See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1581/changes
Changes:
[groldan] spanish UI translation for the web-wcs module
[groldan] spanish UI translation for the web-wfs module
[groldan] spanish UI translation for the web-wms module
[groldan] spanish UI translation for the web-core module
[arneke] GWC bump to 1.1.5b, bugfix of getcapabilities and more version info
[groldan] change NewlayerPage.listOfResourcesContained resource so it's i18n friendlier
[mcr] Start implementing the existing security tests for GeoXACML
[...truncated 13446 lines...]
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor129.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.Socket.connect(Socket.java:520)
at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
at sun.net.www.http.HttpClient.New(HttpClient.java:304)
at sun.net.www.http.HttpClient.New(HttpClient.java:321)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:813)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:765)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:690)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:934)
at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:67)
at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:684)
at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:347)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1135)
... 33 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.732 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.419 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.196 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
11 Aug 14:39:36 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:108)
at org.geoserver.wms.kvp.WMSKvpRequestReaderAdapter.createRequest(WMSKvpRequestReaderAdapter.java:72)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1089)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1064)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1031)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:473)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:454)
at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:193)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:134)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.717 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
11 Aug 14:39:39 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:630)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:728)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.262 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.011 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.231 sec
Results :
Tests run: 162, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/wms-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/wms/2.0-SNAPSHOT/wms-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
Downloading: http://repo.opengeo.org//org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.pom
Downloading: http://download.osgeo.org/webdav/geotools//org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.pom
Downloading: http://maven.restlet.org/org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.pom
Downloading: http://repo1.maven.org/maven2/org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.pom
Downloading: http://repo.opengeo.org//org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.jar
Downloading: http://download.osgeo.org/webdav/geotools//org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.jar
Downloading: http://maven.restlet.org/org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.jar
Downloading: http://repo1.maven.org/maven2/org/opengeo/geowebcache/1.1.5b/geowebcache-1.1.5b.jar
[ERROR] BUILD ERROR
[INFO] Failed to resolve artifact.
Missing:
1) org.opengeo:geowebcache:jar:1.1.5b
Try downloading the file manually from the project website.
Then, install it using the command:
mvn install:install-file -DgroupId=org.opengeo -DartifactId=geowebcache -Dversion=1.1.5b -Dpackaging=jar -Dfile=/path/to/file
Alternatively, if you host your own repository you can deploy the file there:
mvn deploy:deploy-file -DgroupId=org.opengeo -DartifactId=geowebcache -Dversion=1.1.5b -Dpackaging=jar -Dfile=/path/to/file -Durl=[url] -DrepositoryId=[id]
Path to dependency:
1) org.geoserver:gwc:jar:2.0-SNAPSHOT
2) org.opengeo:geowebcache:jar:1.1.5b
1 required artifact is missing.
for artifact:
from the specified remote repositories:
maven-restlet (http://maven.restlet.org),
central (http://repo1.maven.org/maven2),
osgeo (http://download.osgeo.org/webdav/geotools/),
opengeo (http://repo.opengeo.org/)
[INFO] Total time: 3 minutes 9 seconds
[INFO] Finished at: Tue Aug 11 14:39:43 EDT 2009
[INFO] Final Memory: 50M/157M
Failed to send e-mail to mcr because no e-mail address is known, and no default e-mail domain is configured
Failed to send e-mail to arneke because no e-mail address is known, and no default e-mail domain is configured
