See <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/7/changes>
Changes:
[dany111] GEOS:4311 fixing readParams setting
[...truncated 25319 lines...]
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/validation/target/validation-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/validation/2.1-SNAPSHOT/validation-2.1-SNAPSHOT-sources.jar
[INFO] Building Chart external graphics support
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target>
[INFO] [svn-revision-number:revision {execution: default}]
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/main/resources>
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-charts:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot jfree:eastwood:1.1.1-SNAPSHOT: checking for updates from codehaus
[INFO] snapshot jfree:eastwood:1.1.1-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot jfree:eastwood:1.1.1-SNAPSHOT: checking for updates from osgeo
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f13486e6bc29b4979ed3f3a232ff059a609d713c'; remote = '1568f3f906ad1cf601b8f1ca102b647c274a488c' - RETRYING
[WARNING] *** CHECKSUM FAILED - Checksum failed on download: local = 'f13486e6bc29b4979ed3f3a232ff059a609d713c'; remote = '1568f3f906ad1cf601b8f1ca102b647c274a488c' - IGNORING
[INFO] snapshot jfree:eastwood:1.1.1-SNAPSHOT: checking for updates from maven2-repository.dev.java.net
Downloading: http://download.osgeo.org/webdav/geotools//jfree/eastwood/1.1.1-SNAPSHOT/eastwood-1.1.1-SNAPSHOT.pom
Downloading: http://download.osgeo.org/webdav/geotools//jfree/eastwood/1.1.1-SNAPSHOT/eastwood-1.1.1-SNAPSHOT.jar
[INFO] No sources to compile
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/src/test/java>
[INFO] No tests to run.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-tests.jar>
[INFO] Preparing source:jar
[WARNING] the "build.repository" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.path" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.revision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.mixedRevisions" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.committedRevision" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.status" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[WARNING] the "build.specialStatus" property is already defined, its value will be overwritten. Consider another value for the entry properties prefix.
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/charts/target/charts-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/charts/2.1-SNAPSHOT/charts-2.1-SNAPSHOT-sources.jar
[INFO] Building Feature Generalization Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized>
[INFO] Copying 0 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/src/main/resources>
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-feature-pregeneralized:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/classes>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/src/test/java>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/feature-pregeneralized/target/feature-pregeneralized-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/feature-pregeneralized/2.1-SNAPSHOT/feature-pregeneralized-2.1-SNAPSHOT-sources.jar
[INFO] Building Image Mosaic JDBC Extension
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/main/java>
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/main/resources>
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-imagemosaic-jdbc:2.7-SNAPSHOT: checking for updates from osgeo
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/src/test/java>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar>
[INFO] Building jar: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar>
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-tests.jar
[INFO] Installing <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/imagemosaic-jdbc/target/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar> to /home/tomcat/.m2/repository/org/geoserver/extension/imagemosaic-jdbc/2.1-SNAPSHOT/imagemosaic-jdbc-2.1-SNAPSHOT-sources.jar
[INFO] Building OWS request flow controller
[INFO] Deleting directory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target>
[INFO] inspecting <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow>
[INFO] Copying 1 resource
[INFO] skip non existing resourceDirectory <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/src/main/resources>
[INFO] Compiling 10 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/classes>
[INFO] Compiling 7 source files to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/test-classes>
[INFO] Surefire report directory: <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/surefire-reports>
T E S T S
Running org.geoserver.flow.controller.BasicOWSFlowControllerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.flow.controller.GlobalFlowControllerTest
Thread[Thread-1,5,main] calling requestIncoming
Thread[Thread-1,5,main] waiting
Thread[Thread-1,5,main] calling requestComplete
Thread[Thread-1,5,main] done
Thread[Thread-2,5,main] calling requestIncoming
Thread[Thread-2,5,main] waiting
Thread[Thread-2,5,main] calling requestComplete
Thread[Thread-2,5,main] done
Thread[Thread-3,5,main] calling requestIncoming
Thread[Thread-3,5,main] waiting
Thread[Thread-4,5,main] calling requestIncoming
Thread[Thread-5,5,main] calling requestIncoming
Thread[Thread-3,5,main] calling requestComplete
Thread[Thread-3,5,main] done
Thread[Thread-4,5,main] waiting
Thread[Thread-4,5,main] calling requestComplete
Thread[Thread-4,5,main] done
Thread[Thread-5,5,main] waiting
Thread[Thread-5,5,main] calling requestComplete
Thread[Thread-5,5,main] done
Tests run: 3, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 2.106 sec <<< FAILURE!
Running org.geoserver.flow.ControlFlowCallbackTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Running org.geoserver.flow.controller.UserFlowControllerTest
Thread[Thread-6,5,main] calling requestIncoming
Thread[Thread-6,5,main] waiting
Thread[Thread-6,5,main] calling requestComplete
Thread[Thread-6,5,main] done
Thread[Thread-7,5,main] calling requestIncoming
Thread[Thread-7,5,main] waiting
Thread[Thread-8,5,main] calling requestIncoming
Thread[Thread-7,5,main] calling requestComplete
Thread[Thread-7,5,main] done
Thread[Thread-8,5,main] waiting
Thread[Thread-8,5,main] calling requestComplete
Thread[Thread-8,5,main] done
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.798 sec
Running org.geoserver.flow.config.DefaultControlFlowConfigurationTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Results :
Failed tests:
testTimeout(org.geoserver.flow.controller.GlobalFlowControllerTest)
Tests run: 10, Failures: 1, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to <http://hudson.opengeo.org/hudson/job/geoserver-2.1.x/ws/geoserver-2.1.x/extension/control-flow/target/surefire-reports> for the individual test results.
[INFO] Total time: 11 minutes 22 seconds
[INFO] Finished at: Thu Jan 20 11:05:53 UTC 2011
[INFO] Final Memory: 78M/316M
Failed to send e-mail to dany111 because no e-mail address is known, and no default e-mail domain is configured
