See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1077/changes
Changes:
[groldan] GEOS-3025, port DataStoreUtils to DataAccess
[...truncated 6153 lines...]
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.415 sec
Running org.geoserver.filters.ReverseProxyFilterTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.045 sec
Running org.geoserver.filters.BufferedRequestStreamTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.318 sec
Running org.geoserver.web.WebXmlTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.047 sec
Results :
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [config:config {execution: configPackage}]
config:
[echo] Copying data dir from http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal
[copy] Copying 14 files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[copy] Copied 12 empty directories to 9 empty directories under http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/main/webapp/data
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/web-app-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-app/2.0-SNAPSHOT/web-app-2.0-SNAPSHOT-sources.jar
[INFO] [war:war {execution: default}]
[INFO] Packaging webapp
[INFO] Assembling webapp[web-app] in [http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver\]
[INFO] Processing war project
[INFO] Webapp assembled in[1474 msecs]
[INFO] Building war: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/target/geoserver.war
[INFO] Building GeoServer Extensions
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/pom.xml to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/target/extension-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/2.0-SNAPSHOT/extension-2.0-SNAPSHOT-tests.jar
[INFO] Building ArcSDE DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-arcsde:2.6-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde/2.6-SNAPSHOT/gt-arcsde-2.6-20090512.010536-58.pom
3/8K
7/8K
8/8K
8K downloaded
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:arcsde-plugin:2.6-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/arcsde-plugin/2.6-SNAPSHOT/arcsde-plugin-2.6-20090512.010536-59.pom
3/3K
3K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-arcsde/2.6-SNAPSHOT/gt-arcsde-2.6-20090512.010536-58.jar
4/289K
8/289K
12/289K
16/289K
20/289K
24/289K
28/289K
32/289K
36/289K
40/289K
44/289K
48/289K
52/289K
56/289K
60/289K
64/289K
68/289K
72/289K
76/289K
80/289K
84/289K
88/289K
92/289K
96/289K
100/289K
104/289K
108/289K
112/289K
116/289K
120/289K
124/289K
128/289K
132/289K
136/289K
140/289K
144/289K
148/289K
152/289K
156/289K
160/289K
164/289K
168/289K
172/289K
176/289K
180/289K
184/289K
188/289K
192/289K
196/289K
200/289K
204/289K
208/289K
212/289K
216/289K
220/289K
224/289K
228/289K
232/289K
236/289K
240/289K
244/289K
248/289K
252/289K
256/289K
260/289K
264/289K
268/289K
272/289K
276/289K
280/289K
284/289K
288/289K
289/289K
289K downloaded
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/arcsde/target/arcsde-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/extension/arcsde/2.0-SNAPSHOT/arcsde-2.0-SNAPSHOT-sources.jar
[INFO] Building H2 DataStore Extension
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt-jdbc-h2:2.6-SNAPSHOT: checking for updates from osgeo
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-h2/2.6-SNAPSHOT/gt-jdbc-h2-2.6-20090512.010536-58.pom
1/3K
3/3K
3K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-h2/2.6-SNAPSHOT/gt-jdbc-h2-2.6-20090512.010536-58.jar
4/16K
8/16K
12/16K
16/16K
16/16K
16K downloaded
Downloading: http://repo.opengeo.org//org/geotools/gt-jdbc-core/2.6-SNAPSHOT/gt-jdbc-core-2.6-20090512.010536-58-tests.jar
3/79K
5/79K
7/79K
8/79K
12/79K
16/79K
20/79K
24/79K
28/79K
32/79K
36/79K
40/79K
44/79K
48/79K
52/79K
55/79K
59/79K
63/79K
67/79K
71/79K
75/79K
79/79K
79/79K
79K downloaded
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/classes
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/target/test-classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/h2/src/test/java/org/geoserver/h2/H2DataStoreInitializerTest.java :[17,60] incompatible types
found : org.geotools.data.DataAccessFactory
required: org.geotools.data.DataStoreFactorySpi
[INFO] Total time: 5 minutes 53 seconds
[INFO] Finished at: Mon May 11 23:40:40 EDT 2009
[INFO] Final Memory: 43M/63M
