[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1454
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1454/changes
Changes:
[RiniAngreani] - GEOS-3244: Update FeatureChainingWFSTest with encoding client properties on simple attributes
- re-enable DataAccessIntegrationWFSTest
[...truncated 15332 lines...]
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1064)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1031)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:473)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:454)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:728)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:690)
  at org.geoserver.test.AbstractAppSchemaWfsTestSupport.getAsDOM(AbstractAppSchemaWfsTestSupport.java:117)
  at org.geoserver.test.FeatureChainingWfsTest.testGetFeature(FeatureChainingWfsTest.java:212)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:134)
  at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
  at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
  at junit.extensions.TestSetup.run(TestSetup.java:25)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Jul 22, 2009 3:41:58 AM org.geoserver.test.FeatureChainingWfsTest testGetFeature
INFO: WFS GetFeature&typename=gsml:CompositionPart response, exception expected:
<ows:ExceptionReport version="1.0.0"
    xmlns:ows="http://www.opengis.net/ows&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/ows http://localhost:80/geoserver/schemas/ows/1.0.0/owsExceptionReport.xsd&quot;&gt;
    <ows:Exception exceptionCode="InvalidParameterValue" locator="typeName">
        <ows:ExceptionText>Feature type gsml:CompositionPart unknown</ows:ExceptionText>
    </ows:Exception>
</ows:ExceptionReport>
Jul 22, 2009 3:41:58 AM org.geoserver.test.FeatureChainingWfsTest testComplexTypeWithSimpleContent
INFO: WFS GetFeature&typename=ex:FirstParentFeature response:
<wfs:FeatureCollection numberOfFeatures="4"
    timeStamp="2009-07-22T03:41:58.429-04:00"
    xmlns:ex="http://example.com" xmlns:gml="http://www.opengis.net/gml&quot;
    xmlns:gsml="http://www.cgi-iugs.org/xml/GeoSciML/2&quot;
    xmlns:ogc="http://www.opengis.net/ogc&quot;
    xmlns:wfs="http://www.opengis.net/wfs&quot;
    xmlns:xlink="http://www.w3.org/1999/xlink&quot;
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=ex:FirstParentFeature http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
    <gml:featureMembers>
        <ex:FirstParentFeature gml:id="1">
            <ex:nestedFeature>
                <ex:SimpleContent>
                    <ex:someAttribute>string_one</ex:someAttribute>
                </ex:SimpleContent>
            </ex:nestedFeature>
            <ex:nestedFeature>
                <ex:SimpleContent>
                    <ex:someAttribute>string_two</ex:someAttribute>
                </ex:SimpleContent>
            </ex:nestedFeature>
        </ex:FirstParentFeature>
        <ex:FirstParentFeature gml:id="2"/>
    </gml:featureMembers>
</wfs:FeatureCollection>
INFO: WFS GetFeature&typename=ex:SecondParentFeature response:
    timeStamp="2009-07-22T03:41:58.473-04:00"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://example.com http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=ex:SecondParentFeature http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
        <ex:SecondParentFeature gml:id="1"/>
        <ex:SecondParentFeature gml:id="2">
            <ex:nestedFeature>
                <ex:SimpleContent>
                </ex:SimpleContent>
            </ex:nestedFeature>
            <ex:nestedFeature>
                <ex:SimpleContent>
                </ex:SimpleContent>
            </ex:nestedFeature>
            <ex:nestedFeature>
                <ex:SimpleContent>
                    <ex:someAttribute>string_three</ex:someAttribute>
                </ex:SimpleContent>
            </ex:nestedFeature>
        </ex:SecondParentFeature>
Jul 22, 2009 3:41:58 AM org.geoserver.test.FeatureChainingWfsTest testGetFeaturePropertyFilter
INFO: WFS filter GetFeature response:
<wfs:FeatureCollection numberOfFeatures="1"
    timeStamp="2009-07-22T03:41:58.556-04:00"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd http://www.cgi-iugs.org/xml/GeoSciML/2 http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=gsml:MappedFeature&quot;&gt;
        <gsml:MappedFeature gml:id="mf4">
            <gml:name>MURRADUC BASALT</gml:name>
