[Geoserver-devel] Build failed in Hudson: geoserver-trunk #111
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/111/changes
[...truncated 1682 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.928 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
24 Apr 18:35:39 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
24 Apr 18:35:39 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.484 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.128 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.356 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.4 sec
Running org.geoserver.wfs.ReprojectionTest
<wfs:FeatureCollection xmlns:wfs="http://www.opengis.net/wfs&quot; xmlns="http://www.opengis.net/wfs&quot; xmlns:cite="http://www.opengis.net/cite&quot; xmlns:gml="http://www.opengis.net/gml&quot; xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/cite http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.0.0&amp;request=DescribeFeatureType&amp;typeName=cite:GoogleFeatures http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.0.0/WFS-basic.xsd&quot;&gt;
<gml:boundedBy>
<gml:Box srsName="http://www.opengis.net/gml/srs/epsg.xml#900913&quot;&gt;
<gml:coordinates cs="," decimal="." ts=" " xmlns:gml="http://www.opengis.net/gml&quot;&gt;0,\-0 1113194.90793274,1118889.97485796</gml:coordinates>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:GoogleFeatures fid="GoogleGeometries.1">
<cite:the_geom>
<gml:LineString srsName="http://www.opengis.net/gml/srs/epsg.xml#900913&quot;&gt;
</gml:LineString>
</cite:the_geom>
<cite:name>Google</cite:name>
</cite:GoogleFeatures>
</gml:featureMember>
</wfs:FeatureCollection>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.388 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.921 sec
Running org.geoserver.wfs.MaxFeaturesTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.308 sec
Running org.geoserver.wfs.DescribeFeatureTest
24 Apr 18:35:43 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:131)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:497)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:190)
  at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:874)
  at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:808)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:523)
  at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:463)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:869)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsServletResponse(GeoServerAbstractTestSupport.java:545)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:520)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:679)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:662)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:38)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:115)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor96.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.26 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.252 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.468 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.164 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.264 sec
Results :
Tests run: 129, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] snapshot org.geotools.ogc:net.opengis.wfsv:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] [compiler:compile]
[INFO] Compiling 43 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 4 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports
T E S T S
Running org.getoserver.wfsv.DescribeVersionedFeatureTypeTest
Apr 24, 2008 6:35:50 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
WARNING: Skipping class org.getoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost10 since test data is not available
WARNING: Skipping class org.getoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet10 since test data is not available
WARNING: Skipping class org.getoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesPost11 since test data is not available
WARNING: Skipping class org.getoserver.wfsv.DescribeVersionedFeatureTypeTest.testDescribeArcsitesGet11 since test data is not available
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Running org.getoserver.wfsv.RollbackTest
WARNING: Skipping class org.getoserver.wfsv.RollbackTest.testRollbackWfs11 since test data is not available
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.getoserver.wfsv.HistoryRelatedTest
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetFeatureBeforeAfter since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testVersionedFeatureCollection since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testLog since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testLogHtml since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiff since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiffHtml since test data is not available
WARNING: Skipping class org.getoserver.wfsv.HistoryRelatedTest.testGetDiffReverse since test data is not available
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Tests run: 12, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] snapshot org.geotools:gt-render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-xsd-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/src/main/java/org/vfny/geoserver/wms/responses/PaletteExtractor.java :[57,7] org.vfny.geoserver.wms.responses.PaletteExtractor is not abstract and does not override abstract method visit(org.geotools.styling.ShadedRelief) in org.geotools.styling.StyleVisitor
[INFO] Total time: 2 minutes 8 seconds
[INFO] Finished at: Thu Apr 24 18:35:56 EDT 2008
[INFO] Final Memory: 31M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/112/changes
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.58 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.256 sec
25 Apr 11:41:27 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Apr 11:41:27 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.524 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.124 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.92 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.896 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:the_geom>
</gml:LineString>
</cite:the_geom>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.676 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.168 sec
25 Apr 11:41:32 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.224 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.112 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.392 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.18 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Results :
[INFO] [jar:jar]
T E S T S
Apr 25, 2008 11:41:38 AM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.144 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 2 minutes 6 seconds
[INFO] Finished at: Fri Apr 25 11:41:44 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/113/changes
Changes:
[groldan] pending javadocs
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.784 sec
