[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1070
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1070/
[...truncated 6520 lines...]
24/66K
28/66K
32/66K
36/66K
40/66K
44/66K
48/66K
52/66K
56/66K
60/66K
64/66K
66/66K
66K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-postgis/2.6-SNAPSHOT/gt-postgis-2.6-20090508.063122-56.jar
4/83K
8/83K
12/83K
16/83K
20/83K
24/83K
28/83K
32/83K
36/83K
40/83K
44/83K
48/83K
52/83K
56/83K
60/83K
64/83K
68/83K
72/83K
76/83K
80/83K
83/83K
83K downloaded
[INFO] [compiler:compile]
[INFO] Compiling 54 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:testCompile]
[INFO] Compiling 8 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/surefire-reports
T E S T S
Running org.geoserver.wfsv.security.ReadOnlyVersioningDataStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.658 sec
Running org.geoserver.wfsv.HistoryRelatedTest
08 May 04:26:05 ERROR [data.postgis] - Could not version enable: archsites
java.io.IOException: This feature type (archsites) is associated to an unsupported fid mapper: class org.geotools.data.jdbc.fidmapper.NullFIDMapper
The supported fid mapper classes are: [class org.geotools.data.jdbc.fidmapper.BasicFIDMapper, class org.geotools.data.jdbc.fidmapper.MultiColumnFIDMapper, class org.geotools.data.postgis.fidmapper.PostGISAutoIncrementFIDMapper]
  at org.geotools.data.postgis.VersionedPostgisDataStore.enableVersioning(VersionedPostgisDataStore.java:1052)
  at org.geotools.data.postgis.VersionedPostgisDataStore.setVersioned(VersionedPostgisDataStore.java:387)
  at org.geotools.data.postgis.VersionedPostgisDataStoreFactory.createDataStore(VersionedPostgisDataStoreFactory.java:155)
  at org.vfny.geoserver.util.DataStoreUtils.getDataStore(DataStoreUtils.java:78)
  at org.geoserver.catalog.ResourcePool.getDataStore(ResourcePool.java:220)
  at org.geoserver.catalog.impl.DataStoreInfoImpl.getDataStore(DataStoreInfoImpl.java:34)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importDataStores(LegacyCatalogImporter.java:358)
  at org.geoserver.catalog.util.LegacyCatalogImporter.importCatalog(LegacyCatalogImporter.java:303)
  at org.geoserver.catalog.util.LegacyCatalogImporter.imprt(LegacyCatalogImporter.java:152)
  at org.geoserver.config.GeoServerLoader.readLegacyCatalog(GeoServerLoader.java:658)
  at org.geoserver.config.GeoServerLoader.loadCatalog(GeoServerLoader.java:159)
  at org.geoserver.config.GeoServerLoader.postProcessBeforeInitialization(GeoServerLoader.java:125)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyBeanPostProcessorsBeforeInitialization(AbstractAutowireCapableBeanFactory.java:350)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.initializeBean(AbstractAutowireCapableBeanFactory.java:1330)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:473)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory$1.run(AbstractAutowireCapableBeanFactory.java:409)
  at java.security.AccessController.doPrivileged(Native Method)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBean(AbstractAutowireCapableBeanFactory.java:380)
  at org.springframework.beans.factory.support.AbstractBeanFactory$1.getObject(AbstractBeanFactory.java:264)
  at org.springframework.beans.factory.support.DefaultSingletonBeanRegistry.getSingleton(DefaultSingletonBeanRegistry.java:221)
  at org.springframework.beans.factory.support.AbstractBeanFactory.doGetBean(AbstractBeanFactory.java:261)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:185)
  at org.springframework.beans.factory.support.AbstractBeanFactory.getBean(AbstractBeanFactory.java:164)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveReference(BeanDefinitionValueResolver.java:269)
  at org.springframework.beans.factory.support.BeanDefinitionValueResolver.resolveValueIfNecessary(BeanDefinitionValueResolver.java:104)
  at org.springframework.beans.factory.support.ConstructorResolver.resolveConstructorArguments(ConstructorResolver.java:495)
  at org.springframework.beans.factory.support.ConstructorResolver.autowireConstructor(ConstructorResolver.java:162)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.autowireConstructor(AbstractAutowireCapableBeanFactory.java:925)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.createBeanInstance(AbstractAutowireCapableBeanFactory.java:835)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:440)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.applyPropertyValues(AbstractAutowireCapableBeanFactory.java:1245)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.populateBean(AbstractAutowireCapableBeanFactory.java:1010)
