See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/626/>
[...truncated 31776 lines...]
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-sources.jar>
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation>
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Chart external graphics support
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/main/resources>
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/test/java>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Feature Generalization Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/src/main/resources>
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/src/test/java>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-test-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/test/java>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-test-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/resources>
[INFO] Compiling 14 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/classes>
[ERROR] BUILD FAILURE
[INFO] Compilation failure
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/QueueController.java>:\[42,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/QueueController.java>:\[47,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/QueueController.java>:\[56,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/IpBlacklistFilter.java>:\[70,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/IpBlacklistFilter.java>:\[107,5\] method does not override a method from its superclass
<http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/java/org/geoserver/flow/controller/IpBlacklistFilter.java>:\[112,5\] method does not override a method from its superclass
[INFO] Total time: 11 minutes 42 seconds
[INFO] Finished at: Wed Feb 29 04:05:11 UTC 2012
[INFO] Final Memory: 78M/302M
