See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/144/changes
Changes:
[aaime] Report more information about the coverage
[...truncated 131 lines...]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/build-configs/target/build-configs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/build-configs/1.7.0-SNAPSHOT/build-configs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Configuration Deployment PlugIn
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from mortbay-repo
[INFO] artifact org.apache.maven.plugins:maven-plugin-plugin: checking for updates from central
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target
[INFO] [plugin:descriptor]
[INFO] Using 3 extractors.
[INFO] Applying extractor for language: java
[INFO] Extractor for language: java found 0 mojo descriptors.
[INFO] Applying extractor for language: bsh
[INFO] Extractor for language: bsh found 0 mojo descriptors.
[INFO] Applying extractor for language: ant
[INFO] Extractor for language: ant found 2 mojo descriptors.
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] No sources to compile
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar
[INFO] [plugin:addPluginArtifactMetadata]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/maven/config/target/config-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/maven/config/1.7.0-SNAPSHOT/config-1.7.0-SNAPSHOT-tests.jar
[INFO] [plugin:updateRegistry]
[INFO] Building Core Platform Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target
[INFO] Compiling 9 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/platform/target/platform-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/platform/1.7.0-SNAPSHOT/platform-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Data Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target
[INFO] snapshot org.geotools:gt2-coverage:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-h2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-unsupported:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-data:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-jdbc:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.h2database:h2:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.openplans:spatialdbbox:1.0-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo-property:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools.demo:gt2-demo:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-repository:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-postgis:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-plugin:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wms:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-wfs:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-xsd:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-extension:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-filter:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-core:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-graph:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml2:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-gml3:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-xml-ows:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-render:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-shapefile:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 16 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/classes
[INFO] Compiling 1 source file to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/surefire-reports
T E S T S
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/data/target/data-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/data/1.7.0-SNAPSHOT/data-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Model
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target
[INFO] Compiling 62 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/classes
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.ows/target/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.ows/1.7.0-SNAPSHOT/net.opengis.ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Open Web Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target
[INFO] Compiling 67 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/classes
[INFO] Compiling 13 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/surefire-reports
T E S T S
Running org.geoserver.ows.DispatcherTest
log4j:WARN No appenders could be found for logger (org.springframework.beans.factory.xml.XmlBeanDefinitionReader).
log4j:WARN Please initialize the log4j system properly.
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.521 sec
Running org.geoserver.ows.DefaultServiceExceptionHandlerTest
<ows:ExceptionReport version="1.0.0"
xsi:schemaLocation="http://www.opengis.net/ows http://localhost:8080geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ows="http://www.opengis.net/ows">
<ows:Exception exceptionCode="helloCode" locator="helloLocator">
<ows:ExceptionText>hello service exception
helloText
I/O exception here
Illegal argument here</ows:ExceptionText>
<ows:ExceptionText>helloText</ows:ExceptionText>
</ows:Exception>
</ows:ExceptionReport>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.252 sec
Running org.geoserver.ows.kvp.TimeKvpParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.ows.kvp.KvpUtilsTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/ows/target/ows-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/ows/1.7.0-SNAPSHOT/ows-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Main Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target
[INFO] snapshot org.geotools:gt2-cql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-validation:2.5-SNAPSHOT: checking for updates from refractions
[INFO] snapshot org.geotools:gt2-epsg-hsql:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 116 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/classes
[INFO] snapshot org.geoserver:data:1.7.0-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 5 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports
Failed to load Main-Class manifest attribute from
/tmp/surefirebooter4407.jar
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/main/target/surefire-reports for the individual test results.
[INFO] Total time: 35 seconds
[INFO] Finished at: Tue Jan 22 05:32:44 EST 2008
[INFO] Final Memory: 26M/60M