            <gsml:observationMethod>
                <gsml:CGI_TermValue>
                    <gsml:value>urn:ogc:def:nil:OGC::missing</gsml:value>
                </gsml:CGI_TermValue>
            </gsml:observationMethod>
            <gsml:shape>
                <gml:Polygon>
                    <gml:exterior>
                        <gml:LinearRing>
                            <gml:posList>-1.3 52.5 -1.3 52.6 -1.2 52.6 -1.2 52.5 -1.3 52.5</gml:posList>
                        </gml:LinearRing>
                    </gml:exterior>
                </gml:Polygon>
            </gsml:shape>
            <gsml:specification>
                <gsml:GeologicUnit gml:id="gu.25682">
                    <gml:description>Olivine basalt</gml:description>
                    <gml:name codeSpace="urn:ietf:rfc:2141">New Group</gml:name>
                    <gml:name>-Xy</gml:name>
                    <gsml:occurence xlink:href="urn:cgi:feature:MappedFeature:mf4"/>
                    <gsml:exposureColor>
                            <gsml:value>Red</gsml:value>
                    </gsml:exposureColor>
                    <gsml:outcropCharacter>
                            <gsml:value>z</gsml:value>
                    </gsml:outcropCharacter>
                    <gsml:composition>
                        <gsml:CompositionPart>
                            <gsml:lithology>
                                <gsml:ControlledConcept>
                                    <gml:name>name_a</gml:name>
                                    <gml:name>name_b</gml:name>
                                    <gml:name>name_c</gml:name>
                                </gsml:ControlledConcept>
                            </gsml:lithology>
                            <gsml:lithology>
                                    <gml:name>name_2</gml:name>
                            </gsml:lithology>
                            <gsml:proportion>
                                    <gsml:value>significant</gsml:value>
                            </gsml:proportion>
                            <gsml:role>interbedded component</gsml:role>
                        </gsml:CompositionPart>
                    </gsml:composition>
                </gsml:GeologicUnit>
            </gsml:specification>
        </gsml:MappedFeature>
Tests run: 6, Failures: 1, Errors: 0, Skipped: 0, Time elapsed: 5.205 sec <<< FAILURE!
Running org.geoserver.test.XYGeomTest
Jul 22, 2009 3:41:58 AM org.geoserver.test.XYGeomTest testDescribeFeatureType
INFO: WFS DescribeFeatureType response:
<xsd:schema elementFormDefault="qualified" targetNamespace="http://test"
    xmlns:gml="http://www.opengis.net/gml&quot; xmlns:test="http://test" xmlns:xsd="http://www.w3.org/2001/XMLSchema&quot;&gt;
    <xsd:import namespace="http://www.opengis.net/gml&quot; schemaLocation="http://localhost:80/geoserver/schemas/gml/3.1.1/base/gml.xsd&quot;/&gt;
    <xsd:import namespace="http://test" schemaLocation="http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/app-schema-mock62644data/featureTypes/test_PointFeature/GeometrylessTest.xsd&quot;/&gt;
</xsd:schema>
Jul 22, 2009 3:41:58 AM org.geoserver.test.XYGeomTest testGetFeature
INFO: WFS GetFeature response:
<wfs:FeatureCollection numberOfFeatures="2"
    timeStamp="2009-07-22T03:41:58.810-04:00"
    xmlns:ows="http://www.opengis.net/ows&quot; xmlns:test="http://test"
    xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance&quot; xsi:schemaLocation="http://test http://localhost:80/geoserver/wfs?service=WFS&amp;version=1.1.0&amp;request=DescribeFeatureType&amp;typeName=test:PointFeature http://www.opengis.net/wfs http://localhost:80/geoserver/schemas/wfs/1.1.0/wfs.xsd&quot;&gt;
        <test:PointFeature gml:id="mf1">
            <test:loc/>
        </test:PointFeature>
        <test:PointFeature gml:id="mf2">
            <test:loc/>
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.263 sec
Results :
Failed tests:
  testGetFeatureContent(org.geoserver.test.FeatureChainingWfsTest)
Tests in error:
  org.geoserver.test.DataAccessIntegrationWfsTest
Tests run: 14, Failures: 1, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/app-schema/app-schema-test/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 52 seconds
[INFO] Finished at: Wed Jul 22 03:41:59 EDT 2009
[INFO] Final Memory: 43M/63M
Failed to send e-mail to RiniAngreani because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1455/
