See http://hudson.opengeo.org/hudson/job/geoserver-trunk/1656/changes
Changes:
[aaime] Updated test to consider sorting
[aaime] By default sort the workspaces by name
[aaime] GEOS-3358, Workspace URI validation too strict
[aaime] Simple URI validator
[aaime] GEOS-3383, Workspace dropdown contents are not sorted
[...truncated 14583 lines...]
PARAMETER["latitude_of_origin", 0.0],
PARAMETER["scale_factor", 0.9996],
PARAMETER["false_easting", 500000.0],
PARAMETER["false_northing", 0.0],
UNIT["m", 1.0],
AXIS["Easting", EAST],
AXIS["Northing", NORTH],
AUTHORITY["EPSG","32615"]]-->
<LatLonBoundingBox maxx="180.0" maxy="90.0" minx="-180.0" miny="-90.0"/>
<Style>
<Name>Default</Name>
<Title>Default Styler</Title>
<Abstract/>
<LegendURL height="20" width="20">
<Format>image/png</Format>
<OnlineResource xmlns:xlink="http://www.w3.org/1999/xlink" xlink:href="http://localhost:80/geoserver/wms/GetLegendGraphic?VERSION=1.0.0&FORMAT=image/png&WIDTH=20&HEIGHT=20&LAYER=Updates" xlink:type="simple"/>
</LegendURL>
</Style>
</Layer>
</Layer>
</Capability>
</WMT_MS_Capabilities>
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.535 sec
Running org.vfny.geoserver.wms.responses.helpers.DescribeLayerTransformerTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.053 sec
Running org.geoserver.wms.CapabilitiesTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 1.017 sec
Running org.vfny.geoserver.wms.responses.map.metatile.QuickTileCacheTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.003 sec
Running org.geoserver.wms.responses.MapDecorationLayoutTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.012 sec
Running org.vfny.geoserver.wms.responses.map.openlayers.OpenLayersMapTemplateTest
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.315 sec
Running org.vfny.geoserver.wms.responses.map.legend.DefaultRasterLegendProducerTest
Aug 24, 2009 3:39:46 PM org.geoserver.wms.WMSTestSupport assertNotBlank
INFO: testUserSpecifiedRule: pixel count=600 non bg pixels: 153
Tests run: 1, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.276 sec
Running org.geoserver.wms.kvp.GetMapKvpRequestReaderTest
DecribeFT URL for topp:states: http://demo.opengeo.org/geoserver/wfs?VERSION=1.1.0&TYPENAME=topp%3Astates&NAMESPACE=xmlns(topp%3Dhttp%3A%2F%2Fwww.openplans.org%2Ftopp)&REQUEST=DescribeFeatureType&SERVICE=WFS&=&
org.vfny.geoserver.wms.WmsException: Could not connect to remote OWS
at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1137)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.parseLayers(GetMapKvpRequestReader.java:1043)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.read(GetMapKvpRequestReader.java:178)
at org.geoserver.wms.kvp.GetMapKvpRequestReaderTest.testRemoteWFSInvalidURL(GetMapKvpRequestReaderTest.java:389)
at org.geoserver.test.GeoServerAbstractTestSupport.runTest(GeoServerAbstractTestSupport.java:134)
at junit.extensions.TestDecorator.basicRun(TestDecorator.java:24)
at junit.extensions.TestSetup$1.protect(TestSetup.java:21)
at junit.extensions.TestSetup.run(TestSetup.java:25)
at sun.reflect.GeneratedMethodAccessor129.invoke(Unknown Source)
at org.apache.maven.surefire.booter.SurefireBooter.runSuitesInProcess(SurefireBooter.java:338)
at org.apache.maven.surefire.booter.SurefireBooter.main(SurefireBooter.java:997)
Caused by: java.net.ConnectException: Connection refused
at java.net.PlainSocketImpl.socketConnect(Native Method)
at java.net.PlainSocketImpl.doConnect(PlainSocketImpl.java:333)
at java.net.PlainSocketImpl.connectToAddress(PlainSocketImpl.java:195)
at java.net.PlainSocketImpl.connect(PlainSocketImpl.java:182)
at java.net.Socket.connect(Socket.java:520)
at sun.net.NetworkClient.doConnect(NetworkClient.java:152)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:388)
at sun.net.www.http.HttpClient.openServer(HttpClient.java:523)
at sun.net.www.http.HttpClient.<init>(HttpClient.java:231)
at sun.net.www.http.HttpClient.New(HttpClient.java:304)
at sun.net.www.http.HttpClient.New(HttpClient.java:321)
at sun.net.www.protocol.http.HttpURLConnection.getNewHttpClient(HttpURLConnection.java:813)
at sun.net.www.protocol.http.HttpURLConnection.plainConnect(HttpURLConnection.java:765)
at sun.net.www.protocol.http.HttpURLConnection.connect(HttpURLConnection.java:690)
at sun.net.www.protocol.http.HttpURLConnection.getInputStream(HttpURLConnection.java:934)
at org.geotools.data.wfs.protocol.http.SimpleHttpProtocol$SimpleHttpResponse.getResponseStream(SimpleHttpProtocol.java:67)
at org.geotools.data.wfs.WFSDataStoreFactory.loadCapabilities(WFSDataStoreFactory.java:684)
at org.geotools.data.wfs.WFSDataStoreFactory.createDataStore(WFSDataStoreFactory.java:347)
at org.geoserver.wms.kvp.GetMapKvpRequestReader.connectRemoteWFS(GetMapKvpRequestReader.java:1135)
