[Geoserver-devel] Build failed in Hudson: geoserver-trunk #151
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/151/changes
Changes:
[dgricci] Updates of French resources
[...truncated 748 lines...]
Running org.geoserver.wfs.v1_1.TransactionTest
22 Jan 17:33:25 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: No such property: {http://www.opengis.net/wfs\}INVALID
  at org.geoserver.wfs.UpdateElementHandler.checkValidity(UpdateElementHandler.java:110)
  at org.geoserver.wfs.Transaction.execute(Transaction.java:225)
  at org.geoserver.wfs.Transaction.transaction(Transaction.java:104)
  at org.geoserver.wfs.DefaultWebFeatureService.transaction(DefaultWebFeatureService.java:157)
  at sun.reflect.GeneratedMethodAccessor94.invoke(Unknown Source)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
  at $Proxy6.transaction(Unknown Source)
  at sun.reflect.GeneratedMethodAccessor93.invoke(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
  at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:599)
  at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:318)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:419)
  at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:402)
  at org.geoserver.wfs.v1_1.TransactionTest.testUpdateWithInvalidProperty(TransactionTest.java:532)
  at junit.framework.TestCase.runTest(TestCase.java:154)
  at junit.framework.TestCase.runBare(TestCase.java:127)
  at junit.framework.TestCase.run(TestCase.java:118)
  at junit.framework.TestSuite.runTest(TestSuite.java:208)
  at junit.framework.TestSuite.run(TestSuite.java:203)
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:334)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:980)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.68 sec
Running org.geoserver.wfs.v1_1.GetFeatureWithLockTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.232 sec
Running org.geoserver.wfs.xml.GML3FeatureProducerTest
22 Jan 17:33:26 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
22 Jan 17:33:26 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.644 sec
Running org.geoserver.wfs.response.WfsXmlWriterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.1 sec
Running org.geoserver.wfs.TransactionTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.832 sec
Running org.geoserver.wfs.xml.GMLOutputFormatTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.464 sec
Running org.geoserver.wfs.v1_1.WFSReprojectionTest
22 Jan 17:33:31 ERROR [geotools.data] - There's code leaving transaction unclosed. Call Transaction.close() after using them to ensure they do not hold state such as JDCB connections or file handles
22 Jan 17:33:31 ERROR [geotools.data] - Unclosed transaction handle is 'org.geoserver.wfs.LockFeature.lockFeature Transaction'
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.048 sec
Running org.geoserver.wfs.ReprojectionTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.384 sec
Running org.geoserver.wfs.TransactionListenerTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.537 sec
Running org.geoserver.wfs.DescribeFeatureTest
22 Jan 17:33:33 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Could not find type: {http://www.opengis.net/cite/geometry\}DummyFeature
  at org.geoserver.wfs.DescribeFeatureType.run(DescribeFeatureType.java:97)
  at org.geoserver.wfs.DefaultWebFeatureService.describeFeatureType(DefaultWebFeatureService.java:92)
  at $Proxy6.describeFeatureType(Unknown Source)
  at org.geoserver.wfs.DescribeFeatureTest.testPostDummyFeature(DescribeFeatureTest.java:29)
  at sun.reflect.GeneratedMethodAccessor96.invoke(Unknown Source)
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.444 sec
Running org.geoserver.wfs.v1_1.DescribeFeatureTypeTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.38 sec
Running org.geoserver.wfs.xml.FeatureTypeInfoSchemaBuilderTest
Running org.geoserver.wfs.v1_1.CapabilitiesTransformerTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.208 sec
Running org.geoserver.wfs.response.ShapeZipTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.152 sec
Running org.geoserver.wfs.GetCapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.44 sec
Results :
Tests run: 126, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] [install:install]
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfs/target/wfs-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfs/1.7.0-SNAPSHOT/wfs-1.7.0-SNAPSHOT-tests.jar
[INFO] ----------------------------------------------------------------------------
[INFO] Building Versioning Web Feature Service Model
[INFO] [clean:clean]
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target
[INFO] [resources:resources]
[INFO] Using default encoding to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 28 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] No sources to compile
[INFO] [surefire:test]
[INFO] No tests to run.
