See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1343/changes
Changes:
[jdeolive] updated poms to reflect change to jdbc-ng artifacts
Started by user tomcat
Updating https://svn.codehaus.org/geoserver/trunk/src
U release/pom.xml
U community/cite/loader/pom.xml
U pom.xml
U extension/oracle/pom.xml
U extension/db2/pom.xml
U extension/h2/pom.xml
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/minimal’
At revision 12752
Fetching 'http://svn.opengeo.org/geoext/apps/styler2/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app’
Fetching 'http://svn.opengeo.org/geoext/ext/2.2’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/externals/ext’
At revision 1428
Fetching 'http://svn.opengeo.org/geoext/ux’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/externals/ux’
At revision 1428
Fetching 'http://svn.openlayers.org/sandbox/topp/styler’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/externals/openlayers’
At revision 9543
Fetching 'http://svn.opengeo.org/who/ems/trunk/lib’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/externals/tree’
At revision 117
Fetching 'http://svn.opengeo.org/geoext/core/trunk’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/styler/app/externals/core’
At revision 1428
At revision 1428
Fetching 'http://svn.osgeo.org/geotools/trunk/modules/unsupported/app-schema/app-schema/src/test/resources/test-data’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/app-schema/app-schema-test/src/test/resources/test-data’
At revision 33503
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/css’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/test/java/org/geoserver/wicket/test/css’
At revision 12752
Fetching 'https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/img’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/app/src/test/java/org/geoserver/wicket/test/img’
At revision 12752
Fetching 'http://svn.codehaus.org/geoserver/trunk/data/minimal’ at -1 into 'http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/legacy/web/minimal’
At revision 12752
At revision 12752
no change for http://svn.codehaus.org/geoserver/trunk/data/minimal since the previous build
no change for http://svn.opengeo.org/geoext/apps/styler2/trunk since the previous build
no change for http://svn.opengeo.org/geoext/ext/2.2 since the previous build
no change for http://svn.opengeo.org/geoext/ux since the previous build
no change for http://svn.openlayers.org/sandbox/topp/styler since the previous build
no change for http://svn.opengeo.org/who/ems/trunk/lib since the previous build
no change for http://svn.opengeo.org/geoext/core/trunk since the previous build
no change for http://svn.osgeo.org/geotools/trunk/modules/unsupported/app-schema/app-schema/src/test/resources/test-data since the previous build
no change for https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/css since the previous build
no change for https://svn.codehaus.org/geoserver/trunk/src/community/web2/core/src/main/java/org/geoserver/web/img since the previous build
[geoserver] $ /opt/actual/maven-2.0.9/bin/mvn -U -Djava.awt.headless=true -Dtest.maxHeapSize=256M -P allExtensions,web2 clean install
[INFO] Scanning for projects...
[ERROR] FATAL ERROR
[INFO] Error building POM (may not be this project's POM).
Project ID: org.geoserver.web:web-core
POM Location: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/pom.xml
Validation Messages:
[0] 'dependencies.dependency.version' is missing for org.geotools:gt-jdbc-postgis
Reason: Failed to validate POM for project org.geoserver.web:web-core at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/pom.xml
[INFO] Trace
org.apache.maven.reactor.MavenExecutionException: Failed to validate POM for project org.geoserver.web:web-core at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/pom.xml
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:378)
at org.apache.maven.DefaultMaven.doExecute(DefaultMaven.java:292)
at org.apache.maven.DefaultMaven.execute(DefaultMaven.java:129)
at org.apache.maven.cli.MavenCli.main(MavenCli.java:287)
at org.codehaus.classworlds.Launcher.launchEnhanced(Launcher.java:315)
at org.codehaus.classworlds.Launcher.launch(Launcher.java:255)
at org.codehaus.classworlds.Launcher.mainWithExitCode(Launcher.java:430)
at org.codehaus.classworlds.Launcher.main(Launcher.java:375)
Caused by: org.apache.maven.project.InvalidProjectModelException: Failed to validate POM for project org.geoserver.web:web-core at http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/community/web2/core/pom.xml
at org.apache.maven.project.DefaultMavenProjectBuilder.processProjectLogic(DefaultMavenProjectBuilder.java:1108)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildInternal(DefaultMavenProjectBuilder.java:878)
at org.apache.maven.project.DefaultMavenProjectBuilder.buildFromSourceFileInternal(DefaultMavenProjectBuilder.java:506)
at org.apache.maven.project.DefaultMavenProjectBuilder.build(DefaultMavenProjectBuilder.java:198)
at org.apache.maven.DefaultMaven.getProject(DefaultMaven.java:583)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:461)
at org.apache.maven.DefaultMaven.collectProjects(DefaultMaven.java:534)
at org.apache.maven.DefaultMaven.getProjects(DefaultMaven.java:365)
... 11 more
[INFO] Total time: 1 second
[INFO] Finished at: Tue Jul 07 01:55:55 EDT 2009
[INFO] Final Memory: 4M/8M
