[Geoserver-devel] Build failed in Hudson: geoserver-trunk #113
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/113/changes
Changes:
[jdeolive] GEOS-1678, spelling mistake
[aaime] Don't set the forcexy flag at startup, it makes the URN factory go bye bye (don't know why, but it happens)
[...truncated 120 lines...]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] [resources:testResources]
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt2-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 1 source file to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] snapshot org.geotools:gt2-xml-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.beans.factory.xml.XmlBeanDefinitionReader).
log4j:WARN Please initialize the log4j system properly.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.528 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
<ows:ExceptionReport version="1.0.0"
  xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
  xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xmlns:ows="http://www.opengis.net/ows&quot;&gt;
  <ows:Exception exceptionCode="helloCode" locator="helloLocator">
    <ows:ExceptionText>hello service exception
helloText
I/O exception here
Illegal argument here</ows:ExceptionText>
    <ows:ExceptionText>helloText</ows:ExceptionText>
  </ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.104 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.008 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 116 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/src/main/java/org/vfny/geoserver/config/CoverageConfig.java :[284,27] cannot find symbol
symbol : method getDimensionNames()
location: class org.geotools.coverage.grid.GridCoverage2D
[INFO] Total time: 27 seconds
[INFO] Finished at: Wed Jan 16 17:31:45 EST 2008
[INFO] Final Memory: 26M/49M
Updating GEOS-1678
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/114/changes
Changes:
[jdeolive] commenting out dependency on xmlcodegen plugin
[...truncated 115 lines...]
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.52 sec
helloText
I/O exception here
  </ows:Exception>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.048 sec
Results :
[INFO] [jar:jar]
[INFO] Finished at: Wed Jan 16 19:31:42 EST 2008
[INFO] Final Memory: 25M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/115/changes
[...truncated 109 lines...]
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
T E S T S
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.532 sec
helloText
I/O exception here
  </ows:Exception>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.068 sec
Results :
[INFO] [jar:jar]
[INFO] Total time: 26 seconds
[INFO] Finished at: Thu Jan 17 01:12:21 EST 2008
[INFO] Final Memory: 26M/53M
I was trying to launch Geoserver built from sources (in OSX) with the release configuration, for having the various demos available as suggested by Andrea. But neither the
export GEOSERVER_DATA_DIR=/Users/superandrew/Documents/Tesi/geoserver/configuration/release
mvn jetty:run
or
mvn jetty:run -DGEOSERVER_DATA_DIR=/Users/superandrew/Documents/Tesi/geoserver/configuration/release
Seems to work. I can't see any sample data or demo, and during the startup i see
- GEOSERVER_DATA_DIR: /Users/superandrew/Documents/Tesi/geoserver/web/src/main/webapp/data
on the startup output.
Am i missing something?
Thanks
Andrea Maschio
http://www.superandrew.it
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/116/changes
Changes:
[aaime] Fixing the build after yet another deprecated method has been removed in GeoTools
[...truncated 249 lines...]
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.54 sec
helloText
I/O exception here
  </ows:Exception>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.088 sec
Results :
[INFO] [jar:jar]
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
T E S T S
Running org.geoserver.template.FeatureWrapperTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.408 sec
Running org.geoserver.template.GeoServerTemplateLoaderTest
Jan 17, 2008 5:31:44 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/test55174template
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.056 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/main-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/main/1.7.0-SNAPSHOT/main-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Coverage Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target
[INFO] snapshot org.geotools:gt2-arcgrid:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-arcgrid:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-plugin:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-customstreams:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot it.geosolutions.imageio-ext:imageio-ext-library:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-geotiff:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-gtopo30:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-image:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-imagemosaic:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 34 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs/target/wcs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wcs/1.7.0-SNAPSHOT/wcs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Validation Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target
[INFO] Compiling 6 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/validation/target/validation-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/validation/1.7.0-SNAPSHOT/validation-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target
[INFO] Compiling 80 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfs/target/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfs/1.7.0-SNAPSHOT/net.opengis.wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Feature Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 160 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/classes
[INFO] snapshot org.geoserver:main:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 31 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports
Failed to load Main-Class manifest attribute from
/tmp/surefirebooter27126.jar
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports for the individual test results.
[INFO] Total time: 45 seconds
[INFO] Finished at: Thu Jan 17 05:31:59 EST 2008
[INFO] Final Memory: 30M/63M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/117/changes
Changes:
[aaime] Made test less chatty
[aaime] Added ows 1.1 style negotiation abilities to wcs 1.1.1
[aaime] GEOS-1644, Disable the clibpngimagereader by default
[aaime] Added methods to support wcs 1.1.1 style of operation
[...truncated 499 lines...]
[INFO] [jar:jar]
T E S T S
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
helloText
I/O exception here
  </ows:Exception>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.1 sec
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Results :
[INFO] [jar:jar]
T E S T S
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.396 sec
Jan 17, 2008 10:31:45 AM org.vfny.geoserver.global.GeoserverDataDirectory init
SEVERE:
- GEOSERVER_DATA_DIR: /tmp/test51721template
Results :
[INFO] [jar:jar]
[INFO] [jar:jar]
[INFO] [jar:jar]
Downloading: http://lists.refractions.net/m2//org/opengis/geoapi/2.2-SNAPSHOT/geoapi-2.2-20080117.121832-6.pom
1/1K
3/1K
1K downloaded
[INFO] [jar:jar]
/tmp/surefirebooter42415.jar
[INFO] Finished at: Thu Jan 17 10:32:00 EST 2008
Updating GEOS-1644
[INFO] Compiling 31 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/test-classes [INFO] [surefire:test]
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/surefire-reports Failed to load Main-Class manifest attribute from
Hum, this one is odd and seems to be a local problem of the build server?
Hi Andrea,
Unfortunately jetty wont pass through automatically properties set on
the command line... or environment variables defined. What you will have
to do is edit web/pom.xml. Search for GEOSERVER_DATA_DIR (it should be
in an element which is commented out). Uncomment it and set it
appropriately.
-Justin
mvn jetty:run
or
startup i see
Thanks
Andrea Maschio
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
!DSPAM:4007,478f078f58551804284693!
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/118/changes