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/net.opengis.wfsv/target/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/net.opengis.wfsv/1.7.0-SNAPSHOT/net.opengis.wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Versioned Web Feature Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target
[INFO] snapshot org.geotools:gt2-postgis-versioned:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 43 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/classes
[INFO] Nothing to compile - all classes are up to date
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/surefire-reports
T E S T S
There are no tests to run.
Results :
Tests run: 0, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Building jar: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT.jar
[INFO] Installing http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wfsv/target/wfsv-1.7.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wfsv/1.7.0-SNAPSHOT/wfsv-1.7.0-SNAPSHOT-tests.jar
[INFO] Building Web Map Service Module
[INFO] Deleting directory http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target
[INFO] snapshot org.geotools:gt2-shapefile-renderer:2.5-SNAPSHOT: checking for updates from refractions
[INFO] Compiling 128 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/classes
[INFO] Compiling 17 source files to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/test-classes
[INFO] Surefire report directory: http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports
Failed to load Main-Class manifest attribute from
/tmp/surefirebooter45577.jar
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 39 seconds
[INFO] Finished at: Tue Jan 22 17:33:50 EST 2008
[INFO] Final Memory: 30M/63M
Failed to send e-mail to dgricci because no e-mail address is known, and no default e-mail domain is configured
Hi, i’ve got this error in my fresh setup of eclipse debugging geoserver.
Going in the standard WFS-t demo, i’v got an alert saying that transaction is failed, and that is the error stack that for me is absolutely unclear:
22 gen 23:45:38 WARN [geoserver.ows] -
org.xmlpull.v1.XmlPullParserException: could not determine namespace bound to element prefix wfs (position: START_DOCUMENT seen <wfs:Transaction version=“1.0.0” service=“WFS”>… @1:47)
at org.xmlpull.mxp1.MXParser.parseStartTag(MXParser.java:1816)
at org.xmlpull.mxp1.MXParser.parseProlog(MXParser.java:1479)
at org.xmlpull.mxp1.MXParser.nextImpl(MXParser.java:1395)
at org.xmlpull.mxp1.MXParser.next(MXParser.java:1093)
at org.xmlpull.mxp1.MXParser.nextTag(MXParser.java:1078)
at org.geoserver.ows.Dispatcher.readOpPost(Dispatcher.java:1097)
at org.geoserver.ows.Dispatcher.service(Dispatcher.java:273)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:172)
at org.springframework.web.servlet.mvc.SimpleControllerHandlerAdapter.handle(SimpleControllerHandlerAdapter.java:44)
at org.springframework.web.servlet.DispatcherServlet.doDispatch(DispatcherServlet.java:684)
at org.springframework.web.servlet.DispatcherServlet.doService(DispatcherServlet.java:625)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:392)
at org.springframework.web.servlet.FrameworkServlet.doPost(FrameworkServlet.java:357)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:709)
at org.mortbay.jetty.servlet.ServletHolder.handle(ServletHolder.java:445)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1050)
at org.vfny.geoserver.filters.SetCharacterEncodingFilter.doFilter(SetCharacterEncodingFilter.java:108)
at org.mortbay.jetty.servlet.ServletHandler$CachedChain.doFilter(ServletHandler.java:1041)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:264)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.invoke(FilterSecurityInterceptor.java:107)
