[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1238
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1238/changes
Changes:
[jdeolive] GEOS-3076, passing in raw kvp map to old style kvp readers
[...truncated 3829 lines...]
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1007)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:454)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:435)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:709)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:671)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testCoverage(GetFeatureInfoTest.java:206)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:131)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at sun.reflect.GeneratedMethodAccessor122.invoke(Unknown Source)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
16 Jun 19:37:59 ERROR [geoserver.ows] -
java.lang.NullPointerException
  at com.vividsolutions.jts.geom.Envelope.init(Envelope.java:254)
  at com.vividsolutions.jts.geom.Envelope.<init>(Envelope.java:186)
  at org.geotools.geometry.jts.ReferencedEnvelope.<init>(ReferencedEnvelope.java:203)
  at org.vfny.geoserver.wms.responses.featureInfo.AbstractFeatureInfoResponse.execute(AbstractFeatureInfoResponse.java:223)
  at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:143)
  at org.vfny.geoserver.wms.responses.featureInfo.GetFeatureInfoDelegate.execute(GetFeatureInfoDelegate.java:92)
  at org.vfny.geoserver.wms.responses.GetFeatureInfoResponse.execute(GetFeatureInfoResponse.java:97)
  at org.geoserver.ows.adapters.ResponseAdapter.getMimeType(ResponseAdapter.java:48)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:690)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1040)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testCoverageScales(GetFeatureInfoTest.java:220)
  at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testCoverageScales(GetFeatureInfoTest.java:224)
Tests run: 9, Failures: 8, Errors: 0, Skipped: 0, Time elapsed: 0.672 sec <<< FAILURE!
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
16 Jun 19:38:00 ERROR [geoserver.ows] -
java.io.IOException
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
  at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:630)
  at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
  at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
  at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
  at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
  ... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
  at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
  at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
  at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
  at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
  ... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
  at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
  at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
  ... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.214 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.039 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.179 sec
Results :
Failed tests:
  testSimple(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testSimpleHtml(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testBuffer(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testAutoBuffer(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testBufferScales(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testTwoLayers(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testCoverage(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
  testCoverageScales(org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest)
Tests run: 157, Failures: 8, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 2 minutes 30 seconds
[INFO] Finished at: Tue Jun 16 19:38:02 EDT 2009
[INFO] Final Memory: 39M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1239/changes
