[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1081
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1081/changes
Changes:
[aaime] GEOS-2945) make a CatalogRemovalHelper that allows to list dependent resources and to actually remove them
[aaime] Fixing module name (copy and paste error)
[...truncated 5369 lines...]
         <longitude>180.0</longitude>
         <latitude>0.0</latitude>
         <altitude>0</altitude>
         <range>1.2742E7</range>
         <tilt>0</tilt>
         <heading>0</heading>
         <altitudeMode>clampToGround</altitudeMode>
      </LookAt>
   </Folder>
</kml>
13 May 13:39:25 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.423 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTimeTemplateTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.199 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.823 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.georss.RSSGeoRSSTransformerTest
<rss xmlns:atom="http://www.w3.org/2005/Atom&quot; xmlns:georss="http://www.georss.org/georss&quot; version="2.0">
  <channel>
    <title/>
    <description>Feed auto-generated by GeoServer</description>
    <link><![CDATA[http://localhost:80/geoserver/wms?service=wms&srs=EPSG%3A4326&width=0&styles=BasicPolygons&height=0&transparent=false&bbox=-180.0%2C90.0%2C-90.0%2C180.0&request=GetMap&layers=cite%3ABasicPolygons&format=&version=1.1.1]]></link>
    <atom:link href="http://localhost:80/geoserver/wms?service=wms&amp;srs=EPSG%3A4326&amp;width=0&amp;styles=BasicPolygons&amp;height=0&amp;transparent=false&amp;bbox=-180.0%2C90.0%2C-90.0%2C180.0&amp;request=GetMap&amp;layers=cite%3ABasicPolygons&amp;format=&amp;version=1.1.1&quot; rel="self"/>
    <item>
      <title>BasicPolygons.1107531493630</title>
      <link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493630]]></link>
      <guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493630]]></guid>
      <description><![CDATA[<h4>BasicPolygons</h4>
<ul class="textattributes">
</ul>
]]></description>
      <georss:polygon>0.0 -1.0 1.0 0.0 0.0 1.0 -1.0 0.0 0.0 -1.0</georss:polygon>
    </item>
    <item>
      <title>BasicPolygons.1107531493643</title>
      <link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493643]]></link>
      <guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493643]]></guid>
</ul>
]]></description>
      <georss:polygon>6.0 -2.0 6.0 1.0 3.0 1.0 3.0 -2.0 6.0 -2.0</georss:polygon>
    </item>
    <item>
      <title>BasicPolygons.1107531493644</title>
      <link><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></link>
      <guid><![CDATA[http://localhost:80/geoserver/wms/reflect?format=application/atom+xml&layers=cite:BasicPolygons&featureid=BasicPolygons.1107531493644]]></guid>
</ul>
]]></description>
      <georss:polygon>5.0 -1.0 5.0 2.0 2.0 2.0 2.0 -1.0 5.0 -1.0</georss:polygon>
    </item>
  </channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.314 sec
Running org.vfny.geoserver.wms.responses.palette.CustomPaletteBuilderTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.042 sec
Running org.geoserver.wms.WMSExtensionsTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.vfny.geoserver.wms.responses.map.svg.SVGMapProducerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.169 sec
Running org.vfny.geoserver.wms.responses.GetCapabilitiesTest
May 13, 2009 1:39:28 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.306 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.051 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.731 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: -0.022 sec
Running org.geoserver.wms.responses.MapDecorationLayoutTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.006 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.25 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
May 13, 2009 1:39:29 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.181 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.188 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.304 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
13 May 13:39:32 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
  at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:108)
  at org.geoserver.wms.kvp.WMSKvpRequestReaderAdapter.createRequest(WMSKvpRequestReaderAdapter.java:72)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1089)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:435)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:193)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor100.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
<ServiceExceptionReport version="1.1.1"> <ServiceException code="InvalidParameterValue" locator="info_format">
</ServiceException>
</ServiceExceptionReport>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.35 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
13 May 13:39:33 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:619)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:709)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.926 sec
Running org.vfny.geoserver.wms.responses.map.legend.GetLegendGraphicKvpReaderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.137 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.374 sec
Results :
Tests in error:
  testDynamicSymbolizer(org.vfny.geoserver.wms.responses.map.kml.KMLTransformerTest)
Tests run: 155, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 47 seconds
[INFO] Finished at: Wed May 13 13:39:35 EDT 2009
[INFO] Final Memory: 39M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1082/changes
Changes:
[aaime] First tentative at a cascade delete in workspaces. Still very rough, but working
[aaime] A panel that summarizes, in a generic way, what will be the results of a cascade delete (one panel to rule them all, or else, to avoid making a different one for each kind of cascade delete)
[aaime] Generic dialog with ok/cancel button. The looks of it still aren't right, but my css-fu is still not up to the task
[aaime] GEOS-3039) Speed up i18n string lookup
[aaime] Long forgotten trunk forward port: making sure like comparisong with case sensitive enabled/disable work
[...truncated 2974 lines...]
         <tilt>0</tilt>
      </LookAt>
   </Folder>
</kml>
13 May 14:38:19 ERROR [org.geoserver] - Extension lookup occured, but ApplicationContext is unset.
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.429 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.197 sec
Tests run: 10, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.778 sec <<< FAILURE!
  <channel>
    <title/>
    <item>
</ul>
]]></description>
    </item>
    <item>
</ul>
]]></description>
    </item>
    <item>
</ul>
]]></description>
    </item>
  </channel>
</rss>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.321 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.044 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.17 sec
May 13, 2009 2:38:22 PM java.util.prefs.FileSystemPreferences$7 run
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.307 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.05 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.755 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.27 sec
May 13, 2009 2:38:23 PM org.geoserver.wms.WMSTestSupport assertNotBlank
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.149 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.305 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
13 May 14:38:26 ERROR [geoserver.ows] -
</ServiceException>
Tests run: 9, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.279 sec
13 May 14:38:27 ERROR [geoserver.ows] -
java.io.IOException
  ... 44 more
  ... 46 more
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.965 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.14 sec
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.01 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.412 sec
Results :
Tests in error:
[INFO] Total time: 2 minutes 55 seconds
[INFO] Finished at: Wed May 13 14:38:29 EDT 2009
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1083/changes
