[Geoserver-devel] Build failed in Hudson: geoserver-trunk #12
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/12/changes
Changes:
[jdeolive] GEOS-1682, removing stale jars for arcsde and mysql extensions
[...truncated 77 lines...]
[INFO] snapshot org.geotools:gt2-modules:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-referencing:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-referencing:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-metadata:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-metadata:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:geoapi:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:geoapi:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:parent:2.2-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.opengis:parent:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-main:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-main:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building GeoServer Maven Plugins
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-plugin-plugin/2.4.1/maven-plugin-plugin-2.4.1.pom
1/8K
2/8K
4/8K
8/8K
8/8K
8K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugins/maven-plugin-plugin/2.4.1/maven-plugin-plugin-2.4.1.jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugins/maven-plugin-plugin/2.4.1/maven-plugin-plugin-2.4.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugins/maven-plugin-plugin/2.4.1/maven-plugin-plugin-2.4.1.jar
1/30K
2/30K
4/30K
7/30K
9/30K
11/30K
12/30K
14/30K
15/30K
18/30K
21/30K
25/30K
26/30K
28/30K
30/30K
30K downloaded
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.pom
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.pom
1/2K
2/2K
2K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools/2.4.1/maven-plugin-tools-2.4.1.pom
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools/2.4.1/maven-plugin-tools-2.4.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools/2.4.1/maven-plugin-tools-2.4.1.pom
1/9K
2/9K
4/9K
5/9K
7/9K
9/9K
9K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.pom
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.pom
1/3K
2/3K
3/3K
3K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.pom
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.pom
1/2K
2/2K
2K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.pom
Downloading: http://lists.refractions.net/m2//org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.pom
Downloading: http://repo1.maven.org/maven2/org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.pom
2/2K
2K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/reporting/maven-reporting-impl/2.0.4.1/maven-reporting-impl-2.0.4.1.jar
1/18K
2/18K
4/18K
5/18K
7/18K
8/18K
9/18K
11/18K
12/18K
14/18K
15/18K
18/18K
18K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-java/2.4.1/maven-plugin-tools-java-2.4.1.jar
1/15K
2/15K
4/15K
5/15K
7/15K
11/15K
11/15K
12/15K
15/15K
15K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-api/2.4.1/maven-plugin-tools-api-2.4.1.jar
1/43K
2/43K
4/43K
5/43K
7/43K
8/43K
9/43K
11/43K
12/43K
14/43K
15/43K
16/43K
18/43K
19/43K
21/43K
22/43K
24/43K
25/43K
26/43K
28/43K
29/43K
31/43K
32/43K
33/43K
35/43K
39/43K
41/43K
43/43K
43K downloaded
Downloading: http://www.mortbay.org/maven2/snapshot/org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.jar
Downloading: http://lists.refractions.net/m2//org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.jar
Downloading: http://repo1.maven.org/maven2/org/apache/maven/plugin-tools/maven-plugin-tools-beanshell/2.4.1/maven-plugin-tools-beanshell-2.4.1.jar
1/12K
2/12K
5/12K
7/12K
9/12K
11/12K
12/12K
12K downloaded
[INFO] [plugin:descriptor]
[ERROR] FATAL ERROR
[INFO] org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
[INFO] Trace
java.lang.NoSuchMethodError: org.apache.maven.tools.plugin.scanner.MojoScanner.setActiveExtractors(Ljava/util/Set;)V
  at org.apache.maven.plugin.plugin.AbstractGeneratorMojo.execute(AbstractGeneratorMojo.java:116)
  at org.apache.maven.plugin.DefaultPluginManager.executeMojo(DefaultPluginManager.java:443)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoals(DefaultLifecycleExecutor.java:539)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalWithLifecycle(DefaultLifecycleExecutor.java:480)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoal(DefaultLifecycleExecutor.java:459)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeGoalAndHandleFailures(DefaultLifecycleExecutor.java:311)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.executeTaskSegments(DefaultLifecycleExecutor.java:278)
  at org.apache.maven.lifecycle.DefaultLifecycleExecutor.execute(DefaultLifecycleExecutor.java:143)
  at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:334)
  at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:125)
  at org.apache.maven.cli.MavenCli.main(MavenCli.java:280)
  at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
  at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
  at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
  at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
[INFO] Total time: 24 minutes 4 seconds
[INFO] Finished at: Tue Mar 25 23:41:10 EDT 2008
[INFO] Final Memory: 19M/38M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/13/changes
started
Updating https://svn.codehaus.org/geoserver/trunk/geoserver
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/minimal
At revision 8622
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/img
At revision 6610
Fetching 'http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/community/community-schemas/web-c/src/main/webapp/openlayers/lib
At revision 6610
Fetching 'http://svn.codehaus.org/geoserver/trunk/configuration/minimal’ at -1 into 'http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/web/minimal
At revision 8622
At revision 8622
no change for https://svn.codehaus.org/geoserver/trunk/geoserver since the previous build
no change for http://svn.codehaus.org/geoserver/trunk/configuration/minimal since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/img since the previous build
no change for http://svn.openlayers.org/tags/openlayers/release-2.4-rc1/lib since the previous build
[geoserver] $ /opt/maven2/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M clean install
[INFO] Scanning for projects...
[INFO] Reactor build order:
[INFO] GeoServer
[INFO] GeoServer Maven Plugins
[INFO] Plugins configuration files
[INFO] Configuration Deployment PlugIn
[INFO] Core Platform Module
[INFO] Data Module
[INFO] Open Web Service Model
[INFO] Open Web Service Module
[INFO] Main Module
[INFO] Web Coverage Service Module
[INFO] Open Web Service Model v1.1.0
[INFO] Web Coverage Service Model v1.1.1
[INFO] Web Coverage Service 1.1.1 Module
[INFO] Validation Module
[INFO] Web Feature Service Model
[INFO] Web Feature Service Module
[INFO] Versioning Web Feature Service Model
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Test Module
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from opengeo
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] snapshot org.geotools:gt2-api:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-api:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-library:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools:gt2-library:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-modules:2.5-SNAPSHOT: checking for updates from opengeo
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Total time: 12 seconds
[INFO] Finished at: Wed Mar 26 14:27:53 EDT 2008
[INFO] Final Memory: 19M/37M
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/14/changes
Changes:
[groldan] GEOS-1815,added Service.getCharset() and sets the encoding charset to the WCS transformers
started
U main/src/main/java/org/vfny/geoserver/global/Service.java
U main/src/main/java/org/vfny/geoserver/global/GeoServer.java
U wcs/src/main/java/org/vfny/geoserver/wcs/responses/DescribeResponse.java
U wcs/src/main/java/org/vfny/geoserver/wcs/responses/WCSCapabilitiesResponse.java
U wcs/src/main/java/org/vfny/geoserver/wcs/servlets/Describe.java
U wcs1_1/src/main/java/org/geoserver/wcs/DefaultWebCoverageService111.java
U ows/src/main/java/org/geoserver/ows/OWS.java
At revision 8627
At revision 6613
At revision 6613
At revision 8627
At revision 8627
[INFO] GeoServer
[INFO] Data Module
[INFO] Main Module
[INFO] Test Module
[INFO] [jar:jar]
[ERROR] FATAL ERROR
[INFO] Trace
[INFO] Finished at: Wed Mar 26 16:40:23 EDT 2008
