[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1045
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1045/changes
Changes:
[groldan] GEOS-2845, migrated SRSListPanel to the GeoServerTablePanel framework
[groldan] GEOS-2845, i18n resources for the SRS table columns
[groldan] GEOS-2845, added SRSProvider
[...truncated 6109 lines...]
May 2, 2009 5:41:51 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.179 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.516 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.166 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.015 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.567 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.858 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.769 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.421 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.13 sec
Results :
Tests run: 38, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/web-core-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT-sources.jar
[INFO] Building WMS UI Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.6-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/2.6-SNAPSHOT/gt-xsd-sld-2.6-20090502.063211-51.pom
1/4K
4/4K
4K downloaded
Downloading: http://repo.opengeo.org//org/geotools/xsd/gt-xsd-sld/2.6-SNAPSHOT/gt-xsd-sld-2.6-20090502.063211-51.jar
4/75K
8/75K
12/75K
16/75K
20/75K
24/75K
28/75K
32/75K
36/75K
40/75K
44/75K
48/75K
52/75K
56/75K
60/75K
64/75K
68/75K
72/75K
75/75K
75K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 12 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/classes
[INFO] [resources:testResources]
[INFO] snapshot org.geoserver.web:web-core:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver.web:web-core:2.0-SNAPSHOT: checking for updates from osgeo
[INFO] [compiler:testCompile]
[INFO] Compiling 3 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/surefire-reports
T E S T S
Running org.geoserver.wms.web.data.WMSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.21 sec
Running org.geoserver.wms.web.data.StylePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.763 sec
Running org.geoserver.wms.web.data.publish.WMSLayerConfigTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.615 sec
Results :
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.0-SNAPSHOT/web-wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.0-SNAPSHOT/web-wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wms/target/web-wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wms/2.0-SNAPSHOT/web-wms-2.0-SNAPSHOT-sources.jar
[INFO] Building WFS UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target
[INFO] Compiling 2 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/surefire-reports
T E S T S
Running org.geoserver.wfs.web.WFSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.465 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wfs/target/web-wfs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wfs/2.0-SNAPSHOT/web-wfs-2.0-SNAPSHOT-sources.jar
[INFO] Building WCS UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target
[INFO] Compiling 2 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/classes
[INFO] snapshot org.geoserver:wcs1_1:2.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geoserver:wcs1_1:2.0-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 3 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/surefire-reports
T E S T S
Running org.geoserver.wcs.web.data.WCSLayerConfigTest
May 2, 2009 5:42:49 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.6 sec
Running org.geoserver.wcs.web.WCSAdminPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.334 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/wcs/target/web-wcs-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-wcs/2.0-SNAPSHOT/web-wcs-2.0-SNAPSHOT-sources.jar
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target
[INFO] Compiling 8 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/classes
[INFO] Compiling 2 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/surefire-reports
T E S T S
Running org.geoserver.web.demo.MapPreviewPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.551 sec
Running org.geoserver.web.demo.SRSListPageTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.393 sec <<< FAILURE!
Results :
Tests in error:
  testBasicPage(org.geoserver.web.demo.SRSListPageTest)
Tests run: 2, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/demo/target/surefire-reports for the individual test results.
[INFO] Total time: 5 minutes 36 seconds
[INFO] Finished at: Sat May 02 05:43:10 EDT 2009
[INFO] Final Memory: 40M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1046/changes
Changes:
[arneke] Basic GWC functionality restored
[...truncated 3740 lines...]
[INFO] Compiling 111 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/classes
[INFO] Compiling 21 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/target/surefire-reports
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.193 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.785 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.363 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.983 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.157 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
May 4, 2009 1:41:15 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.124 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.644 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.529 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.348 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.945 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.424 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.978 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.698 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.511 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.578 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 6.413 sec
Results :
[INFO] [jar:jar]
T E S T S
May 4, 2009 1:42:08 AM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.777 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.31 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.688 sec
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.388 sec <<< FAILURE!
Results :
Tests in error:
[INFO] Total time: 5 minutes 4 seconds
[INFO] Finished at: Mon May 04 01:42:29 EDT 2009
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1047/changes