25 Apr 12:38:23 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Apr 12:38:23 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.236 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.448 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.964 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.804 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.408 sec
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:the_geom>
</gml:LineString>
</cite:the_geom>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.652 sec
25 Apr 12:38:27 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.216 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.108 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.24 sec
Results :
[INFO] [jar:jar]
T E S T S
Apr 25, 2008 12:38:33 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.16 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 2 minutes 1 second
[INFO] Finished at: Fri Apr 25 12:38:38 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/114/changes
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.76 sec
25 Apr 12:57:30 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Apr 12:57:30 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.248 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.472 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.332 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.332 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.416 sec
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:the_geom>
</gml:LineString>
</cite:the_geom>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.368 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.62 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.172 sec
25 Apr 12:57:34 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.208 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.244 sec
Results :
[INFO] [jar:jar]
T E S T S
Apr 25, 2008 12:57:39 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Apr 25, 2008 12:57:40 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 1 minute 57 seconds
[INFO] Finished at: Fri Apr 25 12:57:44 EDT 2008
[INFO] Final Memory: 35M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/115/changes
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.785 sec
25 Apr 14:17:11 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Apr 14:17:11 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.26 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.984 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.736 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.392 sec
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:the_geom>
</gml:LineString>
</cite:the_geom>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.656 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
25 Apr 14:17:15 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.248 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.296 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.176 sec
Results :
[INFO] [jar:jar]
T E S T S
Apr 25, 2008 2:17:21 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.156 sec
Results :
[INFO] [jar:jar]
[INFO] Finished at: Fri Apr 25 14:17:26 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/116/changes
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.896 sec
25 Apr 16:08:00 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
25 Apr 16:08:00 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.864 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.512 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.132 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.496 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.576 sec
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.432 sec
<gml:boundedBy>
</gml:Box>
</gml:boundedBy>
<gml:featureMember>
<cite:the_geom>
</gml:LineString>
</cite:the_geom>
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.34 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.64 sec
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.188 sec
25 Apr 16:08:05 ERROR [geoserver.ows] -
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.212 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.148 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.492 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.204 sec
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.316 sec
Results :
[INFO] [jar:jar]
T E S T S
Apr 25, 2008 4:08:11 PM org.geoserver.test.GeoServerAbstractTestSupport runTest
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.028 sec
Results :
[INFO] [jar:jar]
[INFO] Finished at: Fri Apr 25 16:08:17 EDT 2008
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/117/changes
Changes:
[groldan] avoid NPE if there are no service keywords
[...truncated 4550 lines...]
7232/520K
7235/520K
7238/520K
7240/520K
7241/520K
7242/520K
7246/520K
7250/520K
7254/520K
7257/520K
7258/520K
7262/520K
7266/520K
7270/520K
7274/520K
7278/520K
7279/520K
7282/520K
7283/520K
7285/520K
7286/520K
7288/520K
7289/520K
7291/520K
7293/520K
7296/520K
7300/520K
7302/520K
7303/520K
7306/520K
7310/520K
7310/520K
7312/520K
7316/520K
7319/520K
7323/520K
7327/520K
7331/520K
7332/520K
7333/520K
7334/520K
7337/520K
7340/520K
7343/520K
7344/520K
7346/520K
7349/520K
7350/520K
7354/520K
7358/520K
7362/520K
7366/520K
7370/520K
7374/520K
7378/520K
7382/520K
7384/520K
7385/520K
7388/520K
7390/520K
7392/520K
7396/520K
7399/520K
7401/520K
7402/520K
7405/520K
7406/520K
7408/520K
7409/520K
7413/520K
7417/520K
7421/520K
7425/520K
7429/520K
7433/520K
7437/520K
7441/520K
7445/520K
7449/520K
7453/520K
7457/520K
7460/520K
7462/520K
7464/520K
7467/520K
7469/520K
7470/520K
7473/520K
7476/520K
7479/520K
7483/520K
7487/520K
7491/520K
7495/520K
7499/520K
7503/520K
7507/520K
7511/520K
7514/520K
7517/520K
7520/520K
7521/520K
7522/520K
7524/520K
7528/520K
7528/520K
7530/520K
7531/520K
7535/520K
7537/520K
7538/520K
7542/520K
7546/520K
7550/520K
7554/520K
7556/520K
7560/520K
7564/520K
7568/520K
7572/520K
7576/520K
7580/520K
7584/520K
7588/520K
7592/520K
7596/520K
7600/520K
7604/520K
7604/520K
7606/520K
7607/520K
7611/520K
7614/520K
7616/520K
7617/520K
7619/520K
7623/520K
7627/520K
7631/520K
7635/520K
7639/520K
7643/520K
7647/520K
7651/520K
7654/520K
7655/520K
7657/520K
7658/520K
7660/520K
7661/520K
7665/520K
7669/520K
7673/520K
7677/520K
7681/520K
7684/520K
7685/520K
7686/520K
7688/520K
7689/520K
7691/520K
7694/520K
7695/520K
7698/520K
7699/520K
7701/520K
7702/520K
7706/520K
7710/520K
7714/520K
7716/520K
520K downloaded
7717/50K
7719/50K
7720/50K
7721/50K
7723/50K
7724/50K
7727/50K
7731/50K
7735/50K
7737/50K
7738/50K
7740/50K
7744/50K
7748/50K
7752/50K
7756/50K
7757/50K
7760/50K
7762/50K
7766/50K
50K downloaded
7768/78K
7769/78K
7771/78K
7772/78K
7776/78K
7778/78K
7779/78K
7780/78K
7782/78K
7783/78K
7785/78K
7789/78K
7793/78K
7793/78K
7795/78K
7796/78K
7797/78K
7800/78K
7802/78K
7803/78K
7805/78K
7809/78K
7813/78K
7817/78K
7821/78K
7823/78K
7824/78K
7826/78K
7827/78K
7830/78K
7834/78K
7837/78K
7838/78K
7842/78K
7845/78K
78K downloaded
[INFO] Total time: 4 minutes 10 seconds
[INFO] Finished at: Mon Apr 28 05:40:49 EDT 2008
[INFO] Final Memory: 33M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/118/changes
