See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1458/changes
Changes:
[aaime] First rough cut at GEOS-3259
[...truncated 13583 lines...]
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building REST Support Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 22 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 11 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/surefire-reports
T E S T S
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.706 sec
Running org.geoserver.rest.format.FormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.668 sec
Running org.geoserver.rest.RESTDispatcherTest
22 Jul 10:40:16 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.344 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
<body>
This is a generic template for Foo.
<br>
Properties:
<ul>
<li>prop3: 3.0
<li>prop1: one
<li>prop2: 2
</ul>
</body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.177 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.022 sec
Running org.geoserver.rest.IndexRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.261 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/pom.xml to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 120 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/classes
[INFO] Compiling 45 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.719 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.545 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Jul 22, 2009 10:40:31 AM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.396 sec
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.036 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.311 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.125 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.657 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.201 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.858 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.102 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.905 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.98 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.751 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.076 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.211 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.252 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.659 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.205 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.569 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.159 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.481 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.167 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.934 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.302 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.636 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.615 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.326 sec
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.182 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.07 sec
Running org.geoserver.web.wicket.SRSPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.406 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.014 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.192 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.519 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.565 sec
Results :
Tests run: 93, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/web-core-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/web/web-core/2.0-SNAPSHOT/web-core-2.0-SNAPSHOT-sources.jar
[INFO] Building WMS UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.xsd:gt-xsd-sld:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 13 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/target/classes
[ERROR] BUILD FAILURE
[INFO] Compilation failure
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/src/main/java/org/geoserver/wms/web/data/SLDEditorPanel.java :[22,32] cannot find symbol
symbol : class EditAreaBehavior
http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/wms/src/main/java/org/geoserver/wms/web/data/SLDEditorPanel.java :[49,23] cannot find symbol
location: class org.geoserver.wms.web.data.SLDEditorPanel
[INFO] Total time: 3 minutes 39 seconds
[INFO] Finished at: Wed Jul 22 10:40:53 EDT 2009
[INFO] Final Memory: 38M/63M