at org.acegisecurity.intercept.web.FilterSecurityInterceptor.doFilter(FilterSecurityInterceptor.java:72)
at org.acegisecurity.util.FilterChainProxy$VirtualFilterChain.doFilter(FilterChainProxy.java:274)
at org.acegisecurity.ui.ExceptionTranslationFilter.doFilter(ExceptionTranslationFilter.java:110)
at org.acegisecurity.providers.anonymous.AnonymousProcessingFilter.doFilter(AnonymousProcessingFilter.java:125)
at org.acegisecurity.ui.basicauth.BasicProcessingFilter.doFilter(BasicProcessingFilter.java:178)
at org.acegisecurity.context.HttpSessionContextIntegrationFilter.doFilter(HttpSessionContextIntegrationFilter.java:229)
at org.acegisecurity.util.FilterChainProxy.doFilter(FilterChainProxy.java:148)
at org.acegisecurity.util.FilterToBeanProxy.doFilter(FilterToBeanProxy.java:98)
at org.mortbay.jetty.servlet.ServletHandler.handle(ServletHandler.java:354)
at org.mortbay.jetty.servlet.SessionHandler.handle(SessionHandler.java:226)
at org.mortbay.jetty.handler.ContextHandler.handle(ContextHandler.java:627)
at org.mortbay.jetty.handler.ContextHandlerCollection.handle(ContextHandlerCollection.java:149)
at org.mortbay.jetty.handler.HandlerCollection.handle(HandlerCollection.java:123)
at org.mortbay.jetty.handler.HandlerWrapper.handle(HandlerWrapper.java:141)
at org.mortbay.jetty.Server.handle(Server.java:269)
at org.mortbay.jetty.HttpConnection.handleRequest(HttpConnection.java:430)
at org.mortbay.jetty.HttpConnection$RequestHandler.content(HttpConnection.java:701)
at org.mortbay.jetty.HttpParser.parseNext(HttpParser.java:617)
at org.mortbay.jetty.HttpParser.parseAvailable(HttpParser.java:199)
at org.mortbay.jetty.HttpConnection.handle(HttpConnection.java:339)
at org.mortbay.jetty.nio.HttpChannelEndPoint.run(HttpChannelEndPoint.java:270)
at org.mortbay.thread.BoundedThreadPool$PoolThread.run(BoundedThreadPool.java:475)
Have you got any clue on what could be misconfigured, as it is still a standard setup?
Thanks
Andrea Maschio
http://www.superandrew.it
See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/152/changes
This error means that the xml request is not well formed. Can you copy
in the xml you sending in the form.
-Justin
Andrea Maschio wrote:
Hi, i've got this error in my fresh setup of eclipse debugging geoserver.
Going in the standard WFS-t demo, i'v got an alert saying that
absolutely unclear:
<wfs:Transaction version="1.0.0" service="WFS">... @1:47)
<http://web.servlet.mvc.AbstractController.handleRequest>(AbstractController.java:139)
at
<http://web.servlet.mvc.SimpleControllerHandlerAdapter.handle>(SimpleControllerHandlerAdapter.java:44)
<http://web.servlet.DispatcherServlet.doDispatch>(DispatcherServlet.java:684)
<http://web.servlet.DispatcherServlet.doService>(DispatcherServlet.java:625)
<http://web.servlet.FrameworkServlet.processRequest>(FrameworkServlet.java:392)
<http://web.servlet.FrameworkServlet.doPost>(FrameworkServlet.java:357)
at
at
at
at
<http://web.FilterSecurityInterceptor.invoke>(FilterSecurityInterceptor.java:107)
<http://web.FilterSecurityInterceptor.doFilter>(FilterSecurityInterceptor.java:72)
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
standard setup?
Thanks
Andrea Maschio
http://www.superandrew.it/&gt;
!DSPAM:4007,4796731b87461431913854!
Defy all challenges. Microsoft(R) Visual Studio 2008.
Geoserver-devel mailing list
Justin Deoliveira
The Open Planning Project
http://topp.openplans.org
I am not sending XML from wfs page, just trying the tasmania roads/cities example, and this was the stdout from geoserver debugging session in eclipse.
Thanks
Andrea Maschio
Il giorno 23/gen/08, alle ore 00:42, Justin Deoliveira <jdeolive@anonymised.com > ha scritto:
-Justin
absolutely unclear:
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
at
standard setup?
Thanks
Andrea Maschio
Justin Deoliveira
