[Geoserver-devel] Build failed in Hudson: geoserver-trunk #1521
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1521/changes
Changes:
[groldan] GEOS-3310, abstract out input field creation and provide a title based on the datastore param title
[aaime] GEOS-3302, New layer group UI does not allow to just rely on the layer default style
[...truncated 17661 lines...]
  at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
  at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
  at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
  at java.security.AccessController.doPrivileged(Native Method)
  at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
  at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
  at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
  at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
  at sun.reflect.GeneratedMethodAccessor114.invoke(Unknown Source)
  at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
  at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
  at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
  at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
  at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
  at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
  at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
  at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:651)
  at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:207)
  at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
  at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:337)
  at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:310)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:182)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:149)
  at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
  at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:171)
  at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:204)
  at $Proxy14.getCoverage(Unknown Source)
  at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
  at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:574)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:212)
  at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
  at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
  at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1064)
  at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1031)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:473)
  at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:454)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:728)
  at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:690)
  at org.geoserver.catalog.rest.CoverageTest.testPostAsXML(CoverageTest.java:148)
  at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:134)
./target/mock56529data/temp/wcs/usa_1249321418265408000.outputFormat
03 Aug 13:43:39 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.715 sec
Running org.geoserver.catalog.rest.CoverageStoreFileUploadTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.905 sec
Running org.geoserver.catalog.rest.CoverageStoreTest
03 Aug 13:43:44 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
03 Aug 13:43:45 ERROR [geoserver.rest] - coveragestore not empty
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.346 sec
Running org.geoserver.catalog.rest.LayerGroupTest
Tests run: 8, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.932 sec <<< FAILURE!
Running org.geoserver.catalog.rest.NamespaceTest
03 Aug 13:43:48 ERROR [geoserver.rest] - No such namespace: none
03 Aug 13:43:50 ERROR [geoserver.rest] - No such namespace: newExistant
03 Aug 13:43:50 ERROR [geoserver.rest] - No such namespace: foo
03 Aug 13:43:50 ERROR [geoserver.rest] - No such namespace: nonExistant
03 Aug 13:43:50 ERROR [geoserver.rest] - Namespace not empty
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.397 sec
Running org.geoserver.catalog.rest.FeatureTypeTest
03 Aug 13:43:52 ERROR [geoserver.ows] -
org.geoserver.wfs.WFSException: Feature type sf:pdsa unknown
  at org.geoserver.wfs.kvp.GetFeatureKvpRequestReader.read(GetFeatureKvpRequestReader.java:91)
  at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1092)
  at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
  at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
  at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsXML(FeatureTypeTest.java:92)
03 Aug 13:43:53 ERROR [geoserver.ows] -
  at org.geoserver.catalog.rest.FeatureTypeTest.testPostAsJSON(FeatureTypeTest.java:124)
03 Aug 13:43:54 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
03 Aug 13:43:55 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.024 sec
Running org.geoserver.catalog.rest.DataStoreTest
03 Aug 13:44:03 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
03 Aug 13:44:04 ERROR [geoserver.rest] - datastore not empty
03 Aug 13:44:05 ERROR [geoserver.rest] - Can't change name of data store.
03 Aug 13:44:05 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
03 Aug 13:44:05 ERROR [geoserver.rest] - Can't change workspace of data store.
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 9.232 sec
Running org.geoserver.catalog.rest.LayerTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.074 sec
Running org.geoserver.catalog.rest.StyleTest
03 Aug 13:44:09 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.331 sec
Running org.geoserver.catalog.rest.WorkspaceTest
03 Aug 13:44:11 ERROR [geoserver.rest] - No such workspace: none
03 Aug 13:44:12 ERROR [geoserver.rest] - No such workspace: newExistant
03 Aug 13:44:13 ERROR [geoserver.rest] - No such workspace: foo
03 Aug 13:44:13 ERROR [geoserver.rest] - Workspace not empty
03 Aug 13:44:14 ERROR [geoserver.rest] - Can't change the name of a workspace.
03 Aug 13:44:14 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.606 sec
Results :
Tests in error:
  testPostNoStyles(org.geoserver.catalog.rest.LayerGroupTest)
Tests run: 138, Failures: 0, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/extension/restconfig/target/surefire-reports for the individual test results.
[INFO] Total time: 7 minutes 3 seconds
[INFO] Finished at: Mon Aug 03 13:44:15 EDT 2009
[INFO] Final Memory: 48M/63M
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1522/changes
Changes:
[mcr] Removing some java warnings
[groldan] GEOS-3310, allow to refresh the list of database raster tables only when adding a new arcsde coverage
[...truncated 17655 lines...]
./target/mock47785data/temp/wcs/usa_1249325003911070000.outputFormat
03 Aug 14:43:24 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
03 Aug 14:43:25 ERROR [geoserver.rest] - No such coverage: wcs,BlueMarble,NonExistant
Tests run: 13, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.734 sec
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.708 sec
03 Aug 14:43:29 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
03 Aug 14:43:30 ERROR [geoserver.rest] - No such coverage store: wcs,nonExistant
03 Aug 14:43:30 ERROR [geoserver.rest] - coveragestore not empty
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.33 sec
Tests run: 8, Failures: 0, Errors: 1, Skipped: 0, Time elapsed: 1.937 sec <<< FAILURE!
03 Aug 14:43:34 ERROR [geoserver.rest] - No such namespace: none
03 Aug 14:43:35 ERROR [geoserver.rest] - No such namespace: newExistant
03 Aug 14:43:35 ERROR [geoserver.rest] - No such namespace: foo
03 Aug 14:43:36 ERROR [geoserver.rest] - No such namespace: nonExistant
03 Aug 14:43:36 ERROR [geoserver.rest] - Namespace not empty
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.217 sec
03 Aug 14:43:37 ERROR [geoserver.ows] -
03 Aug 14:43:38 ERROR [geoserver.ows] -
03 Aug 14:43:39 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
03 Aug 14:43:40 ERROR [geoserver.rest] - No such feature type: sf,sf,NonExistant
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.045 sec
03 Aug 14:43:48 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
03 Aug 14:43:48 ERROR [geoserver.rest] - datastore not empty
03 Aug 14:43:49 ERROR [geoserver.rest] - Can't change name of data store.
03 Aug 14:43:49 ERROR [geoserver.rest] - No such datastore: sf,nonExistant
03 Aug 14:43:49 ERROR [geoserver.rest] - Can't change workspace of data store.
Tests run: 19, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.855 sec
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.005 sec
03 Aug 14:43:53 ERROR [geoserver.rest] - Can't delete style referenced by existing layers.
Tests run: 15, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.274 sec
03 Aug 14:43:55 ERROR [geoserver.rest] - No such workspace: none
03 Aug 14:43:56 ERROR [geoserver.rest] - No such workspace: newExistant
03 Aug 14:43:57 ERROR [geoserver.rest] - No such workspace: foo
03 Aug 14:43:57 ERROR [geoserver.rest] - Workspace not empty
03 Aug 14:43:58 ERROR [geoserver.rest] - Can't change the name of a workspace.
03 Aug 14:43:58 ERROR [geoserver.rest] - No such workspace: nonExistant
Tests run: 21, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.675 sec
Results :
Tests in error:
[INFO] Total time: 6 minutes 58 seconds
[INFO] Finished at: Mon Aug 03 14:43:58 EDT 2009
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1523/changes
