See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1592/changes
Changes:
[groldan] GEOS-2730, various i18n fixes
[...truncated 13573 lines...]
[INFO] Building GeoWebCache (GWC) Module
[INFO] [clean:clean]
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target
[INFO] [resources:resources]
[INFO] Using encoding: 'UTF-8' to copy filtered resources.
[INFO] [compiler:compile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/classes
[INFO] [resources:testResources]
[INFO] [compiler:testCompile]
[INFO] Compiling 1 source file to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/test-classes
[INFO] [surefire:test]
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/surefire-reports
T E S T S
Running org.geoserver.gwc.GWCCatalogListenerTest
12 Aug 12:40:12 ERROR [layer.TileLayerDispatcher] - Unable to determine configuration directory.
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.97 sec
Results :
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Preparing source:jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar
[INFO] [install:install]
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/gwc/target/gwc-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/gwc/2.0-SNAPSHOT/gwc-2.0-SNAPSHOT-sources.jar
[INFO] Building REST Support Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target
[INFO] Compiling 22 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/classes
[INFO] Compiling 11 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/surefire-reports
T E S T S
Running org.geoserver.rest.ReflectiveResourceTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.705 sec
Running org.geoserver.rest.format.FormatTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.228 sec
Running org.geoserver.rest.RESTDispatcherTest
12 Aug 12:40:21 ERROR [geoserver.rest] - error
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.647 sec
Running org.geoserver.rest.format.ReflectiveHTMLFormatTest
<html>
<body>
This is a generic template for Foo.
<br>
Properties:
<ul>
<li>prop3: 3.0
<li>prop1: one
<li>prop2: 2
</ul>
</body>
</html>@SLTests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.158 sec
Running org.geoserver.rest.MapResourceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.rest.IndexRestletTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.422 sec
Results :
Tests run: 14, Failures: 0, Errors: 0, Skipped: 0
[INFO] [jar:jar]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-tests.jar
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-sources.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/rest/target/rest-2.0-SNAPSHOT-sources.jar to /home/tomcat/.m2/repository/org/geoserver/rest/2.0-SNAPSHOT/rest-2.0-SNAPSHOT-sources.jar
[INFO] Building GeoServer Web Modules
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target
[INFO] [site:attach-descriptor]
[INFO] Building jar: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/pom.xml to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT.pom
[INFO] Installing http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/target/web-2.0-SNAPSHOT-tests.jar to /home/tomcat/.m2/repository/org/geoserver/web/2.0-SNAPSHOT/web-2.0-SNAPSHOT-tests.jar
[INFO] Building Core UI Module
[INFO] Deleting directory http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc-postgis:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.6-SNAPSHOT: checking for updates from opengeo
[INFO] snapshot org.geotools.jdbc:gt-jdbc:2.6-SNAPSHOT: checking for updates from osgeo
[INFO] Compiling 127 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/classes
[INFO] Compiling 45 source files to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/test-classes
[INFO] Surefire report directory: http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports
T E S T S
Running org.geoserver.web.admin.ContactPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 5.834 sec
Running org.geoserver.web.data.store.StorePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.2 sec
Running org.geoserver.web.data.store.CoverageStoreEditPageTest
Aug 12, 2009 12:40:40 PM java.util.prefs.FileSystemPreferences$7 run
WARNING: Prefs file removed in background /home/tomcat/.java/.userPrefs/org/geotools/referencing/wkt/prefs.xml
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 4.238 sec
Running org.geoserver.web.wicket.KeywordsEditorTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.115 sec
Running org.geoserver.web.data.workspace.WorkspacePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.429 sec
Running org.geoserver.web.wicket.CRSPanelTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.143 sec
Running org.geoserver.web.data.layergroup.LayerGroupEditPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.172 sec
Running org.geoserver.web.admin.StatusPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.386 sec
Running org.geoserver.web.data.table.NewLayerProviderTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.546 sec
Running org.geoserver.web.wicket.GeoServerPagingNavigatorTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.269 sec
Running org.geoserver.web.data.workspace.WorkspaceEditPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.552 sec
Running org.geoserver.web.data.workspace.WorkspaceNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.052 sec
Running org.geoserver.web.data.layergroup.LayerGroupNewPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.08 sec
Running org.geoserver.web.wicket.browser.FileBreadcrumsTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.034 sec
Running org.geoserver.web.GeoServerHomePageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.23 sec
Running org.geoserver.web.admin.GlobalSettingsPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.508 sec
Running org.geoserver.web.GeoServerSecuredPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.561 sec
Running org.geoserver.web.data.layergroup.LayerGroupPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.293 sec
Running org.geoserver.web.admin.JAIPageTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.283 sec
Running org.geoserver.web.data.store.NewDataPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.747 sec
Running org.geoserver.web.wicket.EnvelopePanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.136 sec
Running org.geoserver.web.publish.HTTPLayerConfigTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.518 sec
Running org.geoserver.web.ConverterTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.146 sec
Running org.geoserver.web.data.ConfirmRemovalPanelTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.477 sec
Running org.geoserver.web.data.store.CoverageStoreNewPageTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.884 sec
Running org.geoserver.web.data.layer.NewLayerPageTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.462 sec
Running org.geoserver.web.wicket.browser.GeoServerFileChooserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.727 sec
Running org.geoserver.web.data.store.DataAccessEditPageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.72 sec
Running org.geoserver.web.data.resource.ResourceConfigurationPageTest
Running org.geoserver.web.wicket.FileExistsValidatorTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.234 sec
Running org.geoserver.web.wicket.GeoServerTablePanelTest
Tests run: 3, Failures: 0, Errors: 3, Skipped: 0, Time elapsed: 0.033 sec <<< FAILURE!
Running org.geoserver.web.wicket.SRSPanelTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.692 sec
Running org.geoserver.web.wicket.WKTToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.02 sec
Running org.geoserver.web.wicket.browser.FileDataViewTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.228 sec
Running org.geoserver.web.wicket.SRSToCRSModelTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.002 sec
Running org.geoserver.web.GeoServerBasePageTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.39 sec
Running org.geoserver.web.data.resource.ResourceNameValidatorTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.web.data.store.DataAccessNewPageTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 2.077 sec
Results :
Tests in error:
testBasicTable(org.geoserver.web.wicket.GeoServerTablePanelTest)
testFullSelection(org.geoserver.web.wicket.GeoServerTablePanelTest)
testSingleSelection(org.geoserver.web.wicket.GeoServerTablePanelTest)
Tests run: 95, Failures: 0, Errors: 3, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/web/core/target/surefire-reports for the individual test results.
[INFO] Total time: 4 minutes 32 seconds
[INFO] Finished at: Wed Aug 12 12:41:08 EDT 2009
[INFO] Final Memory: 56M/152M