  at org.springframework.beans.factory.support.AbstractAutowireCapableBeanFactory.doCreateBean(AbstractAutowireCapableBeanFactory.java:472)
  at org.springframework.beans.factory.support.DefaultListableBeanFactory.preInstantiateSingletons(DefaultListableBeanFactory.java:429)
  at org.springframework.context.support.AbstractApplicationContext.finishBeanFactoryInitialization(AbstractApplicationContext.java:729)
  at org.springframework.context.support.AbstractApplicationContext.refresh(AbstractApplicationContext.java:381)
  at org.geoserver.test.GeoServerAbstractTestSupport.oneTimeSetUp(GeoServerAbstractTestSupport.java:173)
  at org.geoserver.wfsv.WFSVTestSupport.oneTimeSetUp(WFSVTestSupport.java:38)
  at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:21)
  at org.geoserver.test.OneTimeSetupTest$OneTimeTestSetup.setUp(OneTimeSetupTest.java:51)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:20)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
08 May 04:26:14 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSTransactionException: {http://www.openplans.org/topp\}archsites is read-only
  at org.geoserver.wfs.Transaction.execute(Transaction.java:273)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:109)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:163)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy14.transaction(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:574)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:511)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:639)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:586)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:566)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:775)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:758)
  at org.geoserver.wfsv.HistoryRelatedTest.oneTimeSetUp(HistoryRelatedTest.java:56)
Tests run: 1, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 52.096 sec <<< FAILURE!
Running org.geoserver.wfsv.LogOrderTest
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.17 sec <<< FAILURE!
Running org.geoserver.wfsv.DescribeVersionedFeatureTypeTest
log4j:WARN File option not set for appender [geoserverlogfile].
log4j:WARN Are you using FileAppender instead of ConsoleAppender?
log4j:ERROR No output stream or file set for the appender named [geoserverlogfile].
08 May 04:26:16 WARN [data.tes] - Error executing "DROP TABLE tables_changed cascade;": ERROR: table "tables_changed" does not exist
08 May 04:26:16 WARN [data.tes] - Error executing "DROP TABLE versioned_tables cascade;": ERROR: table "versioned_tables" does not exist
08 May 04:26:16 WARN [data.tes] - Error executing "DROP TABLE changesets cascade;": ERROR: table "changesets" does not exist
08 May 04:26:16 WARN [data.tes] - Error executing "ALTER TABLE ONLY archsites ADD CONSTRAINT archsites_pkey PRIMARY KEY (gid);": ERROR: relation "archsites_pkey" already exists
08 May 04:26:16 INFO [test.GeoServerTestApplicationContext] - Refreshing org.geoserver.test.GeoServerTestApplicationContext@anonymised.com: display name [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]; startup date [Fri May 08 04:26:16 EDT 2009]; root of context hierarchy
08 May 04:26:16 INFO [test.GeoServerTestApplicationContext] - Bean factory for application context [org.geoserver.test.GeoServerTestApplicationContext@anonymised.com]: org.springframework.beans.factory.support.DefaultListableBeanFactory@anonymised.com
08 May 04:26:16 INFO [test.GeoServerTestApplicationContext] - Bean 'resourceLoader' is not eligible for getting processed by all BeanPostProcessors (for example: not eligible for auto-proxying)
08 May 04:26:16 WARN [support.DisposableBeanAdapter] - Invocation of destroy method failed on bean with name 'geoServerLoader': java.lang.NullPointerException
Tests run: 1, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 0.631 sec <<< FAILURE!
Running org.geoserver.wfsv.security.ReadOnlyVersioningFeatureStoreTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.023 sec
Running org.geoserver.wfsv.RollbackTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.077 sec <<< FAILURE!
Results :
Failed tests:
Tests in error:
  testRollbackWfs11(org.geoserver.wfsv.RollbackTest)
  testRollbackWfs10(org.geoserver.wfsv.RollbackTest)
  testInvalidRollback(org.geoserver.wfsv.RollbackTest)
Tests run: 10, Failures: 1, Errors: 5, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/wfsv/target/surefire-reports for the individual test results.
[INFO] Total time: 6 minutes 49 seconds
[INFO] Finished at: Fri May 08 04:26:17 EDT 2009
[INFO] Final Memory: 45M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1071/
