See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/127/changes
Changes:
[groldan] GEOS-1897, paging in wms through Query.startIndex/maxFeatures
[...truncated 35 lines...]
[INFO] Validation Module
[INFO] Web Feature Service Module
[INFO] Versioned Web Feature Service Module
[INFO] Web Map Service Module
[INFO] Web Application Module
[INFO] Community Space
[INFO] Building GeoServer
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-clean-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-compiler-plugin: checking for updates from central
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:jalopy-maven-plugin:1.0-SNAPSHOT: checking for updates from refractions-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from codehaus-snapshot-plugins
[INFO] snapshot org.codehaus.mojo:mojo:10-SNAPSHOT: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-surefire-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-jar-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-source-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-site-plugin: checking for updates from central
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-install-plugin: checking for updates from central
[INFO] [site:attach-descriptor]
[INFO] snapshot org.geotools:gt-api:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:library:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:modules:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:geotools:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot com.vividsolutions:jts:1.9.1-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-referencing:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-metadata:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:geoapi:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.opengis:parent:2.2-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-main:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/pom.xml to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/target/geoserver-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/geoserver/1.7.0-SNAPSHOT/geoserver-1.7.0-SNAPSHOT-tests.jar
[INFO] Building GeoServer Maven Plugins
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/pom.xml to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT.pom
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/target/maven-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/1.7.0-SNAPSHOT/maven-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Plugins configuration files
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-resources-plugin: checking for updates from central
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Nothing to compile - all classes are up to date
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from refractions-plugins
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-sources.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 8 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-sources.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.xsd:gt-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 20 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureSource.java :[18,25] cannot find symbol
symbol : class QueryCapabilities
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureSource.java :[126,11] cannot find symbol
location: class org.geoserver.feature.retype.RetypingFeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/PagingFeatureSource.java :[12,25] cannot find symbol
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/PagingFeatureSource.java :[207,11] cannot find symbol
location: class org.geoserver.feature.PagingFeatureSource
http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/src/main/java/org/geoserver/feature/retype/RetypingFeatureSource.java :[127,22] cannot find symbol
symbol : method getQueryCapabilities()
location: interface org.geotools.data.FeatureSource<org.opengis.feature.simple.SimpleFeatureType,org.opengis.feature.simple.SimpleFeature>
[INFO] Total time: 32 seconds
[INFO] Finished at: Wed Apr 30 19:37:12 EDT 2008
[INFO] Final Memory: 22M/41M