... 33 more
Tests run: 17, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.942 sec
Running org.vfny.geoserver.wms.responses.map.kml.KMLSuperOverlayTransformerTest
Tests run: 2, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.402 sec
Running org.vfny.geoserver.wms.responses.map.georss.AtomGeoRSSTransformerTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.284 sec
Running org.geoserver.wms.DefaultWebMapServiceTest
Tests run: 3, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.223 sec
Running org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest
24 Aug 15:39:49 ERROR [geoserver.ows] -
org.vfny.geoserver.wms.WmsException: Invalid format 'unknown/format', supported formats are [text/plain, text/html, application/vnd.ogc.gml]
at org.vfny.geoserver.wms.requests.GetFeatureInfoKvpReader.getRequest(GetFeatureInfoKvpReader.java:108)
at org.geoserver.wms.kvp.WMSKvpRequestReaderAdapter.createRequest(WMSKvpRequestReaderAdapter.java:72)
at org.geoserver.ows.Dispatcher.parseRequestKVP(Dispatcher.java:1089)
at org.geoserver.ows.Dispatcher.dispatch(Dispatcher.java:431)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:209)
at org.springframework.web.servlet.FrameworkServlet.processRequest(FrameworkServlet.java:571)
at org.springframework.web.servlet.FrameworkServlet.doGet(FrameworkServlet.java:501)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:689)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1064)
at org.geoserver.test.GeoServerAbstractTestSupport.dispatch(GeoServerAbstractTestSupport.java:1031)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsServletResponse(GeoServerAbstractTestSupport.java:473)
at org.geoserver.test.GeoServerAbstractTestSupport.get(GeoServerAbstractTestSupport.java:454)
at org.vfny.geoserver.wms.responses.featureinfo.GetFeatureInfoTest.testUknownFormat(GetFeatureInfoTest.java:193)
Tests run: 10, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.982 sec
Running org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest
24 Aug 15:39:51 ERROR [geoserver.ows] -
java.io.IOException
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:124)
at org.vfny.geoserver.wms.responses.GetMapResponse.writeTo(GetMapResponse.java:630)
at org.geoserver.ows.adapters.ResponseAdapter.write(ResponseAdapter.java:60)
at org.geoserver.ows.Dispatcher.response(Dispatcher.java:703)
at org.geoserver.ows.Dispatcher.handleRequestInternal(Dispatcher.java:216)
at org.geoserver.test.GeoServerAbstractTestSupport.getAsDOM(GeoServerAbstractTestSupport.java:728)
at org.vfny.geoserver.wms.responses.map.kml.GeoSearchKMLTest.testBogusRegionator(GeoSearchKMLTest.java:92)
Caused by: javax.xml.transform.TransformerException: Translator error
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:133)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:108)
at org.vfny.geoserver.wms.responses.map.kml.KMLMapProducer.writeTo(KMLMapProducer.java:121)
... 44 more
Caused by: java.lang.RuntimeException: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:167)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encode(KMLTransformer.java:127)
at org.geotools.xml.transform.TransformerBase$XMLReaderSupport.parse(TransformerBase.java:714)
at org.apache.xalan.transformer.TransformerIdentityImpl.transform(TransformerIdentityImpl.java:484)
at org.geotools.xml.transform.TransformerBase$Task.run(TransformerBase.java:296)
at org.geotools.xml.transform.TransformerBase.transform(TransformerBase.java:129)
... 46 more
Caused by: org.vfny.geoserver.wms.WmsException: Unknown regionating strategy bogus
at org.vfny.geoserver.wms.responses.map.kml.KMLUtils.loadFeatureCollection(KMLUtils.java:478)
at org.vfny.geoserver.wms.responses.map.kml.KMLTransformer$KMLTranslator.encodeVectorLayer(KMLTransformer.java:163)
... 51 more
Tests run: 8, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 3.112 sec
Running org.vfny.geoserver.wms.requests.DescribeLayerKvpRequestReaderTest
Tests run: 6, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.013 sec
Running org.vfny.geoserver.wms.responses.featureinfo.FeatureTemplateTest
Tests run: 4, Failures: 0, Errors: 0, Skipped: 0, Time elapsed: 0.27 sec
Results :
Failed tests:
testRemoteOWSGet(org.vfny.geoserver.wms.responses.map.png.GetMapTest)
Tests in error:
testVectorWithRemoteLayer(org.vfny.geoserver.wms.responses.map.kml.KMLTest)
Tests run: 162, Failures: 1, Errors: 1, Skipped: 0
[ERROR] BUILD FAILURE
Please refer to http://hudson.opengeo.org/hudson/job/geoserver-trunk/ws/geoserver/wms/target/surefire-reports for the individual test results.
[INFO] Total time: 3 minutes 11 seconds
[INFO] Finished at: Mon Aug 24 15:39:53 EDT 2009
[INFO] Final Memory: 49M/172M
