See http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/162/changes
[...truncated 582 lines...]
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:615)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:192)
at org.springframework.web.servlet.mvc.AbstractController.handleRequest(AbstractController.java:139)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:599)
at org.geoserver.test.GeoServerAbstractTestSupport.post(GeoServerAbstractTestSupport.java:318)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:419)
at org.geoserver.wcs.DescribeCoverageTest.testDescribeUnknownCoverageXml(DescribeCoverageTest.java:59)
at junit.framework.TestCase.runTest(TestCase.java:154)
at junit.framework.TestCase.runBare(TestCase.java:127)
at junit.framework.TestCase.run(TestCase.java:118)
at junit.framework.TestSuite.runTest(TestSuite.java:208)
at junit.framework.TestSuite.run(TestSuite.java:203)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:334)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:980)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:132)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:107)
at org.geoserver.wcs.response.DescribeCoverageResponse.write(DescribeCoverageResponse.java:35)
... 33 more
Caused by: org.vfny.geoserver.wcs.WcsException: Could not find the specified coverage: plop
at org.geoserver.wcs.response.DescribeCoverageTransformer$WCS111DescribeCoverageTranslator.encode(DescribeCoverageTransformer.java:146)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:702)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:295)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:128)
... 35 more
Tests run: 7, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 7.456 sec
Running org.geoserver.wcs.kvp.GetCoverageReaderTest
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.072 sec
Running org.geoserver.wcs.kvp.BoundingBoxKvpParserTest
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.geoserver.wcs.GetCoverageTest
Error: Could not find mediaLib accelerator wrapper classes. Continuing in pure Java mode.
Occurs in: com.sun.media.jai.mlib.MediaLibAccessor
java.lang.NoClassDefFoundError: com/sun/medialib/mlib/Image
at com.sun.media.jai.mlib.MediaLibAccessor$1.run(MediaLibAccessor.java:248)
at java.security.AccessController.doPrivileged(Native Method)
at com.sun.media.jai.mlib.MediaLibAccessor.setUseMlib(MediaLibAccessor.java:245)
at com.sun.media.jai.mlib.MediaLibAccessor.useMlib(MediaLibAccessor.java:177)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:357)
at com.sun.media.jai.mlib.MediaLibAccessor.isMediaLibCompatible(MediaLibAccessor.java:315)
at com.sun.media.jai.mlib.MlibWarpRIF.create(MlibWarpRIF.java:65)
at sun.reflect.GeneratedMethodAccessor57.invoke(Unknown Source)
at javax.media.jai.FactoryCache.invoke(FactoryCache.java:122)
at javax.media.jai.OperationRegistry.invokeFactory(OperationRegistry.java:1674)
at javax.media.jai.ThreadSafeOperationRegistry.invokeFactory(ThreadSafeOperationRegistry.java:473)
at javax.media.jai.registry.RIFRegistry.create(RIFRegistry.java:332)
at javax.media.jai.RenderedOp.createInstance(RenderedOp.java:819)
at javax.media.jai.RenderedOp.createRendering(RenderedOp.java:867)
at javax.media.jai.RenderedOp.getMinX(RenderedOp.java:2161)
at org.geotools.coverage.processing.operation.Resampler2D.reproject(Resampler2D.java:596)
at org.geotools.coverage.processing.operation.Resample.doOperation(Resample.java:208)
at org.vfny.geoserver.util.WCSUtils.scale(WCSUtils.java:225)
at org.geoserver.wcs.DefaultWebCoverageService111.getCoverage(DefaultWebCoverageService111.java:313)
at org.geoserver.wcs.GetCoverageTest.executeGetCoverageKvp(GetCoverageTest.java:297)
at org.geoserver.wcs.GetCoverageTest.testKvpBasic(GetCoverageTest.java:64)
Tests run: 10, Failures: 2, Errors: 0, Skipped: 0, Time elapsed: 1.64 sec <<< FAILURE!
Running org.geoserver.wcs.xml.GetCapabilitiesXmlParserTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.472 sec
Running org.geoserver.wcs.xml.GetCoverageXmlParserTest
class [Ljava.lang.Double;: [Ljava.lang.Double;@1293709
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.356 sec
Running org.geoserver.wcs.kvp.RangeSubsetKvpParserTest
Tests run: 5, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.004 sec
Running org.geoserver.wcs.xml.DescribeCoverageXmlParserTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.116 sec
Running org.geoserver.wcs.GetCapabilitiesTest
23 Jan 17:14:02 ERROR [geoserver.ows] -
org.geoserver.platform.ServiceException: Could not find any matching version
at org.geoserver.ows.util.RequestUtils.getVersionOws11(RequestUtils.java:220)
at org.geoserver.wcs.DefaultWebCoverageService111.getCapabilities(DefaultWebCoverageService111.java:91)
at org.springframework.aop.support.AopUtils.invokeJoinpointUsingReflection(AopUtils.java:292)
at org.springframework.aop.framework.ReflectiveMethodInvocation.invokeJoinpoint(ReflectiveMethodInvocation.java:155)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:122)
at org.geoserver.ows.util.EMFLogger.invoke(EMFLogger.java:51)
at org.springframework.aop.framework.ReflectiveMethodInvocation.proceed(ReflectiveMethodInvocation.java:144)
at org.springframework.aop.framework.JdkDynamicAopProxy.invoke(JdkDynamicAopProxy.java:174)
at $Proxy6.getCapabilities(Unknown Source)
at org.geoserver.security.OperationSecurityInterceptor.invoke(OperationSecurityInterceptor.java:41)
at org.geoserver.ows.Dispatcher.execute(Dispatcher.java:495)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:188)
at org.geoserver.test.GeoServerAbstractTestSupport.postAsDOM(GeoServerAbstractTestSupport.java:402)
at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionPost(GetCapabilitiesTest.java:39)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:277)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:258)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:352)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:334)
at org.geoserver.wcs.GetCapabilitiesTest.testUnsupportedVersionGet(GetCapabilitiesTest.java:46)
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.128 sec
Running org.geoserver.wcs.GetCoverageEncodingTest
Coverages part: <?xml version="1.0" encoding="UTF-8"?><wcs:Coverages xmlns:wcs="http://www.opengis.net/wcs/1.1.1" xmlns:xlink="http://www.w3.org/1999/xlink" xmlns:ogc="http://www.opengis.net/ogc" xmlns:ows="http://www.opengis.net/ows/1.1" xmlns:gml="http://www.opengis.net/gml" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xsi:schemaLocation="http://www.opengis.net/wcs/1.1.1 schemas/wcs/1.1.1/wcsCoverages.xsd"><wcs:Coverage><ows:Title>BlueMarble</ows:Title><ows:Abstract>BlueMarble description</ows:Abstract><ows:Identifier>wcs:BlueMarble</ows:Identifier><ows:Reference xlink:href="cid:theCoverage"/></wcs:Coverage></wcs:Coverages>
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.989 sec
Results :
Failed tests:
testWrongGridOrigin(org.geoserver.wcs.GetCoverageTest)
testNoGridOffsets(org.geoserver.wcs.GetCoverageTest)
Tests run: 56, Failures: 2, Errors: 0, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://gridlock.openplans.org:8080/hudson/job/geoserver-trunk/ws/geoserver/wcs1_1/target/surefire-reports for the individual test results.
[INFO] Total time: 1 minute 6 seconds
[INFO] Finished at: Wed Jan 23 17:14:04 EST 2008
[INFO] Final Memory: 31M/63M
