SNAPSHOT/print-lib-1.2-SNAPSHOT.jar
[INFO] Compiling 2 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/target/classes>
[INFO] Compiling 1 source file to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/target/surefire-reports>
T E S T S
Running org.geoserver.printing.SmokeTest
17 Jan 19:45:07 ERROR [geoserver.global] -
- GEOSERVER_DATA_DIR: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/./target/mock5493540701615387120data>
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.205 sec <<< FAILURE!
Results :
Tests in error:
testServiceExists(org.geoserver.printing.SmokeTest)
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/community/printing/target/surefire-reports> for the individual test results.
[INFO] Total time: 10 minutes 7 seconds
[INFO] Finished at: Tue Jan 17 19:45:07 UTC 2012
[INFO] Final Memory: 69M/274M
